Jossie90
Drives: 6R 1.2 TDI
Post by Jossie90 »
With byte16 set to 0xFF it still doesn't work, but it does flash quickly (once < 50ms or so) when going going from 2->1. Byte 23 does not influence issue.
Hi Jos, I've been through the wiring schemes again, maybe I messed up somewhere.
But it appears to be ok. You also don't have any errors on your VCDS autoscan? Your coding looks perfectly fine to me. Really strange. I cannot make any chocolate of it...
Could you check your fuses maybe? It's a long shot.
You have a multimeter, right? Could you check whether all wiring is intact? It probably is, since your problem shows up at both sides.
It should work, the BCM of the Bluemotion is capable of sending out the correct signals.
Somehow it appears not to be in xenon mode, if it were then I'd expect some errors about the communication with the LED module.
Could you try this coding, just as a reference?
3CB02BB808210000002809F07F2B9CD9FF80673F7EA61001A00000000000 (cornering lights in bumper)
3CB02BB808210000002809F07F2B9CD9FF80673F7E051001A00000000000 (cornering lights in headlight)
It's a few codings of my old 1.2TDI with OEM xenon. It might throw a few erros since the equipment is different but at least the lighting should be ok.
Jossie90
Drives: 6R 1.2 TDI
Post by Jossie90 »
Hello,
I have checked the autoscan again and there are no errors in the CECM. Is the CECM capable of detecting faulty DRL LEDs?
I have also checked the fuses; they're fine. The halogen DRL also works fine if I connect it again. I think the 6V I measure in switch mode 1 or 2 must be due to a cold bulb detection.
I've tried to apply the codings you gave me; it won't allow me to set it due to an error ("Request out of range").
I have checked the wiring I have added myself. I actually measure a voltage so it has to be connected all the way, I think.
Jos
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote:
firegrafik wrote: Now question is concerning headlight washer adaptation. What adaptation channels of 09 Cent.Eletr. change washer running time and frequency?
Perhaps, :?:
Each 5 cycles (by pulling of wiper stalk) is set from factory.
It's just a suggestion (not tested), but now I have the curiosity about it. We will have to look for it. :)
I've found out.
The 09centr.electr adaptation channel 42 is define the quantity of wiper stalk's pulling to run the headlight washer. Next step is to find out how to change its running time
Jossie90
Drives: 6R 1.2 TDI
Post by Jossie90 »
Iichel,
Thank you very much for your help!
I tried to apply most of your coding and found myself with partially working headlights. After modifying my coding byte by byte, I found the error in my coding.
If anyone else experiences issues with DRL, try the following:
Enable bit 4 in byte 22 (or change it to 0x10).
This fixed it for me!
graag gedaan :-)
R Line
Drives: R Line TSI 1.2 (Mid 2013)
Post by R Line »
Hello Ciclo Hola, greetings from Barcelona, I`m Victor new to the forum, I have a 6R-Line June '13, to tell you I love your changes, thanks to you I replaced the MFA+Instrument cluster and MFSW R-Line. Now I want to change the automatic switch lights but not sure the part number that you used...5GG 941 431 D may be this? http://es.dhgate.com/product/olkswagen- ... 64842.html
Do you think that is compatible with the wiring they sell here?
https://www.x2car.de/Coming-Leaving-Hom ... egensensor
PD. I have from factory rain-light sensor, bi-xenon headlights, fog lights front/rear
Excuse my English
Best Regards
Gracias!
karasovalye
Drives: polo 6c papergray
Post by karasovalye »
hallo ciclo i bildt also a light and rain-sensor but i have a problem. i installed 3 cables 1 red+ 12 v 2 ground 3 cable to bcm T73 C 15 but i have make a connection
to B528 1 LIN-sBUS where can i find this cable. end what is line bus i now can bus but no lin- bus can jou help me please
Hello to all my dear friends around the world.
I'm still working with the renovations (reforms) at my home, I guess I'll not finish until early next month...
I just read all the messages (emails, forum replies, etc) that I have received over this month, just now it is impossible for me to answer this huge amount of emails-messages, I'm sorry honestly, without time due to different reasons it is impossible.
However, all emails are a great encouragement to finish as soon as possible with the work I am doing and come back with all you. Thank you very much to all
Regarding my car, nothing new, only to note that I passed ITV(SP) = MOT(UK) with favorable result.
