Polo 6R ABS CODING
drewdoom
Drives: Polo 6R
Re: Polo 6R ABS CODING
Post by drewdoom »
Here is the data:
VIN: WVWZZZ6RZBU002603 License Plate: ECU
Address 01: Engine
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55A0B9C8AC0157EE89-FFFE
Advanced Identification
Serial number:
Identification: SJ8-FST
Revision: --H05---
Date: 01.06.10
Test stand number: F405
Manufacturer number: 1003
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Misc.
Hardware number: 03E 906 023 L
Car Info
Chassis Number: WVWZZZ6RZBU002603
Engine code: CGP
VCDS Info:
VCID: 285EC03C98F31A06E2-5072
Labels: 03E-906-033-AZQ.lbl
Readiness: No script available
VIN: WVWZZZ6RZBU002603 License Plate: IMMO
Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
Component and/or Version: IMMO H04 0709
Software Coding: 000000
Work Shop Code: WSC 00000
VCID: 6ADAFA348D7FE81634-803E
Advanced Identification/FAZIT
Serial number:
Identification: VO3-041
Date: 26.07.13
Manufacturer number: 2070
Test stand number: 1060
Flash Status
Flash Date: 00.00.00
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 5K0 953 234
Workshop System Name: J334
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset: EV_Immo_UDS_VDD_RM09
ASAM Dataset Revision: A03710
Car Info
Immobilizer
Transponder ID (Current val.): 134D0E9E
Transponder ID 1: 134D0E9E
Transponder ID 2: 6B05D1E3
VCDS Info:
Labels: 5K0-920-xxx-25.clb
210224DB216D00B4842B24E284D400400700
210224DB216D00B4842B24E284D400401700
could you please try these two
drewdoom
Drives: Polo 6R
Post by drewdoom »
Thank You iichel but allready done by geko online.
Here right coding:
210224E3216D00B4842B24E284D400401100
Anyway You was close really close.My respect!!!
Close enough. 17/11 at byte 16 is due to TPMS
CeciliuTabara
Drives: POLO 6R DSG 2013
Post by CeciliuTabara »
Hello guys,
Today i replace my instrument cluster.
After that, I got errors on ABS:
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412C00C784141471825700400905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F2D6C78D6BA1C372E-805A
2 Faults Found:
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 67971 km
Date: 2020.07.09
Time: 00:08:51
0625 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 179601 km
Date: 2020.07.09
Time: 21:19:41
Part No SW: 6R0 920 870 HW: 6R0 920 870
Component: KOMBI H21 0320
Coding: 140E00
Shop #: WSC 00186 211 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 72EB058CA54851DFA1-8026
Can you help me?
You'll need to do a system function test of the ABS module. You can do it in basic settings IIRC.
CeciliuTabara
Here is:
Thursday,09,July,2020,22:14:29:59248
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY197086 License Plate:
Mileage: 179630km-111616mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: WVWZZZ6RZDY197086 Mileage: 179630km-111616miles
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BJ HW: 03C 906 024 BH
Component: CGGB MM4HV G 8997
Revision: --H09--- Serial number:
Coding: 0000077
Shop #: WSC 00788 648 00255
VCID: 67DD64D8558AA47706-5124
Readiness: 0000 0001
Part No SW: 0AM 300 060 HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4560
Revision: 00043014 Serial number: CU501301245051
Coding: 0000020
Shop #: WSC 35070 001 1048576
VCID: 67DD64D8558AA47706-5106
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 67971 km
Date: 2020.07.09
Time: 00:08:51
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 179601 km
Date: 2020.07.09
Time: 21:19:41
Component: LENKW.SENSOR H06 0070
Serial number: 26011304650453
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF321BCE11005BFD5-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 M HW: 6R0 820 045 M
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 387FF7A48BB4FB8F5F-806C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 300111639
Coding: 64B029B808A1000001280EC168AB8FD0F0C867FF60A730C1200000000000
Shop #: WSC 64564 324 38760
VCID: 3979F2A0B0BEE287A0-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110113 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU019111200016909
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU028111200012325
Coding: 18BC30
Subsystem 4 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 29190001675950069296
Coding: A50000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261420900569
Coding: 308104
Shop #: WSC 02739 790 50316
VCID: 3B75E8A8B282D097B2-806E
Component: VW10Airbag01K H10 0020
Revision: -------- Serial number: 003GX01K0BUS
Coding: 00314B
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BBD6CED58791F39-801E
Serial number: 3575HRB405H1S6UQ59C3
Serial number: 3585HRB405H1S6UQCPS0
Serial number: 3515RRB400O50D62K27X
Serial number: 3525RRB400O50D62DIA3
Coding: 140E00
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0251
Revision: BS050001
Coding: 002000
VCID: 70EF0F84A34463CF57-8024
Component: IMMO H21 0320
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB1DEC8D98991F19-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 A HW: 3C8 035 279 A
Component: RNS315-EU H62 0319
Serial number: VWZAZ2N0156574
Coding: 000002510200000000030002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 295922E0481E5207D0-807C
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V4 0050
1 Fault Found:
1048582 - GPS Antenna
B1054 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 179601 km
Date: 2020.07.09
Time: 21:21:36
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 00788
VCID: 306FCF84F7C423CF17-8064
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77FD3498CE2A34F796-8022
End-------------------------(Elapsed Time: 03:06)--------------------------
Thank you,
CeciliuTabara
Thank you iichel,
Wich is the procedure for BAsic Settings?
Can you help with this procedure?
legendaryzz
Drives: 6r
Post by legendaryzz »
polo 1.2 TSi front disc upgraded to 288mm but now i need to code the ABS, can someone help me to get the right code.
This is the original code:
210228E3216F00B3842714E984D100401300
have a look here --> viewtopic.php?f=56&t=74520
legendaryzz
Drives: 6r
iichel wrote: Sat Sep 19, 2020 10:44 pm have a look here --> viewtopic.php?f=56&t=74520
ok thx. I got this code : 210248E3216F00B3842712E984D100401300 and tryed many more but still getting error 22.
i will look at the advanced id numbers: but wich nummers do i compare.
is your VCDS original or clone?
legendaryzz
Drives: 6r
iichel wrote: Sun Sep 20, 2020 12:09 pm is your VCDS original or clone?
How can i see that? I have borrowed it from a friend.
legendaryzz wrote: Sun Sep 20, 2020 1:16 pm
uhm... ask him?
