Rattles when cold..
CrypticG
Drives: 1.2 TSI SEL (6C)
Rattles when cold..
Post by CrypticG »
Hi guys,
Just a small niggle that is annoying. Basically, whenever i am driving over almost all roads, i have a low frequency rattle/creaking coming from my drivers side and passenger side front doors (3-door model). It is coming from the top of the plastic door panel and is mainly audible when the interior of the car is cold. It also occurs when the engine is in high gear with low revs.
Just wondering if anyone has any ideas, experience or knowledge on how to stop the plastic trim on a door from rattling? Preferably without having to take the door apart. Ive been to the dealer with it, when it was in for a software update, but they basically said monitor it and see if it gets worse, but its already worse enough for me! lol  :x thanks in advance!
Picture of the area below:
alexperkins
Site Admin
Re: Rattles when cold..
Post by alexperkins »
Could be the door pull cable rattling against the door card inside
CrypticG
Post by CrypticG »
alexperkins wrote:Could be the door pull cable rattling against the door card inside
Sorry mate, what is that? How could i fix it?
alexperkins
Site Admin
Theres a cable between the door handle and the door lock that runs along the inside of the door card
Its a case of removing the door card, wrapping the cable in bubblewrap (or similar) then putting it back on
CrypticG
Post by CrypticG »
Thank you, sounds a big job bloody hell. Im not great at messing with cars. Might have to pester the dealer.
alexperkins
Site Admin
Its not particularly difficult, though removing the doorcard isnt pleasant lol
CrypticG
Post by CrypticG »
yeah, ive watched a few videos, in particular the removal of an Audi A1 panel and that has some tricky bits
vc-10
Post by vc-10 »
If it's still on warranty, then take it to the dealer. It shouldn't be rattling.
6REA211
Drives: 1.2 SEL
Post by 6REA211 »
Is it a rattle or a creaking sound? I suffer that on my BMW ... it's the glass rubbing against the window rubber and is caused by silicones in the wash shampoo. Cure is to clean everything with IPA or similar and then use a shampoo with no additives. Auto Finesse Lather works for me.
CrypticG
Rattles when cold..
Post by CrypticG »
It is kind of a really quiet creaking sound to be honest. It sounds like it is coming from the plastic trim though - and when I pull the door handle it seems to stop..? Opening the window disrupts it but then it will start again. It's not a major issue just something that is annoying. It is intermittent as well, sometimes it is present - other times it isn't..
alexperkins
Site Admin
That definately sounds like the door handle cable
CrypticG
Rattles when cold..
Post by CrypticG »
Thanks Alex. I think I am going to send it back in for a fix. No point me messing around when it's under warranty. What should I ask for? To have the door handle pull cables wrapped? Or have the door padded with foam?
alexperkins
Site Admin
I would just ask them to investigate the rattle, and potentially fit sound deadening material where necessary, and that you think it could be the door pull cable 8)
CrypticG
Post by CrypticG »
great, thank you :)
6REA211
Drives: 1.2 SEL
Post by 6REA211 »
Before going to the dealer why not just try cleaning the window rubbers at the top of the door panel? The fact that it goes away when the window moves sort of points to the rubbers. It was weeks before I identified the problem on my car ... I was convinced it was the door cards themselves!