This is the last autoscan I did before the ITV:
Wednesday,08,June,2016,12:07:19:06516
VCDS Version: 15.7.4.1
Data version: 20160216
http://www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: ITV
Mileage: 18790km-11675mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 18790km-11675miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6A67323C071007E03A-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02FF02F46B1877387A-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38299E9647163342CA-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 68593E2607E613F24A-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E338AB877341F949A-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A4772DC8770C7C03A-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 352A989F53194157E2-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2E23AA8837C47F041A-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A27B27C0FD087203A-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37289C9543133545D2-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F20AC8DB7FB657D12-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77681C554B53B505D2-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3B3494A17B072DA9B2-806E
End-------------------------(Elapsed Time: 03:23)--------------------------
I come back soon... (early July) I guess. Image :lol:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
firegrafik wrote:
benzinkopf wrote:
firegrafik wrote:New discovery.
Rain closing function works not only on a locked car. It works on unlocked car also. :D
Tell us more. Havent got that working at all on mine so far.
Some time ago I retrofit exterior light wiring, make it through max BCM 7E0937090, installed the rain-light sensor and high-beam assistant(FLA).
Reports are below (unfortunately only on russian)
https&#58;//www&#46;drive2&#46;ru/l/8632361/
https&#58;//www&#46;drive2&#46;ru/l/9309752/
https&#58;//www&#46;drive2&#46;ru/l/10042246/
Hi firegrafik,
Can you share with us your coding for windows regulator motors coding?
firegrafik
benzinkopf wrote: Hi firegrafik,
No problem. There is one of my last autoscans below.
Those door units are from factory
Friday,13,May,2016,15:07:39:10463
ВАСЯ -- программа для диагностики автомобилей концерна VAG запущена на Windows 7 x86
ВАСЯ Версия: 16.0.2.1
Версия данных: 20160226
VIN: XW8ZZZ61ZEGGRAFIK   Номерной знак: С897ХУ
Пробег: 26340km-16366mi   Номер заказ-наряда: 0013(RnClOff)
Шасси: 61 (7E0)
Список: 01 03 08 09 15 17 19 20 25 44 0B
VIN: XW8ZZZ61ZEGGRAFIK   Пробег: 26340km-16366miles
01- Электроника двигателя -- Статус: OK 0000
03- Электроника тормозной системы -- Статус: OK 0000
04- Датчик угла поворота рулевого колеса -- Статус: OK 0000
08- Электроника кондиционера / отопителя -- Статус: OK 0000
09- Блок управления бортовой сети -- Статус: OK 0000
15- Подушки безопасности -- Статус: OK 0000
17- Комбинация приборов -- Статус: OK 0000
19- Диагностический интерфейс шин данных -- Статус: OK 0000
20- Ассистент управления дальним светом -- Статус: OK 0000
25- Иммобилайзер -- Статус: OK 0000
44- Усилитель руля -- Статус: OK 0000
Адрес 09:  Блок управления бортовой сети (J519)       Label: 7E0-937-BCM-V1.clb
   Компонент: BCM PQ25 Max4 H80 0733
   Ревизия: B9080001    Серийный номер: 0771 139150190
   Кодировка: 22904ABF48E1240093380E007ECB16F000C8614F60842055220000030800
   Мастерская #: WSC 12345 123 12345
   VCID: 68D444B99B5B047D3E-803C
   Подсистема 1 - Part No: 5K7 955 559 B  Label: 5K7-955-559.CLB
   Компонент: RLS 260215 03  37  0059
   Кодировка: 0714DD
   Подсистема 2 - Part No SW: 6R0 959 801 AG    HW: 6R0 959 801 AG  Label: 6R0-959-801.CLB
   Компонент: -------------  006 5530
   Кодировка: 000000
   Подсистема 3 - Part No SW: 6R0 959 802 AM    HW: 6R0 959 802 AM  Label: 6R0-959-802.CLB
   Кодировка: 000000
   Подсистема 4 - Part No: 1K8 951 171 A
   Компонент: DWA-Sensor 00  001 0103
   Кодировка: 000000
   Подсистема 5 - Part No: 1K0 951 605 C
   Компонент: LIN BACKUP HO  H05 1501
   Кодировка: 000000
   Подсистема 6 - Part No: 1K8 951 171 A
   Кодировка: 000000
   Подсистема 7 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Компонент: E221__MFL-TAT  H04 0019
   Кодировка: 240000
   Подсистема 8 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Кодировка: 020000
   Подсистема 9 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Кодировка: 020000
Неисправности не найдены.
