Polo 6R ABS CODING
- Drives: 6c 2014 1.2 tsi 66kw
Re: Polo 6R ABS CODING
Yea of course, on friday i will post this for you, thank u veru much!
This is my vcds scan for that esp question. Thanks a lot!
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY130428 Mileage: 62217km-38659miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
Component: 1.2l R4 TSI X21 7876
Revision: R5X21---
Coding: 01110012230411080000
Shop #: WSC 21862 034 00000
ASAM Dataset: EV_ECM12TFS01104E906027BB 001005
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: E5CB98E8E4D2426C37-80B0
CAN Converter 01:
Readiness: 0000 0000
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08501008140811
Coding: 21DD2885492633C00918106B0059841492CC90080005C7090C00
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: B36F36B01A86ECDC69-80E6
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0105
Serial number: 1408151B-1484
Coding: 200000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 9D3BF0088C024AACAF-80C8
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 009248018708
Coding: 000008504253005B4B844000400F07080000580251010000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMA0 004003
ROD: EV_MQBA0.rod
VCID: AE5927C4F1A4C13406-80FA
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU018081442305655
Coding: 0400A0
Front Passengers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU015081442273584
Coding: 1400A0
Drivers Door Rear Control Module:
Subsystem 3 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU025081442371503
Coding: 0400A0
Passengers Rear Door Control Module:
Subsystem 4 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU026081442385418
Coding: 1400A0
3 Faults Found:
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [008] - Open or Short to Plus
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 220
Mileage: 61520 km
Date: 2019.01.22
Time: 19:48:12
138240 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 60599 km
Date: 2019.01.04
Time: 18:45:50
228104 - Dual Washer Pump Input from SCS
B1830 29 [008] - Signal Implausible
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 61603 km
Date: 2019.01.25
Time: 19:54:34
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag00Z 001 0330
Revision: -------- Serial number: 003LM0043ZSU
Coding: 88C0C000000000005C000000000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: B1633CB8E09ADECC1B-80E4
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 410 820 607 14
Component: SideSensor_Df 151 0800
Serial number: 3575H00B515A4C12428G
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 410 822 307 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00AF1608522622B
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 151 608 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A516BCCE3A38Z
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 151 708 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00AD16C1CE6621P
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 740 A HW: 6C0 920 740 A
Component: KOMBI 211 0290
Coding: 072D09002180000800083E001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: A045C9FCBB70674484-80F4
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 009248018708
Coding: 030100046F0A560071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_001_VW26.rod
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Serial number: 2461811543601110AB2B
Coding: 240000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61236A50132821674283
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3211
Serial number: PE930499
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: B26133B4E59CE5D462-80E6
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 869 B HW: 6C0 035 869 B
Component: MU-E--ER 820 6220
Serial number: 18071400010503
Coding: 02620000BE00000041110001000000001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001017
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: AA512BD4CD4CAD14DA-80FE
Revision: R5X21---
CAN Converter 01:
ROD: EV_MQBA0.rod
Coding: 0400A0
Coding: 1400A0
Coding: 0400A0
Coding: 1400A0
3 Faults Found:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 220
Mileage: 61520 km
Date: 2019.01.22
Time: 19:48:12
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 151
Mileage: 60599 km
Date: 2019.01.04
Time: 18:45:50
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 61603 km
Date: 2019.01.25
Time: 19:54:34
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 240000
Coding: 0007
This is my Abs scan for that esp question. Thanks a lot!!
I'm not 100% sure about this, but perhaps:
21DD2885492633C00918106B0059841492CC90080005DB090C00 ESP sport/ESP off
21DD2885492633C00918106B0059841492CC90080005EB090C00 ASR off/ESP sport
Do not drive with these settings until you are sure it suits your needs. If not, revert to the original coding.
Ok thanks i will try this. But this coding will enable the on off option on my multimedia unit?
I don't know. This is what I was able to deduce from other autoscan on the net. It is not impossible that you may need to change more settings, i.e. in the adaptation channels of address 03 (abs) or 5f (multimedia)
Ok thanks, i ll post if i manage to make it work.
