ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
LOL why not
It will be installed on my 6R at my VW dealer, within a month, I guess.
[emoji23]if it doesn't work.... get rid and buy a new one to make it work, I like it Fernando [emoji106]
Ciclo can you tell me something about what I wrote to you before?
edinogti wrote: ↑Tue Sep 12, 2017 12:51 pm hello ciclo
then I'll tell you what I would do
In practice I mounted pneumatic suspension with electronic management
I would like to make sure that once I close the car with the remote control the car will lower itself
for this I have already resolved by purchasing a timed relay card, which I have already tested and works perfectly
my problem is this
the impulse that I should give to my timed card I should take it only at the time of closing the machine
the problem is that in the wiring harness of the door lock if I receive the pulse from the closing wire the current arrives either with the open key or with the close button on the remote control you understand?
I would like to see if there is a single signal somewhere that will either turn on or off only when the car is closed
understand ciclo?
I explain you:
I used the signal of the T28a/22 wire that I told you earlier to close the folding mirrors when close the car with the remote control (for my NO OEM installation of folding mirrors), everything worked correctly because the/my external module managed both signals. (Opening and closing).
I don't know if there is another signal in electrical system that be useful for what you want to achieve.
(I'm guilty)
If I had purchased the TPMS unit with the older software (B,D) the cost would have been similar, so I chose to buy a IC with MFA+ (brand new) with the software updated.
I do not know if the TPMS units I already have (3AA... F and H) will work with this new IC, ...in rdasadia's 6R it works correctly.
...at least I will have the software updated on both units (IC, TPMS)...
ciclo wrote: ↑Wed Sep 13, 2017 9:25 amedinogti wrote: ↑Tue Sep 12, 2017 12:51 pm hello ciclo
my problem is this
understand ciclo?I explain you:
in fact with that module I could solve the problem. Where can I recover that form?
I do not understand correctly what you mean.
Hmm ...
viewtopic.php?f=56&t=58703&start=75#p472068
... in case it is useful for you.
ciclo wrote: ↑Wed Sep 13, 2017 7:21 pmI do not understand correctly what you mean.
Hmm ...
no excuse I wanted to tell where I can buy this form?
