Hi All
My Alarm is keeps going off at the slightest bit of wind, or if so much as breath on the car.
Can anybody help me?
Can I adjust the sensitivity at all?
VW Alarm
- Sponsor
- Location: edinburgh/livingston, drives: polo gti red 5dr
Re: VW Alarm
I know how you feel i had this once but it wasnt the wind after hours of investagation. there was a bloody huge blue bottle fly in the car i never noticed hiding. it kept landing on the sensor. after i squashed it it solved the problemticki wrote:Hi All
You can adjust the sensitivity of the internal sensor with vagcom, vagcom will also register what sensor is setting the alarm off in the first place. It could also be the senor is faulty.
I had a similair problem with the alarm going off on mine and I thought it was the wind, turned out it was the rear washer jet doing its old trick off leaking and it was shorting the boot switch setting the alarm off. A good hint if it is this is that the boot open light on the dash would very lightly flicker every so often as it uses the same switch for this as the alarm.
- ticki
- Sponsor
Sounds very likely. I am slamming the the doors and hatch quite hard to shut them proper. Do you think a bit of lubrication might help?Dangerous Dave wrote:You can adjust the sensitivity of the internal sensor with vagcom, vagcom will also register what sensor is setting the alarm off in the first place. It could also be the senor is faulty.
I've had this problem before, with the exact same symptoms. I'd suggest taking off the plastic cover to the inside of the boot door and check the washer hose.
To remove it you need to undo 2 hex head screws i think and just unclip the rest carefully. Make sure the hose is all connected properly and while you're there take a peek at the lock inside - there'll probably be washer fluid lurking around.
When it happened to me i had to replace the lock part, cos it had shorted the circuit and no longer worked properly.
Good luck
Ant
Good luck
Ant
- ticki
- Sponsor
Thanks mate I will give that a go this weekendAnt_43 wrote:I've had this problem before, with the exact same symptoms. I'd suggest taking off the plastic cover to the inside of the boot door and check the washer hose.
Good luck
Ant
