RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
That is indeed the correct one, a Junior Power Timer for SB10.
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
iichel wrote: Fri Jun 22, 2018 8:58 am That is indeed the correct one, a Junior Power Timer for SB10.
Thanks iichel for reply...
smg_shardul
Drives: Polo 6R
smg_shardul wrote: Fri Oct 27, 2017 2:29 pm sorry was really busy in work couldn't find time
here is the scanned report
i am unable to edit code so some codes are still not changed
Friday,27,October,2017,18:35:04:39744
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: MEXA16608GT067313 License Plate: ,MH9SHARDUL
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 0B
Address 01: Engine (J623-CWXB) Labels: None
Part No SW: 03L 906 023 SN HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number:
Coding: 00250116032500080000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TDI20103L906023SN 001001
ROD: N/A
VCID: 040057528F805F66AE-8050
No ASAM data for: "EV_ECM15TDI20103L906023SN" (VW25)
Readiness: 0 0 0 0 0
Part No SW: 0AM 300 065 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501510066015
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3878F3A24BC8CB8672-806C
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63422907C74617346A4254E0820908
Shop #: WSC 28939 002 1048576
ASAM Dataset: EV_Brake1ES9P0iBOSCH 003031
ROD: N/A
VCID: 0B127C6EA2DE101EEF-805E
No ASAM data for: "EV_Brake1ES9P0iBOSCH" (VW25)
1 Fault Found
0931 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Date: 2019.14.15
Time: 18:24:23
Address 04: Steering Angle (G085) Labels:* None
Serial number: 26071513471359
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EF425BAE16C35B6F8-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418E9E46D8128A4EC5-8014
1 Fault Found
00457 - Control Module for Network (J519)
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:31:40
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171271
Coding: 3A904BBF48E10200013807916CCB96905A88676F600D30C1200000030000
VCID: 2B52DCEE4A9E701E0F-807E
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 080617 04 42 0106
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC
Component: ------------- 007 5521
Serial number: 13102670151005153008
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT
Serial number: 13202671151005132525
Coding: 050000
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 2991519341401746AJ2B
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5520
Serial number: 13202580151005230949
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150929004312
Coding: 020000
2 Faults Found
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:39
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:31:42
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 300104
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_VW75XAprkAssis8K 001003
ROD: N/A
VCID: 397EF6A6B8C2D28E8D-806C
No ASAM data for: "EV_VW75XAprkAssis8K" (VW25)
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0121NNF
Coding: 003036
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
ROD: N/A
VCID: 499E8666E822420E1D-801C
No ASAM data for: "EV_AirbaVW01BPAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 2H0 920 871 B HW: 2H0 920 871 B
Component: KOMBI H04 1009
Coding: 140A080000
Shop #: WSC 13202 938 12345
ASAM Dataset: EV_Kombi_UDS_VD_DRM09 A05730
ROD: N/A
VCID: 275A20DE5E76547EEB-8072
No ASAM data for: "EV_Kombi_UDS_VD_DRM09" (VW36 *)
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 102300
VCID: 68D863E29BE89B0622-803C
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H04 1009
ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03710
ROD: N/A
VCID: 6ADC19EA8DE4A91634-803E
No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels:. 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ASAM Dataset: EV_SteerAsssiNSK 014008
ROD: N/A
VCID: 418E9E46D0128A4EC5-8014
No ASAM data for: "EV_SteerAsssiNSK" (VW25)
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 02425GD0000489
Coding: 0000044004000A
Shop #: WSC 00081 790 00133
VCID: 45868A56CC3AA66EF9-8010
3 Faults Found
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:08
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:08
00874 - Treble Speaker Front Left (R20)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 47
Mileage: 32861 km
Time Indication: 0
Date: 2019.14.15
Time: 18:26:08
End-------------------------(Elapsed Time: 02:55)--------------------------
This is my scan report ciclo I did post my scan report
And where did I lie in this ?
And about camera flickering I already informed you earlier you can check my topic
Rear fog light I got to know now as I told you I never use it.
