Franciswat's Polo 6R 1.6 Bifuel
- Franciswat
- Drives: 6R 1.6 Bifuel
Re: My polo 6r bifuel
Thanks guys, on thursday I'll bring my cara to the body worker.
- Franciswat
You don't need any adapter , you can install the original led plate lights and then if needed we code your BCM. (recent autoscan)
- Franciswat
Re: Upgrading my Polo 6R bifuel
Thank you for this beautiful new ciclo!
I will update thread this week end when I'll the the lighs.
- Franciswat
Hi guys, new OEM led licence plate lights finally arrived perfectly packed!
If I remember correctly there's a box to tick in 09. central electric.
Here's the last autoscan ciclo:
PS This evening I noticed this error at the end of autoscan.
Is that because I may have retrofitted modules (ie PDC) that don't belong in any particular car?
Have I to be worried about It?
Friday,30,November,2018,23:39:58:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY54xxxx License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZCY54xxxx Mileage: 81360km-50554miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3217100B5842524E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BBF08E1260092380E406C6B0CD100C0412F60842000200000020000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0339054
Coding: 820000
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
2 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 81362 km
Time Indication: 0
Date: 2013.04.22
Time: 23:35:02
03156 - Sensor for Anti-Theft System (G578)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 81362 km
Time Indication: 0
Date: 2013.04.22
Time: 23:35:02
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20251528901029
Coding: 100001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XPakrAssis4K 001004
ROD: N/A
VCID: 3A7CE9AABDC4D991E7-806E
No ASAM data for: "EV_VW75XPakrAssis4K" (VW25)
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaVW10PBAVW250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW10PBAVW250" (VW25)
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140A01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3460C7929FA02FE13D-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADC19EA8DE4A91157-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 HW: 6RD 035 187
Component: Radio 517 5124
Revision: RB101000 Serial number: VWZZZ4Q5034465
Coding: 00000400040005
VCID: 0400575287805F61CD-8050
End-------------------------(Elapsed Time: 02:51)--------------------------
Once you install the LED plate lights, try this codingFranciswat wrote: ↑Fri Nov 30, 2018 10:55 pm Hi guys, new OEM led licence plate lights finally arrived perfectly packed!
Friday,30,November,2018,23:39:58:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86 VCDS Version: 17.1.3.0 Data version: 20170203 DS267.2 www.Ross-Tech.com VIN: WVWZZZ6RZCY54xxxx License Plate: Chassis Type: 6R (7E0) Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B VIN: WVWZZZ6RZCY54xxxx Mileage: 81360km-50554miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Cannot be reached ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF Component: ESP8.2i front H05 0002 Revision: -------- Coding: 210224E3217100B5842524E484D700401300 Shop #: WSC 00788 648 00255 VCID: 00085B4297984341E9-8054 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels: None Part No SW: 6R0 820 045 N HW: 6R0 820 045 N Component: Man AC H02 0202 Revision: 0003SH02 VCID: 397EF6A6B0C2D289EE-806C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 HW: 7E0 937 090 Component: BCM PQ25 Max4 H80 0736 Revision: B9080001 Serial number: 0771 060161479 Coding: 3CB02BBF08E1260092380E406C6B0CD100C0412F60842000200000020000 Shop #: WSC 02737 534 00190 VCID: 68D863E29BE89B0141-803C Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB Component: J386__TSG_FT 008 1611 Serial number: KU0KU004011200011991 Coding: 18BC30 Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB Component: J387__TSG_BT 008 1611 Serial number: KU0KU005011200017885 Coding: 08BC30 Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB Component: E221__MFL-TAS H31 0037 Serial number: 0339054 Coding: 820000 Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G Component: J388__TSG_HL 008 1611 Serial number: KU0KU010011200012406 Coding: 08BC32 Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G Component: J389__TSG_HR 008 1611 Serial number: KU0KU009011200013136 Coding: 08BC32 2 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 79 Mileage: 81362 km Time Indication: 0 Date: 2013.04.22 Time: 23:35:02 03156 - Sensor for Anti-Theft System (G578) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 79 Mileage: 81362 km Time