ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Tuesday,14,January,2020,18:56:13:32438
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: DAB AERIAL AMPLIFIER OK!
Mileage: 48190km-29943mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 48190km-29943miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A8D3FD44CF80237773-803E
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA77DF3-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E97BBB-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D59C425460A7317-806C
   Revision: B9084001    Serial number: 2502 179190157
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
   Shop #: WSC 00046 123 12345
   VCID: 2D07F4C8BD16D50F521-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231708304294
   Coding: 308001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71BF28B8612EF1EF369-8024
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E237573-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F5F48D-8012
   Revision: B9084001
   Coding: 002204
   VCID: 688945DC52743027617-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E05F3C4B090AE176BB-807A
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C237B73-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 F    HW: 1T0 035 686 f
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7T1727264
   Coding: 04000442040000A10001
   Shop #: WSC 33361 790 00118
   VCID: 372BD6A04F4A6FDF38D-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V16  8536
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA71F60D-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFDFF8D-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FDF38D-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BBFDC5-806E
End----------(Elapsed Time: 02:03, VBatt start/end: 14.0V/13.9V)-----------
DAB aerial OK!
By the way, in regard to RNS510, I have read in some forums that POIs (speedcameras, etc) cannot be selected (greyed map details button) from a FW certain version onwards.
This is not entirely true if you have the maps CD inserted at the same time. :)
But to avoid having to have the maps CD inserted at the same time, this is the procedure:
- Download the FW from HERE (not from another place :lol:) according to the HW version of your RNS510 (Compatability, explained in the same page).
- You must install it again.
- Install the maps to an earlier version, that is, if you have V16, install the V15, and reinstall the V16 again.
(unfortunately gpsunderground web💖 disappeared :cry:)
- Install the POIs.
You will see that now you can select the POIs (highlighted map details button) that you like without having to have the maps CD inserted.
V17 coming soon...
FYI:
On February 15, I will move these folders from my desktop to an external hard drive.
That is to say, a prudent time has passed (months in some cases :)) in which I had these reminders on my desk, so if any of you need my support you should inform me by email to provide any kind of help. Thank you.
Edwin Hubble https://en.wikipedia.org/wiki/Edwin_Hubble ... crystal clear. :)
Skoda Fabia VRS 2012
Retrofitting.
- BCM Max.
- Automatic lights, LH/CH.
- Automatic DRLs.
- Dimmer for interior lights.
- Dynamic cornering lights.
OEM! 8)
:arrow: viewtopic.php?f=41&t=73355&p=565905#p565898
A birdie told me that Automatic activation of 'Light Assist' function is possible by turning the ignition switch on the PQ25 by BCM coding.
For experts:
New challenge / task / discovery to achieve.
Hint ... it may be necessary to also review the adaptation channels.
Bye. :lol:
I do not answer private messages or emails related to this matter ... 'to anyone, without exceptions'.
It is a challenge.
Thank you very much to all who have cared about my health and that of my loved ones, we are all fine.
However, don't worry about me, everyone knows that Spanish and English people are weeds (difficult to kill), we are always there despite the circumstances ... :mrgreen:
I am deeply affected by the death of many irreplaceable people due to the COVID-19, etc... my deeply condolences to their loved ones.
Hi friends, here again, everything is fine for me, scrupulously following the personal protection measures that my human conscience allows me to avoid being infected by COVID-19, and also, of course, following the measures established in my country .
My challenge is to be the last human to be infected with COVID-19... 🤣
I need a lot of luck (90%) and continue with my parameters ...
The following image (in joking terms) is dedicated to those humans who wasted/lost the opportunity to become SUPREME beings (in financial terms :mrgreen:). Life offers very few opportunities like this in periods of 80-100 years.
Now it's my desktop background. (with all the letters 😁)
Hi there, friends.
I am perfectly fine, I have not yet been infected by COVID. :lol:
I whish you are all in good health.
I prefer not to comment absolutely anything about COVID and human behavior worldwide (in all social strata, without exception).
