[HELP] POLO 6C AIRBOX REMOVAL [2015 TSI]
nzr
- Drives: 2015 Polo [6R] | 1.2 TSI
Can anyone give a video or a GOOD diagram how to do so? It seems to difficult to do so I think im missing something, after taking the 2 clips off and both hoses off, then the air hose, how do i take the housing off?
Re: [HELP] POLO 6C AIRBOX REMOVAL [2015 TSI]
Hello, if you are talking about the 1.0 tsi engine it's actually pretty simple. You'll need a set of torx keys. Here is an aftermarket intake from forge, if you scroll down a bit an click on the "fitting guide" tab there is .pdf file that explains how to remove the factory box. https://www.forgemotorsport.co.uk/VW_Po ... -1610.html
Try use the "search" function as that question was been asked on this forum already (in the past).
https://www.forgemotorsport.co.uk/?download_id=206 same guide but for a 2015> 1.2TSI engine.
