Central locking kit
Leeren666
Drives: polo 6r
Central locking kit
Post by Leeren666 »
anyone used these kits from the bay ? http://www.ebay.co.uk/itm/Remote-Centra ... 3f4beae4e4 Don't have remote locking on my polo and really want to upgrade it, just curious about fitting, heard stories about fitting in line resistors etc ? What's all that about ? I have a friend that would fit it but I don't want to give him a nightmare doing it
6RPotentialBuyer
Drives: Candy White Polo 6R
Re: Central locking kit
Post by 6RPotentialBuyer »
IMO wouldn't trust the locking/security system of my car with a £12 eBay part. It's begging for trouble.
Leeren666
Drives: polo 6r
Post by Leeren666 »
I'm open to suggestions if you know of a more expensive/trusted upgrade ?
alexperkins
Site Admin
Post by alexperkins »
Rclick.co.uk
They do a kit now with a genuine VW key shell
You'll need to put a resistor in for the central locking on these
Leeren666
Drives: polo 6r
Post by Leeren666 »
Been reading up on the rclick but where does the resistor go ? What value and where can I get one ? Help ! Got the kit ordered and want as much info as possible before I/we attempt to fit it ? Is there anyone with a wiring diagram out there ?
alexperkins
Site Admin
It goes under the dash where the wires come out from the drivers door loom.
Ill find the link and add it in for you
alexperkins
Site Admin
Leeren666
Drives: polo 6r
Post by Leeren666 »
Thanks for that, can just order a 180 ohm resistor from eBay ? Waiting to get a full weekend off to fit the kit so not an immediate rush yet
alexperkins
Site Admin
Yea or pop to your local maplin
Leeren666
Drives: polo 6r
Post by Leeren666 »
Pm sent to you sir !
At least I think I have... Says its sat in my outbox ?
Leeren666
Drives: polo 6r
Post by Leeren666 »
Right, I have the rclick kit, had the keys cut, which was a mission itself, moved the transponders over, keys are working locks and starting car fine now, just need to install the kit tomoro, just been reading through the kit and it also has window closure too, couple of questions, I had a quick look up behind the dash in drivers footwell and can only find one harness coming from door, is this the one I need to split and tap into ?
Second question, do I need to connect the window closure wire ? My windows close when the key is held in the closed position anyway ?
alexperkins
Site Admin
Yes from the door
And no ignore the window wire
Leeren666
Drives: polo 6r
Post by Leeren666 »
Hi Alex sorry to be a pain, but does that mean my windows will close with the locking too ?
alexperkins
Site Admin
No, still controlled by the key
Getting the window roll up to work is more complicated on these models than a single wire. Requires diodes and relays