NOOOOOOOOOOOOOOOXXXXXX :lol:
Homey terms,
... during these weeksssss of confinement I have been doing things at home that needed my attention (nothing special), completely disconnected from any online connection. All the issues-topics related to cars were relegated for later, I am even losing interest in cars, but this was already happening before confinement for other more powerful reasons.
I had several projects in mind for my wife's Golf 7.5, ... everything ready to be installed -without external help- (purchased parts, software, installation procedures, tools, etc.), all perfectly clear to make several improvements with total success. Now I plan to sell (or give) all the new parts I bought.
Note for Slavik: especially the infotainment system with navigation without external connection (the screen and unit - DM -).
I apologize to everyone who sent me emails or private messages and did not receive a reply from me. I won't for a long time, I don't feel like connecting the laptop, informational toxicity remains staggering.
I've even disconnected the bluetooth from my 'stupidphone' ... :wink:
I wish all you the best of luck with your projects wherever you live.
Take care, it is necessary.
WTH... (first day without confinement with time periods to exercise in limited places)
😱 perfect to COVID.
Justo cuando creía que no podías ser más tonto de lo que eras, vas y haces esto...
Translation to English.
:lol:
See you soon. :wink:
4x
Some time ago someone told me about using relays for some automatic functions.
This is a possibility for one of those functions:
... perhaps it would be better and easier if it were possible through BCM coding/adaptation. :)
Friday,22,May,2020,21:45:38:32438
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 1ST SCAN AFTER COVID CONFINEMENT (rEsEt)
Mileage: 49320km-30646mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 49320km-30646miles
   ROD: EV_ECM12TFS02103F906070FD_004.rod
   VCID: 6A8D3FD44CF8023BED6-803E
Readiness: 0110 0101
   Revision: --------
   VCID: 025D77745448FA7B456-8056
   Coding: 01
   VCID: 7EA5038420709E9B21E-802A
   Revision: V0000000
   VCID: 3829D59C425460ABAB2-806C
   VCID: 2D07F4C8BD16D503C84-8078
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Coding: 308001
   VCID: 71BF28B8612EF1E3ACC-8024
   Component: VW10Airbag01M H10 VW10Airbag01M H10 00200020
   Coding: 00314D
   ROD: N/A
   VCID: 4ACD9F542C38E23BCD6-801E
   Coding: 140E01
   VCID: 47CBA6603F2A1F53D28-8012
   Revision: B9084001
   Coding: 002204
   VCID: 688945DC5274302BFB2-803C
   Revision: AA001001
   VCID: 2E05F3C4B090AE1BF1E-807A
   Coding: 010100
   VCID: 2A0DFFD48CF8C23B2D6-807E
   VCID: 372BD6A04F4A6FD3A28-8062
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA713FA8-807A
   VCID: 77AB16A00F4AAFD3628-8022
   VCID: 372BD6A04FCA6FD3A28-8062
   VCID: 3B23CA9073E24BB3460-806E
End----------(Elapsed Time: 02:14, VBatt start/end: 13.9V/13.9V)-----------
1.1º
VCDS Upgrade. From HEX-V2 3VIN TO HEX-V2 10VIN
... previously: https://www.uk-polos.net/viewtopic.php? ... 98#p570052
Once the payment has been made and the Feature Code has been received in the email the next day...
:arrow: https://forums.ross-tech.com/showthread ... #post79322
Result successfully.
or click in About (main screen)
Perfect!! 8)
MAPS update. Volkswagen RNS 510 CY Europa West V17 CD_8557
Thanks to iichel.👌
Works great! 8)
CRISPR
Editing: 🧫🧬+🧠 = 👽💪... :lol:
For sale.
Two wiring for automatic lights for POLO 6R
-Model Year A, B, C (sold to VW🐇 8) )
-Model Year D, E ... etc (sold to 🐦77 8) )
-Ready to send.
90€ plus shipping cost.
Promotion as a gift (07/2020-->): 10 Littelfuse fuses and tesa cloth tape, which is not necessary for this installation.
All info here :arrow: viewtopic.php?f=62&t=69223
Locked
