Reverse Lamp and Camera disappeared after BCM max Upgrade
ZahariGeorgiev
- Drives: Polo 6R 1.6 TDI
Can some one help me.....
Recently i change my BCM to BCM max (7E0937090), and after i change it my reverse lamp doesn't go on, and my flip camera also...! When i put back my previous BCM (6R0 937 087) everything works fine....
Re: Reverse Lamp and Camera disappeared after BCM max Upgrade
Then the question arises... did you do it right?
Did you change the coding? The wiring? If so, can you tell us what exactly you did?
ZahariGeorgiev
Hello iichel,
I did the following things: ...copy and paste codes from old BCM to the new one (Central electric and CAN Gateway). 2 New wires from BCM white connector pins 54 and 57 to IC pins 28 and 28 (isolate original ones). That was all changes i made.
A full BCM Max wiring adaptation is necessary.
The faults you get is because there are pins in the new BCM Max that are not being fed (T73a/63 among others), and that is why your reversing light and therefore the RVC 'have disappeared'.
ZahariGeorgiev
Thank you ciclo,
I am a little bit newbie in the wiring..and just wonder what should i do next... i was inspired by yours and iichel retrofits, and so far i do install: heated seats, MK7 Golf flat bottom MFSW, new stalks with cruise control, Seat Toledo instrumental cluster with 6C cover, and full r-line interior from 6C...planing in the future to install auto dimming rear view mirror ( i will order from aliexpress all set: https://www.aliexpress.com/item/3284483 ... 2e0eQDF2dl ) and eventually some day - full led 6C headlight. The question is what exactly wiring scheme i need to follow. My car has a standard fog lights and drl lights, no auto lights and wipers. I saw that you in one of yours post offer wiring for BCM max adaptation, is it still available?
What should i do in my case?
Thanks in advance!
Thanks in advance!
Autoscan?
No matter the faults detected in the autoscan.
If possible, post another autoscan with the original BCM.
The saved autoscan/s are in the 'Logs' folder of the VCDS program.
ZahariGeorgiev
Hello ciclo,
Here is the link with 2 text documents with autoscans of old and new BCM:
https://we.tl/t-8EuMqCG0kf
Thank you in advance!
ZahariGeorgiev
i found this instructions:
https://drive.google.com/file/d/0B2nv91 ... k2Q1E/view
And to fix my problem (reverse light and camera) i have to complete wiring from picture WL0 and WL 2(already did WL 1 to fix illumination of instrument cluster) Is that right, or i should also do WL 3 wiring?
OK. I will post them here.ZahariGeorgiev wrote: Thu Jan 23, 2020 2:45 pm Hello ciclo,
BCM High installed/connected (original).
Thursday,23,January,2020,13:00:34:35439
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZBY004889 License Plate: M2016
Chassis Type: 6R (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
02-Auto Trans -- Status: Malfunction 0010
17-Instruments -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AH HW: 03L 906 023 D
Component: R4 1.6l TDI H13 9979
Revision: --H13--- Serial number:
Coding: 00254016002400080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023AH 003014
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 6C7521942FA9E0B98D-8038
6 Faults Found:
6068 - No Communication with Instrument Cluster
U0155 00 [037] - -
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 153760 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 33 °C
Intake air temperature: 11 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.311 V
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 8 °C
7278 - No Communication with Instrument Cluster
U0155 00 [045] - -
Fault Priority: 6
Fault Frequency: 4
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 44 °C
Intake air temperature: 13 °C
Control Module temperature-TECU: 10 °C
7279 - No Communication with Instrument Cluster
U0155 00 [045] - -
Fault Priority: 6
Fault Frequency: 4
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
11844 - Engine Control Unit Incorrectly Coded
P0610 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Unlearning counter according OBD: 31
Coding in the engine control module-FRF_VARCOD: 1
Number of resets of main unit-CTR_RST_MC: 0
Control Module temperature-TECU: 17 °C
Accelerator position: normalized-Accelerator position: 0.00 %
6118 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Fault Priority: 2
