Hi there!
Perhaps some expert here can help me. Done a mistake (cluster swap - different VIN) and ABS recoded itself to zeros
Well, I was just testing so I have my original IC and everything is fine, except G85 which I can not calibrate
Actual coding of ABS module is EXACTLY the same as factory, cause I have several backups I can confirm it.
ESP and "steering wheel" indicators are on while ignition on, and also a "ESC malfunction" error pops up in IC.
This is the autoscan:
Saturday,14,April,2018,20:38:20:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: License Plate:
Mileage: 40337 Repair Order:
Chassis Type: 5Z-VW21 (6N0)
Scan: 01 02 03 04 09 10 15 17 19 25 44 56 0B
VIN:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWSA) Labels: None
Part No SW: 04E 906 032 G HW: 04E 907 425 A
Component: 1.6l R4 MPI H07 2706
Revision: --H07---
Coding: 00140012022400000000
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ECM16MPI02104E906032G 001007
ROD: EV_ECM16MPI02104E906032G.rod
VCID: 2446D40C2FDBFE66CE-8070
Readiness: 1010 0001
Address 02: Auto Trans Labels: None
Part No SW: 0C3 927 735 G HW:
Component: MARELLI C348V SQ200 1504
Revision: --H02--- Serial number: BPLNF8S6P
Coding: 0000025
Shop #: WSC 00000 000 00000
VCID: 2E523624B917443628-807A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Z0 907 379 K HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: F1DC948D212313C68F1B29698458C8401500
VCID: 4D9051A81CD11F2E31-8018
1 Fault Found:
0993 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 40337 km
Date: 2035.14.17
Time: 04:15:26
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 0671 338141906
Coding: 3BA98B384C3BC600113A06C06CC89A81B188629D608C2059240580020000
Shop #: WSC 79157 025 435844
VCID: 2F6C2B207E1D4D3E23-807A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150914 05 54 0403
Coding: 0530AD
Subsystem 2 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
Component: ZFH_4T H08 0015
Serial number: 3982FL00001410090213
Coding: 006B54
Subsystem 3 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
Coding: 006B54
Subsystem 4 - Part No: 5Z0 947 105 F
Component: DWA-Sensor 00 003 0008
Subsystem 5 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H01 0103
Serial number: 27140002040360104334
Coding: A5FFFF
Subsystem 6 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
Coding: 006B54
Subsystem 7 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
Coding: 006B54
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5Z0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0002
Revision: -------- Serial number: 67781426000519
Coding: 100003
Shop #: WSC 00001 001 00001
ASAM Dataset: EV_EPHVA18VW23X0000 001002
ROD: EV_EPHVA18VW23X0000_VW21.rod
VCID: 43847790CA95D95ED7-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 5Z0 959 655 A HW: 5Z0 959 655
Component: VW10AirbagZZX H02 0216
Revision: -------- Serial number: 003NC305ZGS$
Coding: 000000000000000000000000000000005A58
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 479C6380FEADF57E0B-8012
Address 17: Instruments (J285) Labels:* 5Zx-920-xxx-17.lbl
Part No SW: 5Z0 920 865 A HW: 5Z0 920 865 A
Component: KOMBI H07 0010
Coding: 860A22
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 3E720664A177B4B6B8-806A
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 002200
VCID: 70EEE85CA3A312C67A-8024
Address 25: Immobilizer (J334) Labels:* None
Component: IMMO H07 0010
Serial number:
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 5Z1 909 144 D HW: 5Z1 909 144
Component: EPS_ECU 401 4040
Coding: 004F
ASAM Dataset: EV_SteerAssisNSKGen2 005107
ROD: EV_SteerAssisNSKGen2_005.rod
VCID: 3F8C7B60A67DBDBEB3-806A
2 Faults Found:
0054 - Steering angle sensor
Fault Priority: 2
Fault Frequency: 1
Mileage: 40337 km
Date: 2035.14.17
Time: 04:15:26
Single Additional Freeze Frame:
0047 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Fault Priority: 4
Fault Frequency: 1
Mileage: 40337 km
Date: 2035.14.17
Time: 04:15:26
Address 56: Radio (J503) Labels: None
Part No SW: 5Z0 035 160 A HW: 5Z0 035 160 A
Component: MIBGLAM H11 0039
Revision: RB101000 Serial number: VWZ7Z2R3032201
Coding: 00000400020000
End-------------------------(Elapsed Time: 03:08)--------------------------
Tried so many procedures here that I am lost
What´s more concerning to me is the following:
Please consider that VCDS isn´t "recommending" in a popup any security code, so I am using the wide spread 40168 one, which is actually accepted
This is done in ABS 03 module - Security access - then Basic Settings
If I do not enter the code, this basic setting shows "ERROR: Security access required".
Tried while driving and still and the same.
Can some one help?