Indication: 0 Date: 2013.04.22 Time: 23:35:02 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb Part No SW: 7E0 919 475 K HW: 56D 919 475 Component: PARKHILFE 8K H02 0106 Revision: -------- Serial number: 20251528901029 Coding: 100001 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_VW75XPakrAssis4K 001004 ROD: N/A VCID: 3A7CE9AABDC4D991E7-806E No ASAM data for: "EV_VW75XPakrAssis4K" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 6R0 959 655 K HW: 6R0 959 655 K Component: VW10Airbag022 H09 0020 Revision: -------- Serial number: 003GX011W0JJ Coding: 003232 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_AirbaVW10PBAVW250 A01001 ROD: N/A VCID: 4A9CB96AED24491177-801E Subsystem 1 - Serial number: 3575HRB4059124B2F99H Subsystem 2 - Serial number: 3585HRB4061131GQCOUS Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9 No ASAM data for: "EV_AirbaVW10PBAVW250" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 6R0 920 871 A HW: 6R0 920 871 A Component: KOMBI H03 0505 Serial number: 00000000000000 Coding: 140A01 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113 ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod VCID: 3460C7929FA02FE13D-8060 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 7E0 909 901 HW: 7E0 937 090 Component: GW-K-CAN TP20 H80 0736 Revision: B9080001 Coding: 002200 Shop #: WSC 02737 534 00190 VCID: 68D863E29BE89B0141-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0505 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADC19EA8DE4A91157-803E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11250 Shop #: WSC 00788 VCID: 2F6AC8FEEA860C3940-807A No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb Part No SW: 6RD 035 187 HW: 6RD 035 187 Component: Radio 517 5124 Revision: RB101000 Serial number: VWZZZ4Q5034465 Coding: 00000400040005 Shop #: WSC 12345 123 12345 VCID: 0400575287805F61CD-8050 No fault code found. End-------------------------(Elapsed Time: 02:51)--------------------------
3CB02BBF08E1260092380EC06C6B0CD100C0412F60842000200000020000
(it all depends on the way the wire dedicated for license plate lights was installed)
Old VCDS version.Franciswat wrote: ↑Fri Nov 30, 2018 10:55 pm PS This evening I noticed this error at the end of autoscan.
Depends of you. Yes ... or Not.
- Franciswat
Thank you ciclo for the coding. I entered It and plate lights work without errors on instrument cluster.
Someone told me he had not to code anything to get them work without errors but I have some doubt about it.
I thought I had to change byte 27 to 01 when retrofit led licence plate light (iichel wrote that sometime ago); but now I suppose this way only deactivates light check. Doesn't it
I'm pretty happy for result!!!
Thanks mate!
If It give no problems with car It's ok!Depends of you. Yes ... or Not.
Thanks mate!
- Franciswat
Hi guys, since I like to try new challenges I purchased a new car key from ali. This is it:
I have now the problem to program the transponder on the key to make it usable. Looks like I need the immo pin to configurate the key so question is how to retreive it.
Any information about how to proceede with the key configuration?
- Franciswat
So everything is more clear since I read this:
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
I post it so maybe it can be usefull for someone else.
- Franciswat
What happened?
- Franciswat
Hi dear ciclo, sadly in september my car (parked) had been involved in an accident. Last week I finally got the money (at least a part of the, about 1300 €) from insurance company to repair it. Spare parts only will cost 1200 € according to Etka.
It hurts me to see my car in this conditions but my hope
is to have it back soon better than before.
Oh, ok, I see.
Good luck with the repair, it doesn't seem like a difficult job.
- Franciswat
Thank you ciclo! Sorry for long waiting, now I can finally show you and other mates the car just repaired (4 month from accident!!!)
I asked to replace standard bumper with r-line one I provided, adding 6C upper and lower grills (standard one were broken)! It looks great What do you think?
The same day I got my car repaired It started snowing for the first time in this year.
PS Retrofit of headlight washers and front PDC still have to be done.
Looks great! , thanks for the report.
The best is yet to come.
As for the snow, there are always unexpected coincidences.
In my case, just when I started my tests for High Beam Assist retrofit in our Golf (there were some complications to overcome) began two weeks of persistent fog in the area where I live, making it impossible to get good results.
It was exasperating ...
