Dash cam fitting
MczZippy
Drives: Polo GTI 6C - Flash Red
Dash cam fitting
Post by MczZippy »
Evening all!
Just looking to fit my dash cam, has anyone fitted one? Also how did you get the wire into the fuse box under the dash?
I tried to remove the a-pillar trim but it wouldn't pull off, any ideas?
Cheers!
Re: Dash cam fitting
I think if you search around, this has been covered already, maybe even in this forum, if not look on the main Ibiza and Fabia forums for facts.
Bigtam
Drives: Polo GTI 2016
Post by Bigtam »
What car have you got mate? The side pillar trim is very hard to come off I broke all the clips on my first polo but since I got the GTI I done it a different way.
This is on a Polo Blue GT
viewtopic.php?f=56&t=66839&p=496699#p496699
6RPotentialBuyer
Drives: Candy White Polo 6R
Post by 6RPotentialBuyer »
I did a DIY install on my car, I can put some photo's up and show you how I did it.
MczZippy
Post by MczZippy »
cheers for that! i had it fitted to my Citigo, but as you said broke a couple of clips getting the trim off!
there must be a way to remove without damage....
MczZippy
Post by MczZippy »
Sorted, managed fit without removing panels and hidden cable :)
Eelis
Drives: Polo White 1.0 TSI 110hp Allstar edition
Post by Eelis »
Can you enlighten a bit how you did it? Maybe a picture?
-eelis-
Bigtam
Post by Bigtam »
MczZippy wrote:Sorted, managed fit without removing panels and hidden cable :)
Probably pulled the rubber off and tucked it into the plastic pillar trim
6RPotentialBuyer
I've just done a quick DIY guide on how I did mine. It's a bit late at night so the pictures are a bit crap. Hopefully it makes sense :)
viewtopic.php?f=10&t=69137
MczZippy
Post by MczZippy »
ah yes! thats where i ran mine, except i put the cable through a different hole in the fuse box :)