- Drives: Polo Beats 2017
Hi here is the adaptions from my polo for the abs:
Control unit: 03 Brakes
System description: ESP9.0i
Software number: 6C0907379N
Software version: 0005
Hardware number: 6R0907379BA
Hardware version: H04
Serial number: 08500081160603
ODX name: EV_Brake1ESP90iBOSCHPQ26
ODX version: 100020
Backup name: Brakes
Long coding:
23DD2485492533C6091A106D0059C42492CC90080005CBF98F00
Adaptations:
Anti-slip regulation (ASR):
activated
Hill-start assistant:
normal
XCP calibration protocol:
Not activated
Straight ahead brake stabilization:
activated
Roller test bench mode:
activated
Electronic Stability Program:
activated
Electronic Differential Lock:
activated
Overboost in brake system:
120BAR
Hydraulic brake assistant:
normal
Expanded electronic differential lock:
medium
Rear axle hard braking:
activated
Tire pressure monitoring display:
2
Tire pressure monitoring display, tire selection:
2
Tyre_pressure_control_monitoring_datalogging:
0
Engine drag torque control:
activated
Activating and deactivating all development messages:
VW Botschaften:
Not activated
BOSCH Botschaften:
Not activated
Dynamische Entwicklungsbotschaft 1:
Not activated
Dynamische Entwicklungsbotschaft 2:
Not activated
Dynamische Entwicklungsbotschaft 3:
Not activated
Developer_Function_120:
RKA Warning Error:
No Warning/Errro(Default)
Roller test bench mode, functional:
Not activated
Brake disk drying:
Data:
medium
ABS in lower speed range:
activated
Developer_Function_121:
Not activated
Hill-start assistant, increase threshold:
Three Percent
Regarding the 5F I found these ref to the brake:
Car_Function_Adaptations_Gen2:
menu_display_Brake_Function: activated
menu_display_Brake_Function_clamp_15_off: Not activated
menu_display_Brake_Function_over_threshold_high: activated
menu_display_Brake_Function_standstill: Not activated
menu_display_Brake_Function_after_disclaimer: Not activated
Car_Function_List_BAP_Gen2:
Brake_0x26: activated
Brake_0x26_msg_bus: Databus drivetrain
This is what is on the menu: I have a feeling that the 5f shows the proper option based on the abs setting. that's my theory
ODX version: 100020
Backup name: Brakes
Long coding:
Adaptations:
activated
normal
Not activated
activated
activated
activated
activated
120BAR
normal
medium
activated
2
2
0
activated
VW Botschaften:
Not activated
BOSCH Botschaften:
Not activated
Not activated
Not activated
Not activated
RKA Warning Error:
Not activated
Brake disk drying:
Data:
medium
activated
Not activated
Three Percent
Thank u so much!!
Excellent contribution
massimo23, allow me a little advice that maybe you have already taken into account.
- Make a backup of original setting (adaptation chanels) from all units of your 6C.
Of course that s the first thing i will do! Thank u so much guys! I ll post as soon as i can.
Yes Ciclo that was the first thing I did, thanks. Always have a backup of your strings at its original state to avoid big problems down the road.
About obdeleven it has a history option on every channel so whatever you change in any setting it appears in the history log. It gets better as it gets updated monthly.
it really is a gadget for pros has a lot of functions like:
Trouble code Freeze frame
Advanced control unit information
Live data
Charts
Coding
Coding II
Long coding
Sub control units Information
Sub control units coding
Gateway installation list
Adaptation
Long adaptation
Basic settings
Output test
Security access
Login finder
Control unit reset (UDS)
Diagnostic service change
Control unit Backup
Control unit programming history
CAR programming history
It still isn't as solid as the ross-tech yet I believe. But for the price I think its a great tool for a lot of people.
Live data
Charts
Coding
Coding II
Long coding
Adaptation
Long adaptation
Basic settings
Output test
Security access
Login finder
Control unit Backup
So i made the coding change my C7 with CB DB and it accepted my coding but in mu multimedia it said that this function is not available( i made it show esp system) and with EB doesn t accept the coding
ok so I changed the CB value in the abs coding to DB and this is what happened... I was sweating it
Menu got updated: Couple Errors popped up as soon as I changed the value: Front Assist not available and Tyre Pressure Loss Indicator. I switched off the ignition and switched it back on and all the errors were gone. ))) When I activate ESC Sport in menu I get the following reports in my car: When I try to activate ESC Off I get the following message.... didn't go further after that : So changing that Byte changes the options in the menu. Now could there be some other coding or adaption to be done? that's the question...