Fault Frequency: 1
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 43 °C
Intake air temperature: 12 °C
Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 10000010
6117 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Vehicle speed: 255 km/h
Readiness: 0 0 0 0 0
Part No SW: 0AM 300 050 P HW: 0AM 927 769 D
Component: GSG DSG AG7 403 9060
Revision: 00040034 Serial number: TFK01005190911
Coding: 0000020
Shop #: WSC 07486 001 1048576
VCID: 363B8D768C9F24C35D-513C
1 Fault Found:
006242 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 10
Mileage: 0 km
Time Indication: 0
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3416D00B6842D14EA82DA00421300
Shop #: WSC 02069 123 12345
VCID: 060BEDC68BAF4473DD-8052
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 45
Mileage: 0 km
Time Indication: 0
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x1211
Hex Value: 0x259D
Hex Value: 0x007F
Hex Value: 0x7F81
Hex Value: 0x7FF8
00474 - Control Module for Immobilizer
Fault Priority: 0
Fault Frequency: 1
Reset counter: 45
Mileage: 0 km
Time Indication: 0
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 38398970779538CD2D-806C
1 Fault Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 145101228
Coding: 3CB82BBF08A10000003800003C2B0CD90080410F60040000200000000000
VCID: 4041791897CDE885ED-8014
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU011.05.1015140
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU017.05.1012733
Coding: 08BC30
Subsystem 3 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 29190000858580089166
Coding: A40000
Subsystem 4 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU010.05.1012823
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU007.05.1017524
Coding: 08BC32
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag008 H09 0018
Revision: -------- Serial number: 003DW00FP4EK
Coding: 003038
VCID: 424F751297DBFC97FD-8016
Serial number: 3572SRB40000B7ACC10B
Serial number: 3582SRB40000B7C92178
Serial number: 3516GRB401P9OICCMBQI
Serial number: 3526GRB401N9OICD7JTE
2 Faults Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12674816 - Immobilizer Control Module
U0167 00 [009] - No Communications
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 002200
VCID: 7071198857BDC8556D-8024
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 45
Time Indication: 0
Address 25: Immobilizer
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00000
VCID: 2F309B4BC7784E1295-807A
1 Fault Found:
49-00 - No Communications
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:25)--------------------------
Thursday,23,January,2020,12:49:37:35439
www.Ross-Tech.com
Mileage: 153350km-95287mi Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56 0B
VIN: WVWZZZ6RZBY004889 Mileage: 153350km-95287miles
VCID: 6C5D39EC078118A1A5-8038
6 Faults Found:
U0155 00 [032] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 153527 km
Date: 2000.00.00
Time: 00:00:00
Coolant temperature: 53 °C
Intake air temperature: 4 °C
Voltage terminal 30: 12.424 V
Unlearning counter according OBD: 33
Control Module temperature-TECU: 4 °C
U0155 00 [040] - -
Fault Priority: 6
Fault Frequency: 3
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Control Module temperature-TECU: 6 °C
U0155 00 [040] - -
Fault Priority: 6
Fault Frequency: 3
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
P0610 00 [032] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 2
Fault Frequency: 1
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
U1112 00 [032] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 153477 km
Date: 2000.00.00
Time: 00:00:00
Address 02: Auto Trans
Cannot be reached
Revision: --------
VCID: 06F305DE93877C5BF5-8052
2 Faults Found:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x1211
Hex Value: 0x25A0
Hex Value: 0x007F
Hex Value: 0x7F81
Hex Value: 0x7EF8
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Revision: V0000000
VCID: 3821A1485F8D503545-806C
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 138160111
Coding: 3CB82BBF08A10000003800003C2B0CD90080410F60000000200000000000
Shop #: WSC 18752 008 00032
VCID: 685141F81F7D3085C5-803C
Coding: 18BC30
Coding: 08BC30
Coding: A40000
Coding: 08BC32
Coding: 08BC32
2 Faults Found:
01516 - Terminal 30; Left
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 16
Reset counter: 7
Mileage: 153321 km
