ciclo wrote: ↑Sat Jul 27, 2019 7:09 pm
Please check that the electric bridge is installed correctly.
It's crucial, the power supply is not reaching the BCM (that's why the faults, low beam, etc).
Master,
I blundered at this crucial step
I messed up terribly, connecting the bridge wrongly, shorting the relay circuit and my car smoked for the first time.
Lucky still being alive, I rushed and disconnect the battery immediately.
It took a while for me to get back to my senses, and then I began to do postmortem analysis. The wires( Yellow and Brown ) behind the relay were severely burnt and also the T17/7(light switch connector) Yellow wire which was isolated, was also burnt. I removed the bridge fearing further damage.
I checked for all nearby and other wiring's, whatever could possibly be seen, looked fine for me.
It's a daring or my foolishness I don't know, I connected the battery again with heart beating heavily, car didn't smoke or caught fire this time luckily. My hospital Ambulance was in standby mode just in case.
After waiting for some time, connected the VCDS cable, added the new coding for BCM Max and did the auto scan(without electric bridge inserted). Started checking what all functions have taken a hit. After new coding, except for low beam and cornering lights all other functions were working....Ambient lights, Dimmer switch, Reverse lights, Rear camera, Plate lights, and yes rear fog is also working master.
Felt little relaxed after seeing most of the functions working, pushed myself a little further and inserted electric bridge into right place this time and voila,.. low beam started working, but didn't check the cornering lights in a hurry to stop further experimenting.
Presently I have removed the electric bridge and disconnected the battery, and parked the car, until the mess I have created is rectified and it's totally safe to drive again.
Should I approach the service centre(not sure, if they will entertain me) or should I try it myself to rewire the burnt wires and other wires if damaged. Opening the full dash looks imminent now, Master please guide me.
Pictures of wrongly inserted bridge, burnt relay wires and latest VCDS autoscan(without electric bridge inserted) below:
Sunday,28,July,2019,15:03:16:09269
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: MEXL15606GT048293 License Plate:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 65
VIN: MEXL15606GT048293 Mileage: 42980km-26706miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000
Coding: 00250056232400080000
Shop #: WSC 53863 002 1048576
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D84C0CEAD13BD3F11F-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6502
Revision: 00043014 Serial number: CU501508317273
Coding: 0000020
Shop #: WSC 01260 002 1048576
VCID: 3A2E3B92A05DDA87C4D-806E
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C8461624724254C0800908
Shop #: WSC 29230 002 1048576
VCID: 0B40AE56B3C7130FAFB-805E
Serial number: 10051504650275
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F782F07536A7B85-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DC4C7EC18B895F857-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180475
Coding: 3AB02BFF08A10000003800C07C2B9490D2C061FF608C0000200400020000
Shop #: WSC 00046 123 12345
VCID: 2C020DCA56097437461-8078
Subsystem 1 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU015041441050460
Coding: 1400B3
Subsystem 2 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU014041441047765
Coding: 0400B3
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 1971517275001536AB2B
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580150623202239
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581150812164218
Coding: 020000
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 42985 km
Time Indication: 0
Date: 2019.07.28
Time: 00:11:25
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261224902578
Coding: 108101
Shop #: WSC 02756 790 50316
VCID: 392C249EA9DBD19FCD7-806C
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0118WCJ
Coding: 003036
Shop #: WSC 01234 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC545EF93B411F5D7-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140C01
VCID: 47C85266EF2FB76F4B3-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002304
VCID: 688AB1DA82719817629-803C
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8ECBD29CFDAA0774D-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DC4C7EC10B895F857-8014
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 01855GD0000318
Coding: 00000400010001
Shop #: WSC 00081 790 00118
VCID: 45D4586ED5A3A57FB9F-8010
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058983
ROD: EV_RDKBERU30_005.rod
VCID: 372822A69FCFC7EF3B3-8062
End----(Elapsed Time: 01:11, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
