No there are 4 connectorsiichel wrote:you don't, it's the same connector.
1 for H4 halogen
2 for parking lights
3 for indicators
4 for headlight range motor
Sent from my Pixel 2 using Tapatalk
H7 has 10 pin connectoriichel wrote:Yes. But the same connector is fitted with the same pin layout on the H7 and H4 headlights.
smg_shardul wrote:Fri Jan 12, 2018 3:34 am Hi ciclo how r u?
I want to know how to install H7 twin barrel headlight to H4 setup
H4 has 4 different wires to connect and H7 have single 10 pin connector
Now I got 10 pin connector for H7 headlight I will insert all wires from 4 connectors of H4 headlights as per the below pic
Now my question is in H4 setup only one beam either high or low will work at a time and in H7 when full beam both high and low bulbs works together
Any solution for this ?
Best Regards
Shardul
ciclo wrote: ↑Fri Jan 12, 2018 6:48 pm In the back side of relay holder. YOU should know where is the J331 relay.
You have to remove the BCM to be able to extract the relay holder, once the relay holder is removed from the relay carrier, you have to slightly extract the terminal locking mechanism and then remove the terminal with the tool.
Estimated time to do this work, about 5-10 min max, but I guess it will take you a couple of hours.
Ok thank u...ciclo wrote:The simplest thing is always the best. You do not have to do anything else.
1 wire added as per you guidance and headlights are working perfectly...ciclo wrote:The end result should be 100% perfect...
Yes I took I will edit and upload here tomorrow...ciclo wrote:Thanks for letting us know.
Did you take pictures of the process?
