What to look out for- 1.2 TDI SE
Trev the farmer
Drives: 1.2 TDI SE
Post by Trev the farmer »
I have just purchased a Polo 1.2 TDI SE, I am due to pick it up this week. Is there anything I should be looking out for regarding common faults etc. Regards, Trev.
Re: What to look out for- 1.2 TDI SE
Vw= crap. Good luck.
SimonPoole
Post by SimonPoole »
Check to see if its had the Dieselgate fix applied and if it has, find a tuner to roll it back to a pre "fix" file.
It will run better and puts less strain on the EGR valve and DPF.
Check for broken suspension springs, which are common on most cars nowadays and worn front suspension bushes depending on mileage.
Trev the farmer
Drives: 1.2 TDI SE
Thanks Simon, I appreciate the help. How do I tell if it has had the dieselgate fix ?
SimonPoole
Should be a small sticker with a recall/service action number on it in the boot near the spare wheel.
Alternatively you should be able to check with your local VW dealer. There was an online checker, but they seem to have been taken down recently.
You should also check when it last had the cambelt and water pump changed. Should be every 5 years, I Can't remember the mileage interval, but it is whichever comes soonest anyway.
Trev the farmer
Drives: 1.2 TDI SE
Thanks very much !!!
Dont let them fool you do the big service every 100 000 km or 5 years atleast the timing belt. Dont go for 180 000 km
Trev the farmer
Drives: 1.2 TDI SE
Thanks I appreciate your help. The Polo had a full service at 60,000 miles, it is now at 63,000. I presume that would cover the cam belt and water pump.
CarbonChaos
Post by CarbonChaos »
Never presume anything when buying a second hand car 🤔
Ask for the invoice for the service if possible you should be able to see what’s been done,just because it’s had A service doesn’t mean it was the correct service?
if your in doubt or can’t prove the belts need to be done or have been done then budget for that cost in the sale price.
SimonPoole
Trev the farmer wrote: Wed Feb 10, 2021 7:49 pm Thanks I appreciate your help. The Polo had a full service at 60,000 miles, it is now at 63,000. I presume that would cover the cam belt and water pump.
Highly unlikely. As said check for receipts.
Trev the farmer
Drives: 1.2 TDI SE
I have been trying to find out if my polo has had the dieselgate fix. I have checked for stickers around the spare wheel well, nothing. I have been on the vw website and entered my vin number, it says “this vin number is not part of claim “ . Does that mean it has not had the fix ?
SimonPoole
Trev the farmer wrote: Mon Feb 15, 2021 2:31 pm I have been trying to find out if my polo has had the dieselgate fix. I have checked for stickers around the spare wheel well, nothing. I have been on the vw website and entered my vin number, it says “this vin number is not part of claim “ . Does that mean it has not had the fix ?
When I checked mine on the website it said the same, but then when I checked it again it told me that it had been done.
Check with your local VW dealer, they should be able to tell you.
If it has been at the dealer since dieselgate, it has the updated software.
JALKEN
Drives: POLO 6R 1.2 TDI
Post by JALKEN »
CHANGE CAMBELT AND WATER PUMP !
The bearing failed on my waterpump after only owning the car for 1 month and the cambelt jumped.
Also like everyone else has said, rollback mapping to previous deiselgate fix. Mine drives like crap when in low rev's.
Trev the farmer
Drives: 1.2 TDI SE
Thanks for all the help and advice, very useful.
