Fog/Cornering Lights as DRL
VK70
- Drives: VW Vento 1.2 TSI Highline
Hello
I have a Vento 1.2TSI DSG (Ind) with BCM 6RU 937 087 M.
Currently the fogs lights seem to be controlled by the BCM as they also work as cornering lights(work with turn indicator and steering)
I tried activating Byte 23 Bit 2 and Bit 6 to enable them to work as DRLs.
However this doesnt seem to be working.
Can someone help me if this is the correct code and more importantly does the above BCM support this feature .I remember reading on one of the threads that it needs the signal from light switch T17/3.
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 083160303
Coding: 3A984BFF08A10000013800006C0B069000C0414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 6CCED363D68B0E62D358725-8039
Thanks!
Sent from my ONEPLUS A5000 using Tapatalk
Thanks!
antardaksh04
- Drives: TSI
Re: Fog/Cornering Lights as DRL
You indeed need a bcm max. Why not install OEM DRLs in the bumper?
VK70
Hello Antardaksh
Thanks for confirming.I thought so,but gave it a try anyway since the BCM was controlling the fogs.
Btw,nice mod on the grill.Is that a wrap or a paint job?
VK70
Hello iicheliichel wrote:You indeed need a bcm max. Why not install OEM DRLs in the bumper?
Thanks for confirming.For the OEM DRLs do I need the BCM max as well or will the existing one work?
I am planning to install the Morimoto Xenons for the low beams ,so currently no plans of upgrading to the OEM bi xenons.
You can make the OEM DRL installation without the bcm max. That's no problem
VK70
Great,thanks iichel.iichel wrote:You can make the OEM DRL installation without the bcm max. That's no problem
Will place an order for those then.
Do you have a wiring diagram for this ?Can you share this or point me to a thread if this has already been shared please.I did search but couldnt find any.
Vivek
https://drive.google.com/file/d/1Khvvda ... p=drivesdk
Number 1 is for non bcm max
VK70
I was just about to reply that I found your reponse on this thread viewtopic.php?t=71281#p533894iichel wrote:https://drive.google.com/file/d/1Khvvda ... p=drivesdk
Will the below wiring kit work?
https://www.carsystems.eu/vw-polo-6c-le ... d2175.html
If not and I need to DIY the wiring , I would need
a.3 JPT terminals
b.2 SPT terminals.
c.For the wire 1.5mm2 is correct?
d.Pin 2 on the DRL connector will be to ground I suppose?
Wire 17/3 to fuse holder 1,5mm2. One jpt one spt
Wire from fuse holder to each light, one spt two jpt
Two GND wires so two jpt and a ground eye or something
VK70
Thanks a ton. Will get this done and update here soon.iichel wrote:Wire 17/3 to fuse holder 1,5mm2. One jpt one spt
antardaksh04
- Drives: TSI
Hi VK,
Chrome strip is wrapped in matt black vinyl and I painted logo with matt black paint.
Regards.
VK70
The finish looks good.I am planning to experiment with Plastidipantardaksh04 wrote:Hi VK,
Regards.
Vivek
