Forge intercooler - 1.4 GTI & 1.8GTI - *SOLD*
- Drives: Scirocco R 2015
Forge intercooler for the 1.4 TSI GTI model. Only a couple of months old, sprayed with 'FORGE' in black.
Product Description (taken from forge website)
After over 12 months in the development, testing and refining this product, we are pleased to offer what has to be the best intercooler upgrade in the market place today for the Fabia VRS, Polo GTi 1.4 twincharged engine, and the Polo 1.8T 2015 onwards. The original intercooler has been redesigned using a high thermal efficiency core, to offer greater cooling. This has been combined with a significant increase in both the frontal surface area and overall dimensions, as you can see clearly in the images.
After early experimentation with various designs of fabricated end tank, and in order to obtain an even airflow within the intercooler, we have used a cast alloy tank. This not only improves on the performance in this particular application, but allows the complex OEM mounting design to be retained, ensuring perfect fitment. The result of all this hard work is clearly evident with a good torque and power increase all the way across the rev range, and not just a peak figure increase. This equates to really usable gains. The difference is felt even on a car running standard software (+10hp). The maximum gains achievable of course will be dependent on the software used but on a software tuned car we recorded 18hp on the first power run.
When looking at any dynamometer results, it is the shape or area under the curve that helps you visualise the usable engine power and the rpm where it occurs. It is far too simple to just look for the peak figures that are often quoted by so many, and miss what the data is really saying. The performance of this intercooler can only be described as the ideal, that all tuners aim for better cooling providing a reduction in inlet temperature (-15°C), reduction in resistance or differential pressure, improved airflow, clear increase in power across the rev range, and an intercooler that utilises original mountings.
Test results are carried out on standard and stage 1 levels mapped engines. Turbo upgrades that include higher boost pressure and flow properties may exceed the flow parameters of this intercooler.
Looking for *SOLD SOLD SOLD* POSTED ono.
Located in Lincolnshire near Horncastle if you would prefer collection.
Will be sent on Fedex next day service depending on time of payment etc.
Re: Forge intercooler - 1.4 GTI
Another off the car.. boxed up ready to send
Re: Forge intercooler - 1.4 GTI & 1.8 GTI
just to add will also fit the new 1.8turbo polo's
Re: Forge intercooler - 1.4 GTI & 1.8GTI
Priced reduced to £350.
Do you have any pics of it on the car with the bumper on? Can you see the writing on it?
I don't unfortunately.. it was only on the car a short while before i decided to go standard.Deejbb wrote:Do you have any pics of it on the car with the bumper on? Can you see the writing on it?
You can see it, but if you buy the same template from the forge website (about £10) and carefully place it in the same area you could always respray a new colour?
i did it black because i wanted a subtle look, personally not a fan of it being in your face and so obvious.
Yeah I wouldn't want it to be too visible.. Thanks, will let you know.
squatted down or kneeling from an angle it is but stood from a short distance its subtleDeejbb wrote:Yeah I wouldn't want it to be too visible.. Thanks, will let you know.
Will accept £300, need this out my dads garage
Surely someone wants this?
Still for sale. £300 ono posted.
re-listed on eBay again - http://www.ebay.co.uk/itm/-/281911773134?
will accept £300 from forums or purchase via eBay and let me know you've seen it here..
is it needed to replace the pipework or is that all the same in diameter and location?
Everything's the same, literally bolt off bolt oniichel wrote:is it needed to replace the pipework or is that all the same in diameter and location?
SOLD SOLD SOLD
