i just bought new struts for my polo now they are uprated but i have not idea how to fot the front ones, well i do i have had them off before but will i have to press the old strut out of the hub and new ones in or is it a bolt clamp ?
as much help as possible would be appreciated
having i suspension dilemma please help
do you have the hole suspension strut, or just the insert?
the strut and hub are all in one on these so if you have a new strut you may have to change the hub over. if you have the insert, you'll have to strip the unit and install the new insert into the housing. Not a hard job but will likely need spring compressors etc.
