Hello guys,
I brought this set from kufatec : https://www.kufatec.com/en/volkswagen/v ... o-6r-39408
And there is no manual available, so i have 2 cables witch i am not sure where to connect.
Here there are:
-1st , Here i think its written (BCM)A49, Is that Right?
-2nd , Here its written "Violet" - Where should i connect it? IC connector pin17?
Thanks in advance!
Help with Headlight Washer System Harness
ZahariGeorgiev
- Drives: Polo 6R 1.6 TDI
Re: Help with Headlight Washer System Harness
what are the other sides of the wires connected to?
ZahariGeorgiev
1st one - (BCM)A49 - other side is connected to the relay
2nd one i think is going for the low water level sensor
Yeah connect it to T32/17 from the instrument cluster. Relay goes to BCM T73a/49
ZahariGeorgiev
Thank you very much iichel!
Soon i will try to install front and rear PDC and will also gonna need help
