DPF Sensor
Kr1s
Drives: 1.2 TDI 2010
DPF Sensor
Post by Kr1s »
I've been needing to replace my DPF sensor as my car has gone into limp mode and I have the part (https://www.autodoc.es/bosch/665279?gsh ... tsQAvD_BwE) but I have no idea where it's located on the car.
Anyone have an idea of where it is?
Re: DPF Sensor
mounted on the fuel filter in the engine bay behind right hand side headlight
Kr1s
Re: DPF Sensor
Post by Kr1s »
Doesn’t seem to be there :lol: .
Re: DPF Sensor
Ah I see, your steering wheel is on the wrong side.
look on the other side, on the firewall between the engine and the cabin
would be nice if you could post some pictures of its actual location, thanks
Kr1s
Re: DPF Sensor
Post by Kr1s »
Wooo thank you! :D Finally found it.
Now, should I be concerned that one of the hoses ends right there?
Re: DPF Sensor
Looks pretty acceptable to me
