☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼ ...CLOSED!
- Drives: Polo 6R 1.2TSI
Re: ☼ POLO 6R. WIRING LOOMS. Automatic lights. BCM Max. ☼
Hello ciclo,
you do amazing things
Can you help me?
i want to add to my car auto headlights and after my research you are the right person.
I need a wiring loom for Polo 6R, 2010 - tenth digit A.
I have factory installed on the car rain sensor, cruise control and etc. and i think BCM max.
you only have one pc. left, I want to take it
Best Regards and Have a nice day.
Can you help me?
Does your car have a start/stop system and/or factory bi-xenon headlights? Or do you have VCDS? It's important to be sure your car has BCM max, otherwise this won't work or you need to retrofit BCM max too.
Hello bad_mad, welcome. Thanks for your comment.
Please, can you post a recent VCDS autoscan of your 2010 Polo 6R 1.2 TSI?
As iichel comments, your 6R needs to have a BCM installed that can manage automatic lights. (BCM Max - factory bixenon -, or BCM for 6R Bluemotion)
Have a nice day too.
Thank you very much for your comments guys
I will make necessary scan with VCDS tomorrow and i will posted.
I dont have factory bi-xenon or start/stop system...but if necessary I will upgrade to BCM Max.
Ok, so your BCM will be "high" 6R0937087 X.
Do you already know or have seen what BCM Max you have to buy?
The autoscan is a priority to be able to advise you in the correct way.
- Drives: polo 2012 r-line
Hello ciclo
I have a polo 6R 2012 1.2 TSI R-line xenon
I'm looking for the wiring loom for retrofitting the auto-light
BCM part nr: 7H0 937 089
Do you have a wiring loom for this?
I have VCDS and VCP and ODIS...
Hope to hear from you..
Further info about 09- central electrical
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0254
Revision: BS050001 Serial number: 0465 112120862
Coding: 3CB02BBF08A1000009300E916E2B0FD05AC0672F60051041200000010000
Shop #: WSC 12345 123 12345
VCID: 39734EB4B0D04C89EE-806C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050412 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU017041200011654
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU018041200013274
Coding: 18BC30
Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO1580100W
Coding: 081001
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003041200011604
Coding: 18BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010041200011151
Coding: 18BC32
Coding: 02302D
Coding: 18BC30
Coding: 18BC30
Coding: 081001
Coding: 18BC32
Coding: 18BC32
Hello VWflappie, welcome.
2012 can be 'Model Year' C or D.
It implies one type of wiring or another (it is precisely the turning point).
Please check the tenth digit of your VIN. Thank you.
viewtopic.php?f=62&t=69223#p516196
Hello Ciclo,
Thank you for your reply..
vin number is WVWZZZ6RZCYxxxxxxx
this would be a "C"
this would be a "C"
You are correct My BMC is 6R0937087D. I have not yet selected a specific BCM version, I will wait for your advice on the best option, In the near future i I have a plan to retrofit front OPS park system, Bluetooth module and xenon-headlight. My wife will be very happy about that
Thank you in advance.
