Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
- Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Fitting test and wired through T73a/65 and door lock ground.
So far so good. Working on the special bracket now.
Thanks master ciclo and iichel.
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
And....do you can show how? Do you have any link?benzinkopf wrote:Old cluster - Modified EEPROM for staging active
[youtube]https://youtu.be/ge5pS7vFhCY[/youtube]
Here re the post from one of the great member here FiregrafikUgabista wrote:And....do you can show how? Do you have any link?benzinkopf wrote:Old cluster - Modified EEPROM for staging active
https://www.drive2.ru/l/7949101/
https://www.drive2.ru/l/8082062/
- Ugabista
Thanks [emoji108][emoji106]
Good job!benzinkopf wrote: ↑Fri Nov 17, 2017 1:43 pm IMG]https://uploads.tapatalk-cdn.com/201711 ... 273abb.jpg[/IMG
Thanks master ciclo
The previous info:
viewtopic.php?f=56&t=58703&p=527095#p527085
viewtopic.php?f=56&t=58703&start=3780#p526561
The best part: Stupidly i thought there is no connector between the door and below A pillar [emoji17]. Lucky there is enough room for one wire to pass through temporarily. Now need to find the both female/male pins to go through this connector.
ciclo wrote: ↑Fri Nov 17, 2017 7:00 pmGood job!benzinkopf wrote: ↑Fri Nov 17, 2017 1:43 pm IMG]https://uploads.tapatalk-cdn.com/201711 ... 273abb.jpg[/IMG
Thanks master ciclo
The previous info:
ciclo wrote: ↑Thu Nov 16, 2017 8:07 am Read at the end of this post:
viewtopic.php?f=56&t=58703&start=60#p470545
Note: The sun visors of courtesy mirrors have their own switch.
Thank you Ciclo. I'm totally amaze how to systematically manage the posting. incredible!
Noted Ciclo. From the document, I see more terminal listing for 1K0 937 702 C from 0.5 - 2.5 wires but for the counter connector 1K0 937 722 D, there re only 1.0-2.5 wires types. I think I shud be using 0.5 for door exit/warning lights and side mirror puddle light, is that right?
If I'm reading the document correctly, should I go for 000979150E <----> 000979132E ?
Choose according to your criteria to use the empty slots in the T28 connector.
MCP 1,5 or MCP 2,8 (male and female)
https://www.a4-freunde.com/showwiki.php ... uebersicht
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Looks clean and nice.benzinkopf wrote: ↑Fri Nov 17, 2017 1:43 pm
May be share photos of the bottom of door, where you have fitted the light assembly.
sure. but im working on the bracket. will share once that one ready. the photo above is to test fit the light module at the edge of the door panel and to see the projection image clarity as it is depending on the installed height.ag69 wrote:Looks clean and nice.benzinkopf wrote: ↑Fri Nov 17, 2017 1:43 pm
my custom bracket for door exit/warning light mounting. There’s some little tweaking needed for the 3Dprinted bracket still but I’m happy with the position and mounting.
But i do think its not really a good “warning” light as there’s quite a distance from actual door edge, but the position is the best due to polo door panel design.
I’m waiting for the type without the projector. With this projector logo, its not really light up the area but as showoff instead. So better with the white light model. plus that one dont have heatsink needed like the one with projector.
- ag69
great!!!
really appreciate your hard work.
waiting for the FINAL your dream fittings.
haha. thank you. but dont wait. im not working on it until i get the next light type and terminal/pins for the T28 door connector.ag69 wrote:great!!!
