Will this fit in a uk car??
desgreen
Post by desgreen »
Will this Monsoon stereo work on a UK POLO??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
toXXin
Moderator
Post by toXXin »
The radio wont as the US uses different frequencies to us.
Wai_Mak
Post by Wai_Mak »
I bought a US headunit, the only difference is that in the US the Frequency Module (FM) scans in odd decimal digits,
eg, it will scan 87.9Mhz 88.1Mhz 88.3Mhz - increment of 0.1Mhz every step!
So you will basically miss the radio stations with an even decimal, such as KISS FM and CAPITAL FM
Clawz
Post by Clawz »
You can get a converter for this which plugs into the aerial socket for most radios :)
markjsca1
Post by markjsca1 »
Where can you get that from clawz? I've a Head Unit from the US and i can only get about half the radio stations clearly here in ireland. It'd definatly be worth it...even tho i dun listen to the radio that much... How much do you reckon it'd be?
Clawz
Post by Clawz »
I can't remember where I saw the UK ones, but here's a link to show you what I mean:
http://www.audiocubes.com/product_info. ... cts_id=464
rooboy
Post by rooboy »
Wai_Mak wrote:I bought a US headunit, the only difference is that in the US the Frequency Module (FM) scans in odd decimal digits,
So you will basically miss the radio stations with an even decimal, such as CAPITAL FM
well it's not that bad then :lol: :lol:
GANA
Post by GANA »
Clawz wrote:I can't remember where I saw the UK ones, but here's a link to show you what I mean:
Can you please give me a link for the UK ones? Does this converter work?
Babe RuthLess
Post by Babe RuthLess »
In addition to different FM scanning, American radios scan MW in 10KHz steps while in Europe, Asia, Africa etc. that's done in 9KHz steps.
Also, most radios from this part of the world (including those double-DIN Monsoons) do not include RDS features.
Still, it'd fit a Polo without problems.
Babe RuthLess
Just remembered something: that converter basically changes your radio's FM frequency range, but won't change the way the unit scans the frequencies.
As the site probably explains, Japan uses a different FM range than the rest of the world (as usual).
I do know that some stereos have a choice of 9 or 10KHz increments for MW tunning, not sure about FM though.
'Course, if the thing can be tunned by the 0.01MHz then that's not really a problem I suppose.
