Hi there guys, Just after some info really... Things I am after:
Interior Light bulbs: Ie, the reading light, or the light that comes on when the doors open.
Reg plate bulbs
Fog / Spot light bulbs
Aftermarket Angel eyes full beam and main beam bulbs
Cheers guys!
P.S. Pretty new on this forum, will post some pics of my polo soon! See you guys around soon!
Polo 9N3 Bulb Sizes?
- Karson3270
Re: Polo 9N3 Bulb Sizes?
Welcome to the forum. Regards the bulbs your handbook for the car will detail what is required for what function it does.
On the bulbs for angel lights ? I haven't got a clue maybe some of the lads on here can point you in the right direction. Other than that take the bulbs out and go to Halfords, if in any doubt go to the stealers. In saying that their bulbs are not that expensive and you will get the correct ones.
I can only tell you a few mate which is what i know for 100%
Dipped Beam - H7
Main Beam - H1
Reading bulbs in the ceiling x 2 - Same as your sidelights
Fogs - H3
Rear number plate bulbs - Festoons aswell same as below
Interior light x 1 in the ceiling of the car - I think they are called festoons, pic below
Thats everything i think lol, but i know every1 of the above 100% correct
Hope it helps.
Dipped Beam - H7
Main Beam - H1
Fogs - H3
Hope it helps.
- Karson3270
Thanks mate, I ordered some H3's and they arrived today! But the thing is, I have no idea how to replace the bulb... The bulb which I have taken out looks more like the H8-H11 range on this picture shown: http://www.team-bhp.com/forum/attachmen ... _chart.jpg
Any ideas where I have gone wrong?
Cheers!
Cheers!
would u be able to get a pik of the actual bulb mate then ill have another lookk, cheers
As far as i know these are the light bulb types:
Side lights and 2 interior map lights = 501 wedge
interior dome light, sunvisor mirror light and number plate lights = 39mm festoon
dip beam = H7
main beam = H1
Fogs = HB4/9006 (not 100% on this as not changed them myself)
Hope this helps!!!
dip beam = H7
main beam = H1
Hope this helps!!!
- Karson3270
http://img710.imageshack.us/img710/1305 ... 101559.jpg
Sorry about the poor quality it was dark
Cheers for your help guys! Pics of my beauty will be posted when the weather starts clearing up and I get to give it a good clean!
On the cover that goes on the back of my fogs actually has the connection that your bulb has on it which is wierd, what i think might happen you clip the bulb into the cover then clip the bulb into the fog and reconnect the wire on the outside of the cover, on mine it was a H3 bulb as didnt take long at all =S
- Karson3270
So when you took your bulb out it didn't look like mine?
- Karson3270
I think I found the solution guys... The bulb size/type is 9006 :S Sounds a bit strange... http://img.alibaba.com/photo/51206500/9 ... n_Bulb.jpg
But it sounds right! So I'm happy! Thanks anyway guys!
