Hello, welcome.
Here is another 6R 2010 that made the adaptation of BCM High to BCM Max + automatic lights.
viewtopic.php?f=56&t=68980#p514546
viewtopic.php?f=56&t=68980#p514815
To consider:
- BCM Max model to install. There are several possible models.
- Factory wiring, there are several possibilities according to factory equipment.
It determines which wires to install and isolate.
I know it is difficult to understand at first, but everything becomes very simple if you understand that the BCM is the part that must control the necessary lights for automatic lights. You should ask yourself what lights in your car are not controlled by the BCM.
If you open a thread in the 6R section and provide the information from your 6R (images, autoscan), I may help you.
Under no circumstances will I manufacture your wiring looms because I no longer buy the necessary material to manufacture them.
