Hi dears!!
i have a BIG problem with my polo... i install a new steeringwheel, this one in picture:
it's fantastic, before this i had not steering wheel commands, but with two wires i resolved the question.
after install, i had airbag error light, and i try to remove it with my vag com, but nothing happen: i recived the error "airbag igniter resistence too low"
what can i do? i change only airbag and steering wheel, not my clock ring...
new airbag has this connector
and this is my standard clock connector...
i'm pretty sure that airbag is not fault. ( and sorry for my bad english..... )
any idea? help..
Airbag problem after new steering wheel
- Drives: polo 6r
- Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Re: Airbag problem after new steering wheel
As you did not have a MFSW before you will need a new airbag and airbag wiring loom. See this link viewtopic.php?f=10&t=54171
- Drives: polo 6r
hi dear, the problem is that i alredy have right airbag and i had put the other 2 wires..! i wish it's the clock spring...joe6 wrote:As you did not have a MFSW before you will need a new airbag and airbag wiring loom. See this link viewtopic.php?f=10&t=54171
