another wheels question
tucker
Post by tucker »
Two things really, can anyone tell me the name of or where to buy a socket piece that fits the star shaped nuts on the bbs wheels? I have tried my local car shop and Halfords but had no joy. I want to split the two rims, then rub down the outer rim and get the inner section re-spayed.
So secondly instead of getting the inner spoked part of the wheel powder coated, can anyone recomend a good alloy wheel spray paint? I brought a can of Simoniz crome paint today and done a tester on a primed piece of wood, but was not impressed with the finish. Looked a bit splodgy looking if you know what i mean. Just want to make sure i get the right paint as once its sprayed theres no turning back. hope somebody can help.....many thanks
rich0404
Re: another wheels question
Post by rich0404 »
tucker wrote:Two things really, can anyone tell me the name of or where to buy a socket piece that fits the star shaped nuts on the bbs wheels? I have tried my local car shop and Halfords but had no joy. I want to split the two rims, then rub down the outer rim and get the inner section re-spayed.
torq bits you need for a rachet.
my halfrauds definately do them for a fact, if not b&q had a little set when i was in there the other day!
i will be doing this to my wheels soon, not really looked into it very well yet. but i think bstardchild did a walk-through on how to refurb wheels, look in there and have a look if he names any products.
hope i helped..
polo16vgti
Post by polo16vgti »
if your talking about he standard 15in bbs wheels on your polo the tool is actually called a spline bit the teeth are closer together than a torx bit torx bit have a larger gap between each tooth got a set at work can find out what size you will need if you want
stu nwpoc
Post by stu nwpoc »
Yeah im thinking of doing the same, if anyone has any good tips for doing this then please let us know, and yeah the size of spline bit we need would help us too
:D
smokeGTI
Post by smokeGTI »
tucker wrote:can anyone tell me the name of or where to buy a socket piece that fits the star shaped nuts on the bbs wheels? I have tried my local car shop and Halfords but had no joy.
The star shape shocket key should be in your polo's tool box.
If you do not have it, then you may buy one from your dealer.
As I know they have about 20 pattens for Polo's.
So you need to bring you car along ,and try them one by one.
vr6south
Post by vr6south »
Try your local motor factors. It's an M8 torx bit which fits perfectly. Managed to get one yesterday for just over £3.00 with a 14" adaptor to fit a std socket set. Don't let Halfrauds try to sell you one that "almost Fits". I've managed to polish two of my rims this afternoon, wish that I'd done it months ago :D
mkone
Post by mkone »
Thanks for letting me know what size torx I need, just getting myself round to doing the refurb at the moment. Been trying to source a set of spare rims for a while. vr6south would be interested in seeing pics of your progress. How much do most garages charge you to take the tyre's off?
vr6south
Post by vr6south »
My centres only needed a good clean with kitchen cream cleanser and a wax polish once they had been removed from the rim. I used a water based paint remover meaning that the tyres could be left on and made no difference on the finished result :). Probably better off doing it this way in order to leave the laquer intact where the tyre seals on the rim. It's cheaper as well :D . The area of the outer rim which is hidden by the centre was masked off to leave the laquer intact to further prevent corrosion in this area and also stops any cr$p falling into the exposed bolt holes. Before reassembly I coated the inner part where the two parts meet with a thin layer of grease, again to prevent the dreaded corrosion. Will try and post phots later :wink:
polo16vgti
i have found a step by step instruction and list of stuff you need including tools etc with pic on this forum under something to do with wheels but do you think i can find it now.
polo16vgti
i think it was basteadchild (think thats right) that did the wheels.
inder
Post by inder »
polo16vgti wrote:i have found a step by step instruction and list of stuff you need including tools etc with pic on this forum under something to do with wheels but do you think i can find it now.
here you go: http://www.tigerstyle.co.uk/poloforum/v ... hp?t=13624
