[ORiOn] VW Polo 6R BlueGT
ORiOn
Drives: Polo BlueGT / Audi S5
Re: [ORiOn] VW Polo 6R BlueGT
Post by ORiOn »
Prototyping :D :P
Keep us informed. 8)
I think I'll do it in another way, but I still have to study it ..
ORiOn
Post by ORiOn »
ciclo wrote: Thu Apr 19, 2018 7:01 am Keep us informed. 8)
I want it to look as oem as possible, and in metal and oval like the one you showed in your topic, looks a bit "tuning" for my taste :P
If you ever need a prototype tester .. :-)
ORiOn
Post by ORiOn »
iichel wrote: Thu Apr 19, 2018 7:30 pm If you ever need a prototype tester .. :-)
I first need to design them better, which isn't easy when you are just starting at 3D design haha :P
"hand made in Switzerland" :mrgreen: :mrgreen:
ORiOn
Post by ORiOn »
But not quite the "schweizer qualitat"... :lol:
ORiOn
Post by ORiOn »
Does anybody know the fuse for the heated side view mirrors? 🤔
ORiOn
Post by ORiOn »
I just checked continuity on all of them, and they all work... F*ck... :(
ORiOn wrote: Thu Apr 19, 2018 7:25 pm
My way to do it is as close to OEM as possible and super high quality (similar to the front tweeters). I assure you, the appearance is impressive, but the best is where they are located.
Logically everything is improvable, ... please, surprise us with your way to do it. I'll tell you all the mistakes you've made with your way to do it. :mrgreen:
Remember that the materials must be adequate so that they don't fail with the passage of time and car's movements. :lol:
ORiOn wrote: Wed Jun 13, 2018 9:07 pm I just checked continuity on all of them, and they all work... F*ck... :(
And ... what's the problem?
Hmm... the heated side mirrors function is controlled by the BCM once it is activated by the switch or BCM coding.
ORiOn
Post by ORiOn »
ciclo wrote: Thu Jun 14, 2018 6:41 am
Well, since it's not the fuses, I have no idea why they don't work... :(
Post your current BCM coding.
ORiOn
Post by ORiOn »
ciclo wrote: Thu Jun 14, 2018 6:57 pm Post your current BCM coding.
Let's hope it's something in the coding... :|
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 55 56 61 77 0B
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CPTA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 Q    HW: 04E 907 309 D
   Component: 1,4l R4 TSI   X08 5763
   Revision: WCX08---    Serial number:
   Coding: 00190032242401000000
   Shop #: WSC 92521 052 12345
   ASAM Dataset: EV_ECM14TFS01104E906016Q 002009
   ROD: EV_ECM14TFS01104E906016DL.rod
   VCID: 3068DC8B6B27B2C20C-8064
Readiness: 0110 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H01 0002
   Serial number: --------------
   Coding: 21DD4885232600C984141272C45200550905
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F2A7F77D6598D3A35-805A
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LJR0002L
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF432B3E1F394B2CE-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3878E4AB8B576A8244-806C
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090     HW: 7H0 937 090
   Component: BCM PQ25 Max4 H72 0708
   Revision: B9072001    Serial number: 0531 313120016
   Coding: 64B029B84821000021280F117EEB9FD90AC1672F7E0D70C1200000030000
   Shop #: WSC 00788 648 00255
   VCID: 6BD20BE78A81111A79-803E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 221012 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1621
   Serial number: KU0KU009101200010457
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1621
   Serial number: KU0KU010101200012525
   Coding: 58BC30
   Subsystem 4 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0300853
   Coding: 820000
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361229300488
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E74F2B3A17354B28E-806A
   Component: VW10Airbag01S H10 0020
   Revision: --------    Serial number: 003GX01G87NL
   Coding: 003153
   VCID: 4A9CAE63EDBBE81222-801E
   Serial number: 3575HRB405L1KR0EG0P-
   Serial number: 3585HRB40571KAE8B15X
   Serial number: 3515RRB400K4UOFEI8RS
   Serial number: 3525RRB400G4UOFEQ1SR
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   VCID: 3566ED9F944597EA5F-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H72 0708
   Revision: B9072001
   Coding: 002034
   VCID: 70E81C8BA3A7F2C24C-8024
   Component: IMMO          H05 0607
   Serial number:
   VCID: 6ADC0EE38D7B081202-803E
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0546
   Revision: A1001003    Serial number: 7663790475
   Coding: 020100
   VCID: 2A5CCEE345FBC812C2-807E
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C8 035 279     HW: 3C8 035 279
   Component: RNS315-EU   H59 0319
   Serial number: VWZAZ2M5536049
   Coding: 040004710200010000008000
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 68D874EB93773A0214-803C
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V9  0069
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11221
   Shop #: WSC 00788
   VCID: 3068DC8BF727B2C20C-8064
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 019A000001000000
   VCID: 77FA2797CEC9A5FA8D-8022
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H72 0708
   Coding: 032F7A64
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970261222
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105120668
   Coding: 060000010100010000000101
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002.rod
   VCID: 244020DB2FDF1E62F8-8070
Well, you have the BCM Byte15 Bit3 enabled ... Mirror Heating ON while Rear Window Heater ON.
Your BCM coding
Disable it and test the heated side mirrors function with the mirrors switch.
If they doesn't work: ( :shock: .. :lol: )
Enable the BCM Byte15 Bit3 again.
Push the rear window heater button on the dash -yellow light ON-, if the side mirrors heating works as the same time and with the mirror switch any other position different to heat, the problem is in the mirror switch.
Make the tests with the engine ON.
Good luck!
Additional info :arrow: http://www.vwpolo.net/exterior_mirrors-148.html