I never blame you for your BCM Adaption wires and autolights support I just told you what I observed if you can help here that's ok if not then also it's ok as I never use it
Very easy, you have to post a RECENT autoscan (not from October 27 of last year :lol: ) every time you request my help. I'm not a fortune-teller to know all the changes you've made to your Vento in any time interval* since the last known autoscan.
*Time interval can be from the first second to infinity and beyond... :lol:
As I said you never posted an autoscan with all my wiring installed, I never knew for sure that all the electrical installation in your car worked perfectly.
I would have such autoscan documented in the folder dedicated to your Vento (folder with the only intention to help you in the future... FREE ... as usual... :wink: )
Therefore, you lie.
Do not give much importance to this, everybody lies... (makes existence possible :lol:).
Apart:
The strange behavior of the rear fog lamp only in light switch parking position.
Was the installation of the instrument cluster from the AMAROK carried out at an official VW dealer?
If not, how was it done? Software? Method?
Where did the information come from to later edit the EEPROM? Assuming you were not wrong with some 'Bits' when editing.
Was it the same procedure for seeramkumars cluster?
Related info:
- https://uk-polos.net/viewtopic.php?f=56 ... om#p527802
- https://uk-polos.net/viewtopic.php?f=56 ... om#p536827
- https://uk-polos.net/viewtopic.php?f=56&t=71394#p534976
The more you lie :lol: about these questions the less likely there is to solve this strange behavior of the rear fog light that is not related at all to my wiring, coding or technical support (i insist :lol: .... FREE ... since many years).
smg_shardul
Drives: Polo 6R
ciclo wrote: Fri Aug 03, 2018 4:16 am Very easy, you have to post a RECENT autoscan (not from October 27 of last year :lol: ) every time you request my help. I'm not a fortune-teller to know all the changes you've made to your Vento in any time interval* since the last known autoscan.
Therefore, you lie.
Apart:
Related info:
That is the latest scan ciclo I have just swapped cluster that's it , I have not changed any of the coding
Installation of Amarok cluster was done at VW service centre but i don't know whether rear fog light was working or not.
Few months back I have installed Seat Toledo cluster it was installed by using software Super vag.
I got information of eeprom from madwarlock & firegraphics I have changed only required bits I can check in other vehicle to confirm as Amarok cluster is not in car.
I don't know which cluster seeramkumar is using
What common thing I found is my and his car is dsg and vento2013 s car is manual his rear fog light is working perfectly.
I think it's coding issue only
Right now my vcds cord is not working I will try once or I have ordered the cord I will get it in 2 weeks I will upload latest scan
smg_shardul
Drives: Polo 6R
AFS Kit ready
Waiting for level sensor bracket
Thanks a lot Firegraphics for your guidance
Thanks a lot ciclo for parametizing AFS module without this project was incomplete
Thanks a lot Madwarlock for AFS Module
OK...
DSG or manual transmission is not related to the rear fog light.
It would be the case if we were talking about the reversing light, but it is not.
- The rear fog light wouldn't work with the light switch in headlights position in case it was a common BCM coding issue.
However, we will try something unusual with the BCM coding when you have your VCDS cable in your hands.
Greetings until then.
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
Which slot in fuse box should i use for AFS For polo 6r??
smg_shardul
Drives: Polo 6R
hmthakur wrote: Thu Aug 16, 2018 6:54 pm Which slot in fuse box should i use for AFS For polo 6r??
SB10
Any slot with terminal 15
It requires 5A fuse
hmthakur
Post by hmthakur »
Which is positive and negative in fuse box upper line or lower??
smg_shardul
Drives: Polo 6R
hmthakur wrote: Thu Aug 16, 2018 7:40 pm Which is positive and negative in fuse box upper line or lower??
You will get only positive in fuse box.
For negative you need to search ground point and take connection from there .
Fuse box has only input and output
A is input
B is output
hmthakur
Post by hmthakur »
So in case of AFS is it input or output and SB 10 slot fuse is already installed
smg_shardul
Drives: Polo 6R
hmthakur wrote: Thu Aug 16, 2018 7:49 pm So in case of AFS is it input or output and SB 10 slot fuse is already installed
Input of terminal 15 is already there
You just need to take output and insert fuse
In your case you can use SB15.
