Activation Of Rear DRL Tailight
PoloBlack
Drives: Polo Beats
Post by PoloBlack »
Hi All,
Does anyone know the VAG coding to program the rear taillight LED DRLs to always on, per the following video:
https://youtu.be/yKvjZCyTx14
Thanks in advance.
proalves
Drives: Polo GTI AW1 2019
Re: Activation Of Rear DRL Tailight
Post by proalves »
Search here in this post...
viewtopic.php?f=71&t=74111
PoloBlack
Drives: Polo Beats
Post by PoloBlack »
proalves wrote: Sat Jan 25, 2020 12:47 pm Search here in this post...
Thank you! Any issues applying this setting in conjunction with auto exterior lights?
proalves
Post by proalves »
PoloBlack wrote: Sun Jan 26, 2020 6:39 am
I haven't tested it yet.
The coding information I found on the internet.
I am gradually discovering what can or cannot be changed in our GTI...
PoloBlack
Drives: Polo Beats
Post by PoloBlack »
proalves wrote: Tue Jan 28, 2020 3:34 pm
Update - This can be done with Carista ‘Scandinavian DRL’ and works awesome in conjunction with auto-headlights.
CarbonChaos
Post by CarbonChaos »
But ‘Scandinavian DRL’s’ basically puts the side/ position lights on all the time this will include all interior lights in the switch’s etc which is tiresome at best.
The better way is to code each rear position lamp to be active with front drl’s.
PoloBlack
Drives: Polo Beats
Post by PoloBlack »
This is how the option reads in Carista - as far as I was aware, in daytime it’s just my rear DRLs running which is what I was after, but now I have doubts? Which other lights are running in tandem?
CarbonChaos
I have tried this mod via OBDeleven ‘Scandinavian DRL’s’ and it does turn on the position lights which includes front drl’s on 6C polo.also on seat Ibiza and Skoda Octavia all the same results.
From your image I suspect it will also do the same as it states parking lights? Guess you will have to try it and see?
PoloBlack
Drives: Polo Beats
Post by PoloBlack »
CarbonChaos wrote: Tue Feb 04, 2020 9:39 pm I have tried this mod via OBDeleven ‘Scandinavian DRL’s’ and it does turn on the position lights which includes front drl’s on 6C polo.also on seat Ibiza and Skoda Octavia all the same results.
I think it is front and rear DRLs, which is what I was after, I have auto lights and the front DRLs are always on in any case
T8PDN
Drives: GTI+
Post by T8PDN »
This can be done I have done it on my VW polo GTI 2018 with obd 11 through longcoding.
T8PDN
Drives: GTI+
Post by T8PDN »
(09) Central Electrics
Step 1
LEUCHTE23SL HLC7
Light_Function_D_23
Old value: nitcht activ
New value: Tagfahrlicht
Step 2
LEUCHTE23SL HLC7
Dimming_CD_23
Old value: 0
New value: 60
Step 3
LEUCHTE24SL HRA69
Light_Function_D_24
Old value: nicht aktiv
Step 4
LEUCHTE24SL HRA69
Dimming_CD_24
Old value: 0
New value: 60
T8PDN
Drives: GTI+
Post by T8PDN »
Done with OBD11 pro
Happy coding people
fazzy
Drives: GTi++/TT/TDi/190E
Post by fazzy »
Thx 😊
Rlinegrey
Drives: Polo AW
Post by Rlinegrey »
I always code 20br/21br/23sl/24sl
Verstuurd vanaf mijn Mi 9 SE met Tapatalk
