VW POLO 6R. WIRING AUTO LIGHTS. Coming/leaving home. OEM.
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
Description:
Automatic lights and functions coming/leaving home.
For all VW POLO 6R with factory xenon headlights + light sensor .
For all VW POLO 6R with halogen headlights + start/stop system + light sensor. Bluemotion.
Full Kit
+ + + VCDS coding
- Wiring 100% OEM. Brand new. Lifetime warranty in the wiring.
- One switch OEM. Brand new.
- Two universal relays. Brand new.
- Coding perfect through email. All lights will work correctly, same as factory.
110 € -10% = XXX Included shipping and PayPal fees
Payment by PayPal Shipping certified and tracking number. Shipping worldwide.
***********Sold out!***********
Installation Guide: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Laser 3932 Terminal Tool: http://www.ebay.co.uk/sch/i.html?_from= ... ol&_sop=15
Full Kit
+ + + VCDS coding
Re: POLO 6R. WIRING AUTO LIGHTS. CH/LH.
Light sensor
Features:
Automatic Light:
The main lights come on when the light threshold is appropriate.
Leaving Home:
Unlock the car with the remote control, then dipped beam (or fog lights), side lights, license plate lights come on for the set time.
Coming Home:
Turn off the ignition, then pull the high beam stalk once (flash), now when you open the door dipped beam (or fog lights), side lights, license plate lights come on for the set time.
Set time:
To change the set time is on channels 47 and 48 Adaptation or Adaptation UDS from the drop panel.
This can be up to 60 seconds, but I think it's best not to put more than 30 seconds, the battery will wear less.
http://www.uk-polos.net/view ... 05#p474349
Example of purchase order (thanks to teji-GTI):
Click to enlarge:
Features:
Automatic Light:
Leaving Home:
Coming Home:
Set time:
Click to enlarge:
"Model Year"
I need to know the tenth letter of the VIN to send the correct wiring.
For example:
WVWZZZ6RZDYXXXXXX
D = MODEL YEAR 2013
(A=2010, B=2011, C=2012, E=2014) You should check physically.
VIN: you can find in a small window of the windshield or also in autoscan with VCDS.
VIN http://en.wikipedia.org/wiki/Vehicle_id ... ion_number
For example:
WVWZZZ6RZDYXXXXXX
D = MODEL YEAR 2013
Hi Ciclo,
I saw your post in der german forum and your item on Ebay. I would like to buy one of your wirings. How can I get into contact with you? Since I' am new in this forum, PMs are disabled for me. My polo is a WRC, build in 2013.
Regards.
Regards.
HI vase_t, you have a PM.
i would buy but i dont have a light sensor
http://www.aliexpress.com/item/OEM-Auto ... 26711.html
http://www.polovw.it/foro/viewtopic.php ... 58#p448328 pages 21,22,23
Other possibilities: (sensor only)
http://forum.mypolo.nl/polo-v-6r/5387-a ... post165530
VCDS (all 6R):
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050512 05 54 0403
Coding: 06302D
VCDS (all 6R):
Coding: 06302D
Re: VW POLO 6R. WIRING AUTO LIGHTS. Coming home/leaving home
Did you know that my wiring is the best you can buy? ...
Did you know that the most important is the support during installation? ...
Good news.
After installing my wiring (similar ) for automatic lights on a VW POLO BlueGT halogen headlights and make a "special VCDS coding", automatic lights and CH/LH working perfectly.
Possibly the first 6R with halogen headlights and automatic lights in the world. OEM
Hi Ciclo,ciclo wrote:Good news.
After installing my wiring for automatic lights on a VW POLO BlueGT halogen headlights and make a special VCDS coding, automatic lights and CH/LH working perfectly.
This is possible by having start/stop system and an appropriate BCM.
I saw on a danish VAG-forum that a guy installed you wiring for Auto-light in his BlueGT with halogen headlights.
I have Blue GT with Halogen headlights and double foglights and I want your solution instead of my current solution from China.
What do I need to buy from you?
The special VCDS coding, is that the guide you made here: http://www.uk-polos.net/view ... 20#p474658
Br,
Henrik
Denmark
Hi HenrikC_DK
I send you a PM with my email for you to contact me.
Re: VW POLO 6R. WIRING AUTO LIGHTS. Coming/leaving home. OEM
I would like to buy one of your wirings. How can I get into contact with you? I' am new in this forum, PMs are disabled for me.
thanks !
thanks !
Hi citroene, you have a PM.
- Drives: Blue GT
My car – a Polo Blue GT – was the first to get Auto light and CH/LH OEM despite the fact that the car is equipped with Halogen front lamps.
How?
Very simple: I installed the wiring made by Ciclo and of course an original Auto light switch!
However, it requires that your car have the rain sensor and the start/stop system OEM.
The installment was very simple to carry out – following the instructions made by Ciclo. The difficult part was to put the two wires into the right places in the BCM – the rest was a piece of cake to do. The coding was also very easy because I simply e-mailed my auto scan to Ciclo who prepared the new coding as a copy and paste. Therefore, it took less than five minutes to recode my car after the installment.
When I ordered the wiring by Ciclo it took less than six days before it arrived as a track and trace shipment her in Denmark where I live. The payment was carried out using PayPal so I also felt very secure about that part.
The wiring itself is top professional made – hard to spot the difference between this and a factory made part.
The result?
DRL: Check
Sidelights: Check
Low beam: Check
High beam: Check
Front fog lights: Check
Rear fog light: Check
Reversing light: Check
Auto light: Check
CH via fog lights: Check
LH via fog lights: Check
So in other words: Everything works perfectly!
In addition, because the system uses the original rain/light sensor it is very easy to change the sensitivity of the system.
I can only recommend this wiring from Ciclo – outstanding work!
How?
The result?
DRL: Check
Sidelights: Check
Low beam: Check
High beam: Check
Auto light: Check
Installed this to my WRC and it works just perfect. Great communication and support from Ciclo. Highly recommended!
