for example...hmm... hereAdam87 wrote: Tue Jan 16, 2018 10:18 pm @Ciclo
Sorry I couldn’t find the post (I think it was in your build thread) where you explained about WRM needing to be SW 8xxx for folding mirror, yes this is correct as a minimum but, I have found one exception to this rule, the T5 ‘K’ revision WRM has the exact same SW & HW number as my WRM but it is missing 3 pins and once opened it is possible to see all the components that are missing
‘K’ revision with missing components
https://uploads.tapatalk-cdn.com/201801 ... 88ea35.jpg
‘L’ revision with marked components
https://uploads.tapatalk-cdn.com/201801 ... 670ca0.jpg https://uploads.tapatalk-cdn.com/201801 ... f893cb.jpg
Maybe not very expensive to add most of the components, except for the PWM driver for the mirrors which also needs the SW copying from the L module
Maybe it's another possibility, although somewhat cumbersome for most. I like all the researches you do... you rock!
Looks perfect all the improvements you've made, but especially the LED license plate lights ... and ... something that can hardly be seen in one of the images ... you're a bad boy.
