rear light fault, earth?
andy198712
Drives: '72 Beetle
Post by andy198712 »
i'm getting a 2002 1.4 polo ready for MOT
when i press the brake the warning light on the dash for the rear fog glows....
i noticed someone has added an extra earth cable from the orange bulb (literally wedged down the side of it) to the brown wire an inch after the plug.... which sent off alarm bells. (passenger side)
is this a common issue?
plan of action is unplug the light and see if it does it, then try the other side, test again.
then remove bulbs and test both sides like that.
any tips or people had this before?
i followed the cable loom back 12 inches where there is a few plugs and they look a tad green in places! earth looked okay though.
i haven't fully tested all the bulbs yet which will be one to try, but can't see it causing this issue surely?
Andy
andy198712
Drives: '72 Beetle
Re: rear light fault, earth?
so now when i go to indicate left, the light on the dash goes fast (blown bulb) but none of the 3 indicators on the left hand side work? don't work for hazards either.... thoughts?
Andy
The first thing that I would do would be to make sure that the metalwork on the part that the bulbs are located is still usable - ie no rusting. After that you should run a length of wire down from the front of the car, from a suitable earth point, to the earth point of that cluster and solder it on if possible, then see if everything works okay, if so try to find a suitable body earth point near the rear of the car and run that wire now from the cluster to that earth point.
Edit:- maybe after everything is back working okay, you could tidy things up by identifying the incoming earth wire to that cluster, unwrap a length of the cable, remove some of that wire's insulation, and wrap round then solder the new earth wire to that wire, then wrap the repair with insulating tape and then rewrap the cable with cable harness wrapping tape.
Another Edit:- you will also need to use a voltmeter to check what is happening as I've just remembered that you said the left side does now not work at all, I'd think that you have caused a short circuit to earth at that rear cluster, ie indicator 12 volts to earth short?
andy198712
Drives: '72 Beetle
i'll get probing tomorrow with them on and see if they are getting a 12v intermittently (flash) then i can narrow it down to earth... odd how its the whole left side? the indicator light on the dash still works but just flashes fast, as if a bulb is out.
thanks for the ideas, I'm pretty sure that rear cluster has a body earth near it... which looks clean but will inspect!
andy198712
Drives: '72 Beetle
One point, and I discovered this obvious point many years ago, beware of high resistance in the supply wires or earths! I found this out on an old Fiesta, I measured the 12 volts supply to the rear wiper with the wiper unplugged, it read 12 volts so okay - no, the wire was almost completely cut through and when loaded with the wiper motor, the voltage at that motor was almost nothing! Just something to bear in mind when working with car supplies.
andy198712
Drives: '72 Beetle
Well,
Turned out to be rear left light, i replaced the light with a good used one and all was fixed! i checked the earths and they were okay too.
there is a rear washer pipe union right above some pipes that was apart also which wouldn't of helped matters! plenty of contact cleaner in those plugs too, but glad its better!
Yes, on an older car you need to check all these pipe joining points, also always use a additive in the washer fluid to avoid the water "firming up" in colder weather - which is the root cause of these pipe joints separating/leaking. I have looked after a 2000 VW Passat for 13 years and a 2002 Polo for 13 years with no parting pipes issues - in an area with very low for UK temperatures.
andy198712
Drives: '72 Beetle
yeah i agree, Quantum premium is extremely cheap for VW i just found out! so going to be using that across the board from now on i think!