benzinkopf
Friday,13,May,2016,15&#58;07&#58;39&#58;10463
ВАСЯ Версия&#58; 16&#46;0&#46;2&#46;1
Версия данных&#58; 20160226
VIN&#58; XW8ZZZ61ZEGGRAFIK   Номерной знак&#58; С897ХУ
Пробег&#58; 26340km-16366mi   Номер заказ-наряда&#58; 0013(RnClOff)
Шасси&#58; 61 (7E0)
Список&#58; 01 03 08 09 15 17 19 20 25 44 0B
VIN&#58; XW8ZZZ61ZEGGRAFIK   Пробег&#58; 26340km-16366miles
01- Электроника двигателя -- Статус&#58; OK 0000
03- Электроника тормозной системы -- Статус&#58; OK 0000
04- Датчик угла поворота рулевого колеса -- Статус&#58; OK 0000
08- Электроника кондиционера / отопителя -- Статус&#58; OK 0000
09- Блок управления бортовой сети -- Статус&#58; OK 0000
15- Подушки безопасности -- Статус&#58; OK 0000
17- Комбинация приборов -- Статус&#58; OK 0000
19- Диагностический интерфейс шин данных -- Статус&#58; OK 0000
20- Ассистент управления дальним светом -- Статус&#58; OK 0000
25- Иммобилайзер -- Статус&#58; OK 0000
44- Усилитель руля -- Статус&#58; OK 0000
Адрес 09&#58;  Блок управления бортовой сети (J519)       Label&#58; 7E0-937-BCM-V1&#46;clb
   Part No SW&#58; 7E0 937 090     HW&#58; 7E0 937 090
   Компонент&#58; BCM PQ25 Max4 H80 0733
   Ревизия&#58; B9080001    Серийный номер&#58; 0771 139150190
   Кодировка&#58; 22904ABF48E1240093380E007ECB16F000C8614F60842055220000030800
   Мастерская #&#58; WSC 12345 123 12345
   VCID&#58; 68D444B99B5B047D3E-803C
   Подсистема 1 - Part No&#58; 5K7 955 559 B  Label&#58; 5K7-955-559&#46;CLB
   Компонент&#58; RLS 260215 03  37  0059
   Кодировка&#58; 0714DD
   Подсистема 2 - Part No SW&#58; 6R0 959 801 AG    HW&#58; 6R0 959 801 AG  Label&#58; 6R0-959-801&#46;CLB
   Компонент&#58; -------------  006 5530
   Кодировка&#58; 000000
   Подсистема 3 - Part No SW&#58; 6R0 959 802 AM    HW&#58; 6R0 959 802 AM  Label&#58; 6R0-959-802&#46;CLB
   Подсистема 4 - Part No&#58; 1K8 951 171 A
   Компонент&#58; DWA-Sensor 00  001 0103
   Подсистема 5 - Part No&#58; 1K0 951 605 C
   Компонент&#58; LIN BACKUP HO  H05 1501
   Подсистема 6 - Part No&#58; 1K8 951 171 A
   Подсистема 7 - Part No SW&#58; 6C0 959 442     HW&#58; 6C0 959 442
   Компонент&#58; E221__MFL-TAT  H04 0019
   Кодировка&#58; 240000
   Подсистема 8 - Part No SW&#58; 6R0 959 811 L    HW&#58; 6R0 959 811 L
   Кодировка&#58; 020000
   Подсистема 9 - Part No SW&#58; 6R0 959 812 L    HW&#58; 6R0 959 812 L
Неисправности не найдены&#46;
Oh. Now i can see ur door motor coding is all zero... Accept for the rear doors which is 020000. Hurm
firegrafik
benzinkopf wrote: Oh. Now i can see ur door motor coding is all zero... Accept for the rear doors which is 020000. Hurm
Yes, this fact embarrassed me to. Many polo owners in Russia tried to retrofit a high line door motors, changing the whole door harnesses, but stlill have not a positive result. Somebody wrote a guess that when you provide the door motor retrofitting, the door unit's correct coding not the most important procedure, it has to be adapted basically and in theory the official dealer this could provide.
benzinkopf
High line door motors? What that offers?
i guess the electric adjustable mirrors and the comfort function.
you probably already tried the many codings available in the autoscans. and the bcm 7E0 in firegrafiks car should support it for sure
Locked