You better get installation done from a professional installer or a good local mechanic.
hmthakur
Post by hmthakur »
smg_shardul
Drives: Polo 6R
ciclo wrote: Fri Aug 03, 2018 7:57 am OK...
here is the latest scan report
Sunday,26,August,2018,13:02:58:57843
VCDS Version: 18.2.1.2 (x64)
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: MEXA16608GSHARDUL License Plate:
56-Radio -- Status: OK 0000
Revision: --H33--- Serial number: 00000000000000
ASAM Dataset: EV_ECM15TDI02013L906023SN 001001
ROD: N/A
VCID: 0407F47A8FFAEC6403-8050
No ASAM data for: "EV_ECM15TDI02013L906023SN" (VW25)
Readiness: 0 0 0 0 1
Component: GSG DSG AG7 431 6560
Coding: 0000020
VCID: 387F508A4BB27884DF-806C
Coding: 62DD2C63422907C74617346A4254E0820909
ASAM Dataset: EV_Brake1SEP90iBOSCH 003031
ROD: N/A
VCID: 0B15DF46A2A4A31C42-805E
No ASAM data for: "EV_Brake1SEP90iBOSCH" (VW25)
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Coding: 01
ASAM Dataset: EV_LWSKLOV2W5X 005001
ROD: N/A
VCID: 7EF38692E11686B455-802A
No ASAM data for: "EV_LWSKLOV2W5X" (VW25)
Revision: V0000000
VCID: 41893D6ED868394C68-8014
Coding: 3A904BBF48E30200013807916CCB96905A88676F600D30C1200000030000
VCID: 2B557FC64AE4C31CA2-807E
Coding: 0728DD
Coding: 050000
Coding: 050000
Coding: 250000
Coding: 020000
Coding: 020000
2 Faults Found
03428 - Activation of Left Adaptive Light
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 89193 km
Time Indication: 0
Date: 2015.14.31
Time: 00:16:07
03429 - Activation of Right Adaptive Light
Fault Priority: 3
Fault Frequency: 20
Reset counter: 141
Mileage: 89053 km
Time Indication: 0
Date: 2015.14.28
Time: 16:41:50
Part No SW: 18D 919 475 HW: 56D 919 475
Component: PARKHILFE 8K H02 0005
Revision: -------- Serial number: 20241529702142
Coding: 108101
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18WV3218CS0 001001
ROD: N/A
VCID: 70EFA8AAAB42E0C4D7-8024
No ASAM data for: "EV_EPHVA18WV3218CS0" (VW25)
Coding: 003036
ASAM Dataset: EV_AirbaVW10BAPVW250 A01001
ROD: N/A
VCID: 4999254EE858F10CB0-801C
No ASAM data for: "EV_AirbaVW10BAPVW250" (VW25)
Part No SW: 6JA 920 840 A HW: 6JA 920 840 A
Component: KOMBI H15 0605
Coding: 140A01
Shop #: WSC 07053 266 104857
ASAM Dataset: EV_Kombi_UDS_VD_DRM09 A04716
ROD: N/A
VCID: 3979558EB8B8618C20-806C
Revision: B9082001
Coding: 102300
VCID: 68DFC0CA9B9228048F-803C
Component: IMMO H15 0605
ASAM Dataset: EV_Imom_UDS_VDD_RM09 A03709
ROD: N/A
VCID: 6ADBBAC28D9E1A1499-803E
No ASAM data for: "EV_Imom_UDS_VDD_RM09" (VW36 *)
ASAM Dataset: EV_SteerAssinSSK 014008
ROD: N/A
VCID: 41893D6ED068394C68-8014
No ASAM data for: "EV_SteerAssinSSK" (VW25)
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5314
Revision: -------- Serial number: VWZZZ4H6283197
Coding: 16000400040005
Shop #: WSC 00078 790 00102
VCID: 46832E72F1461E745D-8012
End-------------------------(Elapsed Time: 02:36)--------------------------