Hey miky396 have you checked the following adaption to see if its the same:
Looking at your Abs coding and mine also wondering what's going on with the third last and second last bytes...
21 DD 28 85 49 26 33 C0 09 18 10 6B 00 59 84 14 92 CC 90 08 00 05 DB 09 0C 00 Yours
23 DD 24 85 49 25 33 C6 09 1A 10 6D 00 59 C4 24 92 CC 90 08 00 05 CB F9 8F 00 Mine
09 0C and F9 8F mmmmm...
can you check your adaptions against mine just to see any difference..
We need to decipher this abs coding
Here are other abs codes from polos 2014-2017 with 26 Bytes
21 DD 48 85 49 2B 33 C1 09 19 10 6B 00 56 84 12 92 CC 90 08 00 05 CB 09 8F 00 Polo 6C Driving on Right 1.2 TSI 110hp 16V - CJZD 2017 6 speed manual No ACC or CC
21 DD 24 85 89 27 33 C6 09 16 10 72 00 51 84 24 91 CC 90 08 00 07 C9 09 8F 00 Polo Driving on the Right 5 Doors 1.4 TDI BlueMotion 5 speed Manual 2015 with CC
21 DD 28 85 89 25 33 C9 09 15 10 6D 00 56 84 14 91 CC 90 08 00 07 C9 09 8F 00 Polo 6C R3 1.4l TDI Comfortline Bluemotion 90bhp 5 Speed manual (J000-CUSB) 2016 with CC
23 DD 24 85 49 2B 33 C4 09 1B 10 6C 00 59 C4 24 92 CC 90 08 00 05 CB 09 8F 00 Polo Driving on Left R3 1.01 MPI Match 6 Speed Manual (J623-CHYA) 2017 with CC
23 DD 24 85 49 25 33 C6 09 1A 10 6D 00 59 C4 24 92 CC 90 08 00 05 CB F9 8F 00 mine Polo Beats Driving on Left 5 Doors 1.0 75Hp 6 Speed manual 2017 Engine CHYB with CC
23 DD 48 85 8B 24 33 C7 11 19 10 6F 00 56 C4 12 D1 CC 88 08 00 0A CB 09 8F 00 Polo LHD 5 Door BlueGT 1.4 TSi (ACT) 150Hp 7 speed DSG automatic (J623-CZEA) 2016 with CC
23 DD 28 85 89 2A 33 C5 11 18 10 72 00 51 C4 14 91 CC 88 08 00 05 CB 09 87 00 Polo Driving on the left 1.2 Tsi Match 7 Speed Automatic DSG (J623-CJZC) 2016 with CC
23 DD 48 85 8B 28 33 C7 11 16 10 6A 00 58 C4 12 D1 CC 88 08 00 0A CB FD 8F 00 Polo 6C Driving on Left 1.4l R4 TS Automatic 7 Speed DSG (J623-CZEA) with CC
21 DD 48 85 49 27 33 C9 09 17 10 6D 00 51 84 12 92 CC 90 08 00 05 CB FB 8F 00 Polo Driving on Right 5 Doors 1.0 TSI 105Hp 6 speed manual 2016 with ACC
23 DD 48 85 49 26 33 C9 09 18 10 6B 00 55 C4 12 92 CC 90 08 00 05 CB FB 87 00 Polo Driving on the Left 5 Door TSI Comfortline 1.2L T/P 81Hp 6 Speed Man 2017 (6C13-CJZD) FX/17 with ACC
21 DD 48 85 89 29 33 C4 11 14 10 72 00 51 84 12 91 CC 88 08 00 05 CB FD 8F 00 Polo Driving on Right TSI Highline 5 Doors 1.0 110Hp 7 Speed DSG automatic 2017 with ACC