Time Indication: 0
Date: 2014.06.14
Time: 17:03:44
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 16
Reset counter: 7
Mileage: 153321 km
Time Indication: 0
Date: 2014.06.14
Time: 17:03:44
Coding: 003038
VCID: 42378D6A6FB314FF15-8016
2 Faults Found:
U0155 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
U0167 00 [008] - No Communications
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 6JA 920 840 A HW: 6JA 920 840 A
Component: KOMBI H16 0607
Coding: 140801
Shop #: WSC 73430 031 00217
VCID: 392E9F454B862A3C5D-806C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
2 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 58
Reset counter: 47
Mileage: 153119 km
Time Indication: 0
Date: 2014.06.09
Time: 00:25:57
02873 - Control Module for Back-Up Camera (J772)
Fault Priority: 2
Fault Frequency: 58
Reset counter: 47
Mileage: 153119 km
Time Indication: 0
Date: 2014.06.09
Time: 00:25:57
Component: IMMO H16 0607
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A5F3DF20F8B0497D5-803E
Coding: 11230
Shop #: WSC 00000
VCID: 2F18B3A3AF50667A8D-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:49)--------------------------
This installation guide is for a 6R RHD from India, your 6R is an LHD from Europe, so this installation guide is not applicable to your 6R under any circumstances.ZahariGeorgiev wrote: Thu Jan 23, 2020 6:28 pm i found this instructions:
Put in your mind that no two POLO 6R are alike in the world (this statement is not true, but each 6R has its own particularities), it's just for you to consider so that the installation you plan to do ends up being a total success in your 6R (B model year).
Please, post a picture of your fuse box under the steering wheel and I will tell you what installation guide you should use for you can build the BCM Max adaptation wiring and the wiring for automatic lights.
Due to some reason I don't know, I subscribe to this thread to answer the future questions.
Please, ask only one question in each post, do not take the opportunity to ask 1000 questions in each post
I will try to answer each post individually.
Thank you.
ZahariGeorgiev
Hello ciclo,
I am very grateful for your help!
Here is the picture of the fuse box:
Follow this installation guide for the manufacture and installation of wiring looms:
https://drive.google.com/file/d/1cXw67i ... sp=sharing
Download it.(PDF file)
I will provide you with BCM and RLS codings according to installations.
ZahariGeorgiev
Dear ciclo,
Is it possible for you to manufacture those wiring looms? I can wait and will pay as much as it cost, but i will know for sure that everything will work!
Make a new Autoscan with 7E0 BCM installed and post it here, first Clear all DTCs before clicking Start for the new Autoscan.
Post the following images:
Relay carrier
Light Switch connector
Dimmer connector
In the same way that you have seen them in the installation guide that I provided, ... also from your 6R, an exterior of the lights and one from the inside (dashboard).
I have contacted my suppliers because I am missing a very important contact terminal for your installation. It will all depend on whether they can supply it to me.
If it were possible to make your wiring looms, you would never overpay, you will only pay the actual cost.
- The relays must be original (autolights wiring = 104€, + BCM Max wiring adaptation = 54€, + shipping cost = 16€, + additional shipping cost --> read below).
- You will pay the shipping costs of the material I request to make your wiring looms. I guess it will be 10-12 euros to add to the total.
Let's wait to see if I receive an answer from my suppliers.
Tell me if you agree as soon as possible.
Relay carrier
Dimmer connector
ZahariGeorgiev
I am agree with everything, just want to finish my project..
Tomorrow will take pictures of all parts and post autoscan.
One more thing, i order auto light switch (3C8941431A), auto dimming rearview mirror from 6C (3G0857511E), rain/light sensor for it(5Q0955559B), and i got this from kufatec: https://www.kufatec.com/en/volkswagen/v ... mber=38994
But unfortunately the plug for auto dimming mirror is different for that 6C mirror, so i order another one: https://www.kufatec.com/en/light-sight/ ... mber=40062, and will need help later with them ...
Kufatec provides installation instructions, but there is no problem if you need help.
