Hi Ciclo,
I've tested the codes.
For each of them:
I cleared all DTCs.
Entered BCM coding.
Performed autoscan.
Activated high beam.
1st
3CB02BBF08A1000008380C916C2B0CD05AC0470F60051040200000030000
Tuesday,24,October,2017,22:44:13:27502
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116 License Plate: 15TH SCAN-1ST TEST
Mileage: 100380km-62373mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 56 0B
VIN: WVWZZZ6RZBY312116 Mileage: 100380km-62373miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71E99E02A0C274CE75-8024
Readiness: 0000 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230248E3416E02B4C42612E382D740811700
Shop #: WSC 00788 648 00255
VCID: 071DD0DAB2465A7ECB-8052
Part No SW: 6R0 907 044 E HW: 6R0 907 044 E
Component: Climatronic H09 0609
Revision: V0000000
VCID: 35616A129C2A18EE69-8060
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 321160318
Coding: 3CB02BBF08A1000008380C916C2B0CD05AC0470F60051040200000030000
VCID: 2A5B496E45944716F4-807E
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1611
Serial number: KU0KU024031100012688
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 007 1611
Serial number: KU0KU016031100015781
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 591 A HW: 7P0 959 591
Component: J245 PS72.015 H05 0006
Serial number: WOO1165901/
Coding: 081001
Subsystem 4 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0050759
Coding: 830000
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Serial number: KU0KU011041100017315
Coding: 08BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 007 1611
Serial number: KU0KU011041100013053
Coding: 08BC32
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag01E H09 0020
Revision: -------- Serial number: 003GZ000HCNK
Coding: 003145
VCID: 4C972FF6E7A0792626-8018
Serial number: 3575HRB40550HJHG9ON%
Serial number: 3585HRB40590HJHG919A
Serial number: 3515RRB405B0I4AG6OGL
Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H21 0320
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 72EB910EA5C44FD68C-8026
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 002300
VCID: 68DFF3669B18B50622-803C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 10
Mileage: 100245 km
Time Indication: 0
Date: 2012.03.13
Time: 23:57:39
Component: IMMO H21 0320
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB896E8D14871634-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 31414
VCID: 2F6D587AEA76223E23-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0114000001000000
VCID: 77FDA01ACEA62AFEBB-8022
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:02)--------------------------
2nd
3CB02BBF08A1000008380C916C2B0CD0DAC0470F60051040200000030000
Tuesday,24,October,2017,22:50:31:27502
www.Ross-Tech.com
Cannot be reached
Revision: --------
Revision: V0000000
Coding: 3CB02BBF08A1000008380C916C2B0CD0DAC0470F60051040200000030000
Coding: 18BC30
Coding: 08BC30
Coding: 081001
Coding: 830000
Coding: 08BC32
Coding: 08BC32
Coding: 003145
Coding: 140A00
Revision: B9081001
Coding: 002300
1 Fault Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 10
Mileage: 100245 km
Time Indication: 0
Date: 2012.03.13
Time: 23:57:39
Serial number:
Coding: 11221
Shop #: WSC 31414
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:59)--------------------------
3rd
3CB02BBF08A1000008380C916C2B0CD0D2C0470F60051040200000030000
Tuesday,24,October,2017,22:56:50:27502
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116 License Plate: 17TH SCAN-3RD TEST
Cannot be reached
Revision: --------
Revision: V0000000
Coding: 3CB02BBF08A1000008380C916C2B0CD0D2C0470F60051040200000030000
Coding: 18BC30
Coding: 08BC30
Coding: 081001
Coding: 830000
Coding: 08BC32
Coding: 08BC32
Coding: 003145
Coding: 140A00
Revision: B9081001
Coding: 002300
1 Fault Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 10
Mileage: 100245 km
Time Indication: 0
Date: 2012.03.13
Time: 23:57:39
Serial number:
Coding: 11221
Shop #: WSC 31414
Address 56: Radio
Cannot be reached
All of your 3 test codes seem to have solved the high beam bulb error.
Then I reverted to the original coding: 3CB02BBF08A1000008380C916C2B0CD05AC0670F60051040200000030000
Error came back instantly.
Currently I'm on the 1st test code.
Thank you for your help!