This is my autoscan with VCDS:
Tuesday,14,July,2020,20:20:06:41650
VCDS Version: 19.6.1.0
VIN: WVWZZZ6RZAY207095 License Plate:
Mileage: 139390km-86615mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 69
VIN: WVWZZZ6RZAY207095 Mileage: 139390km-86615miles
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 D HW: 03F 906 070 D
Component: SIMOS10.20H02 9694
Revision: -------- Serial number:
Coding: 001900D6202400080000
Shop #: WSC 21893 142 98567
ASAM Dataset: EV_ECM12TFS02103F906070D 003014
ROD: EV_ECM12TFS_003_VW25.rod
VCID: 2390550B6780F72411-8076
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 210228E3216D00B9842514EB84D600401300
Shop #: WSC 02069 000 00000
VCID: 4DC6E18D3356F3C241-8018
Part No SW: 6R0 907 044 B HW: 6R0 907 044 B
Component: Climatronic H08 0305
Revision: V0000000
VCID: 32A33BDEABCF2D9D99-8066
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 045101363
Coding: 3CB02BB808E12400933006407CEA0FD0F0C041FF60842040200000000000
Shop #: WSC 124697 483 00190
VCID: 3EB703FAFB0B5569F9-806A
Component: RLS 160210 05 54 0403
Coding: 0005F3
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0902
Serial number: KU0-KU003.02.1013503
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU001.02.1013377
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 7 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU008.02.1011193
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU009.02.1017072
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 HW: 6R0 919 475
Component: PARKHILFE 4K H07 0008
Revision: -------- Serial number: 71391002525827
Coding: 100001
ASAM Dataset: EV_VW250ParkiAssis2 S01006
ROD: EV_VW250ParkiAssis2.rod
VCID: 7BE88533C778E79CD1-802E
Part No SW: 6R0 959 655 D HW: 6R0 959 655 D
Component: VW10Airbag008 H09 0018
Revision: -------- Serial number: 003DX00103V+
Coding: 003038
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 43B015EBE760B70411-8016
Serial number: 3572SRB40000ABE4527B
Serial number: 3582SRB40000ABE08259
Serial number: 3516GRB402N9LLFMPSK1
Serial number: 3526GRB402J9LLFNABOE
Part No SW: 6R0 920 860 DX HW: 6R0 920 860 DX
Component: KOMBI H03 0207
Coding: 140E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 0D86614D3F16738241-8058
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002200
VCID: 70E5BF14A301A1CF69-8024
Component: IMMO H03 0207
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBAB6683275D1559-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667789290
Coding: 010000
VCID: 269F53329B93E53139-8072
Good morning VWflappie.
This will be your wiring for automatic lights.
viewtopic.php?f=56&t=58703&start=4755#p572056
Through my email I will inform you of all the payment and shipping processes, and additional information about wiring installation, BCM/RLS coding, etc ...
Soon I will send you my email by private message so you can contact me. I beg you a little patience ... in any case the wiring will be sent first thing tomorrow if this is your wish.
Good morning bad_mad.bad_mad wrote: ↑Wed Jul 15, 2020 9:27 am You are correct My BMC is 6R0937087D. I have not yet selected a specific BCM version, I will wait for your advice on the best option, In the near future i I have a plan to retrofit front OPS park system, Bluetooth module and xenon-headlight. My wife will be very happy about that
etc...
Thank you very much for the Autoscan.
Recommendation to buy your new BCM for your future projects:
Contact firegrafik (forum user), he can help you get one of the latest BCM Max models... 7E0937090 C, D, E ... you will be satisfied with this purchase.
Besides, you need the wiring for BCM adaptation.
The process would be similar to this: viewtopic.php?f=56&t=70853&p=529913#p529913
Plus other wire for reverse light. (in your case)
I can manufacture your wiring looms, for BCM MAX adaptation and for automatic lights.
The price for this process is indicated in the first post of the first page of this thread:
Please read B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH (same conditions, full support, etc)
Total = 135 + 16 shipping costs.
Please tell me if you agree so I can start with the preparations ... I have to order a couple of connectors for your wire set. Thanks.
Top! Hope the hear soon from you ciclo!
ciclo wrote: ↑Wed Jul 15, 2020 11:42 amGood morning VWflappie.
Hello VWflappie
Please check your inbox. Thank you.
The last two wiring that I put on sale in this thread. Ready to send.
MY A, B, C.
MY D, E, ... etc
All info here viewtopic.php?f=62&t=69223&p=516196#p516196
MY A, B, C.
MY D, E, ... etc
Hello Mr. Ciclo
I am Navein from India. interested in staring Retrofit business in India.
I tried contacting many retrofit installers in India. But no one is able to help me.
Heard more about you and my friends told me that you will help me in this.
Please call me or what app me +919994999898
E- Mail : sales@velmuruganagency.in
