Which lowering springs. Eibach or H&R
Eibach or h&r springs on polo gti ?
Which is the better choice ?
Dink
- Platinum Member
- Drives: 2015 GTI
Re: Which lowering springs. Eibach or H&R
I have eibach springs fitted to my gti and the ride is better than standard (6c gti)
Any pics so i can see the height?
H&r do a lower ride height than eibach
Dink
- Platinum Member
- Drives: 2015 GTI
This is with the eibach springs fitted. It's a subtle drop and is about right imho.
Andy1273
- Drives: 1.2 tsi polo
The rear looks so much better. By how much did it lower by? Did you purchase a standard kit or a specific type for the height?
Any problems with speed bumps, kerbs, pot holes etc....
Dink
- Platinum Member
- Drives: 2015 GTI
Think eibach only do one drop height for the polo gti and it's around 25mm
I've not had any problems with rubbing or Kerbs.
I didn't want to go to low on the rear as it starts to push the wheel forward and just makes it look broken imho
Does look better than standard, and probably not as rough a ride as the h&r ones but i do like the lower look
Andy1273
I agree does look better than standard.john__m wrote: Sat Oct 20, 2018 12:30 pm Does look better than standard, and probably not as rough a ride as the h&r ones but i do like the lower look
Where may I ask did you get the springs from? VW and how did you get them fitted, independent garage or at VW?
I presume although you've had them fitted to your GTI they will also fit a 6c TSI?
Dink
- Platinum Member
- Drives: 2015 GTI
I got them from a site called autodoc.co.uk (they were the cheapest around) and got a local garage to fit them.Andy1273 wrote: Sun Oct 21, 2018 10:33 am I agree does look better than standard.
You will struggle to get vw to fit them.
There is a part for lowering springs from vw but they can sometimes be a bit of pain to find.
Andy1273
So do you need this part to be able to fit them? You have a part number?Dink wrote: Sun Oct 21, 2018 11:55 amAndy1273 wrote: Sun Oct 21, 2018 10:33 am I agree does look better than standard.
Dink
- Platinum Member
- Drives: 2015 GTI
No. vw do lowering springs (well they used to) but it's difficult to find the part number. They won't be listed under your vin number
You can still get them. They are called vw racingline. But ive heard the ride is terrible and they cost a lot more than eibach or h&rs
Dink
- Platinum Member
- Drives: 2015 GTI
I'd read up on what the h&r springs are like for ride qualityjohn__m wrote: Sun Oct 21, 2018 8:07 pm You can still get them. They are called vw racingline. But ive heard the ride is terrible and they cost a lot more than eibach or h&rs
I used Eibach and H&R, with H&R the car was very short and nice but it bounced all the time my car is a 6R Blue GT. After a week of use, Mount Eibach again as the car worked really badly. I bought H&R 35 / 55mm. I sincerely recommend eibach
Eibach:
H&R
Sorry for my english
Eibach:
H&R
Looks good
