[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Franciswat's Polo 6R 1.6 Bifuel - Page 19 - UK-POLOS.NET - THE VW Polo Forum
Wet your finger with distilled water and remove the dirt.
- Never dry the surface of the gel pad with a cloth. Use a hair dryer with cold air.❄ (...ambient temp)
- The cleaning finger should ALWAYS have a small layer of distilled water when cleaning the surface.
If you follow these two previous instructions exactly, the cleaning will be perfect and without damage to the Sensor.
3. Multi-pin connector 2, 8-pin, for voltage supply lines and CAN bus
12 – Voltage supply, negative, terminal 31
15 – Voltage supply, positive, terminal 30
16 – Anti-theft coding control signal, SAFE, positive -> connect this one to 12V as well
But there is a chance that the device (MIB radio) has the new quadlock, so different pin assignment.
Hi guys, a future great add today for my little car. From Germany a new Composition Media from a WV Beetle.
It's the last version of CM with both APP buttom and DAB. Part number is 5K703520K.
CM is cheaper compared to a Discovery Media but It has all functions I was looking for.. and even more.
Moreover I think smartphone connectivity perfectly make up for the lack the function of DM extra-funcions.
I tried to list all vesion of CM after long time of searching.
5K7035200 HW H05 NO DAB MUTE BUTTON
5K7035200A HW H04 or 05 DAB MUTE BUTTON
5K7035200B HW H20 NO DAB MUTE BUTTON
5K7035200D HW H20 NO DAB MUTE BUTTON
5K7035200E HW H20 or H22 NO DAB or DAB MUTE BUTTON
5K7035200F HW H30 NO DAB MUTE BUTTON
5K7035200G HW H32 NO DAB MUTE BUTTON
5K7035200H HW H30 NO DAB SOUND BUTTON
5K7035200H HW H31 NO DAB SOUND BUTTON
5K7035200K HW H41 DAB APP BUTTON
5K7035200L HW H41 NO DAB APP BUTTON
5K7035200M HW H41 NO DAB APP BUTTON
The first attempt to power the radio with 12 v 5 A power supply failed but after converting a xbox 360 power supply It provided more than 10 A which were enought to use the radio. Radio works nice! Only voice commands are not activated so I will have to ask for their activation over CP removal.
(first 2 pictures taken from web)
Finally I'm impressed by this radio even If I had only a fast look.
Can't wait to test It on car.
Hmm...
I made a Wiring-adapter to connect to the new T10 connector (original wires) in case I want to return to the previous state (CCS on the Stalk) ... easily.
This wiring is currently connected to T41, but is not connected on the other end ... because on the other end (original wires, new T10 connector) I have the CCS Emulator connected.
I have two sets of parts:
1- MFSW with CCS buttons, Stalks without CCS switches. (+ CCS Emulator)
2- MFSW without CCS buttons, Stalks with CCS switches. (+ Wiring-adapter)
I also have two slip rings, two airbags, etc...
Franciswat wrote: Tue Jun 02, 2020 11:53 pm
Hello guys, when you installed CC emulator did you keep stalk wiring to use both MFSW buttons and stalk buttons?
I changed the stalk as well. The stalk must be set to CC OFF in order to control the cruise on/off via MFSW.
This is too complicated (always assume an idiot will drive your car at some point in time) and can even become hazardous.
Thank you very much for your answers guys they are really helpful!
Then since I will have both CC and on board computer buttoms on MFSW can I replace my current stalk with a more "basic" one whithout extra buttons? In this way I will avoid to have double commands which may be confusing.
