Any electric cable ?
Tapatalk kullanarak iPhone aracılığıyla gönderildi
Racechip Install
- Drives: 6C GTI
- Drives: BlueGT
- Drives: 6C GTI
Re: Racechip Install
No nothing to connect to battery
- Drives: BlueGT
Ok I'm looking still
- Drives: BlueGT
- Drives: 6C GTI
Thank you
Have you tried contacting racechip maybe?
- Drives: Polo Blue GT
Racechip are very helpful, they will advise upon suitability, convertibility and installation. If you need a different harness they will supply.
Great company to deal with.
Hi
To fit second connector you need to remove the engine undertray and then you will find the boost connector you need to connect to.
It's an awkward one to remove as there is an Air con pipe right in front of it.
Took me a bit of time to get it off, but once done the racechip on their supplied settings really transforms the car, makes it much sharper and more eager than factory.
Make sure when you tie wrap the racechip cables that you route them away from the radiator fans which are unshrouded and therefore you need to be careful.
