ciclo wrote: Sat Mar 24, 2018 8:05 pm
Byte17 Bit0 enabled, activates the indirect TPMS in modules ESP9.0i front H03 0003 , yours is ESP9.0i front H03 0001.
F1DC948D212313C68F1B29698458C8400901
Try it. (with the right parts installed)
Tried it, no success
Forget the battery module if you don't have it installed in you Suran.
This module doesn´t show as installed, but is accessible.
VCDS Release 17.8.0 Select Control Module2.jpg (5.84 KiB) Viewed 4508 times
Also, what I told you before, I don´t understand why these modules shows as installed but they aren´t accessible:
EdgardoRodriguez wrote: Sat Mar 24, 2018 9:37 pm
Menu options "comfort" and "luces y visib." Where enabled by me
Please, enlighten us. How did you do it?
However, your instrument cluster is very different from ours. (wires assignment in T32 connector, software, etc)
Thanks for the pictures, nice interior.
The checking I wanted to do cannot be seen in the images, I wanted to see the buttons on the Right Stalk/lever. (it's my luck in these things)
I didn't say what I wanted to check so as not to alter the result and other reasons.
VCDS Release 17.8.0 61-Battery Regul., Open Controller (1K0-907-534.CLB).jpg
Have you checked that the indirect TPMS is available in the IC coding?
About what is accessible or not, or what is shown or not shown I will explain it to you by email, not all diagnostic tool and versions (origin ) work in the same way.
Clear like the water.
By changing an adaptation channel: Address 17,5Z0 920 865 A,channel IDE09551-Car menu source,adapted from,Version 2 ,to,Version 1 ,Wednesday,03,January,2018,16:34:25:00001
ciclo wrote: Sun Mar 25, 2018 6:53 am
Don't know what is IC coding???
Later de detailed stalks pictures
IC coding = the coding of your instrument cluster. On most PQ25 clusters, it's byte 2 bit 0 -> set to 1 for indirect TPMS warning in the instrument cluster.
iichel wrote: Sun Mar 25, 2018 1:26 pm
Thanks iichel for the heads up!! I´ll try it later! Most coding I've tried in my IC says "Coding rejected, request out of range" but perhaps, this one works!
I am curious is there possible to XDS activite.
Please try this variants
F1DC948D212313C68F1B29698458C8400904
F1DC948D212313C68F1B29698458C840090C
also lets try is it is possible to set the ESPoff button to deactivite the ESC fully, not only ASR
F1DC948D212313C68F1B29698458C8401500
like this
like this
firegrafik wrote: Sun Mar 25, 2018 1:45 pm
Hi! What is this about firegrafik?
Do you have any posible code for trying indirect TPMS ??
Found this on a russian page:
Вот для примера лог кодировки блока 03, идущего на поло с завода:
Адрес 03: Электроника тормозной системы (J104) Label: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Компонент: ESP9.0i front H03 0001
Серийный номер: --------------
Кодировка: 51DD4864422707C48A19126A4251E041090C
Мастерская #: WSC 01530 935 00200
VCID: 0B1E5B35A26D8F1822-805E
The guy states that has indirect TPMS working. Which shows the firmware? the first highligthed "Part No SW" or "Component" section?
My ABS module shares HW and Component parts, but Part No SW: 5Z0 907 379 K
I feel confused
I feel confused
I suppose it is firmware limitations. the software 5Z0907379K doesn't allow the RKA (indirect TPMS))coding. Because of this I asked to try
F1DC948D212313C68F1B29698458C840090C[/size
To clarify if there some more limitations of your ESP control unit firmware.
I feel confused
OK,
missed that part. Later today I´ll give it a shot and then tell you.
In case I am limited by software, is there any possible way to flash another one? Knowing that i am not a VW Technician unfortunatelly (no access to those tools)
