Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Great! Nice lighting effect to know that the heating is on.
What LEDs have you used? Do you have images of the process?
Sure!
I bought ten of these: click
I simply soldered two of them to the + and - inside the steering wheel.
Then I taped the LED strips to the side of the airbag. That's all.
I'm sorry but I didn't make any pictures. I'll make some, the next time I remove the airbag. I had to do it in about 0 degrees Celcuis, outside.
Making pictures was not in my head, sorry.
Thanks Michel. Really nice, one of the best I've seen.
I think nothing beats the original
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Very nice iichel.
All blue colouring !!
The red LED strips on my airbag, they illuminate when the heating is enabled.
Via T12/5 to the heating relay
More pictures: https://imgur.com/a/sES7YaZ
How the CCE operates the heating elements and the LED:
Good solution for your heated steering wheel ... but Slavik is going to cut your balls for violating the CCE casing.
That's fine, it's cheaper than in the hospital haha.
I present you, the Slavik Seal of Approval:
That's great ... thanks for sharing your work!
I love how the car is going!
Thank you both
- Lee_Liu_Te
- Drives: 6R 1.2 TDI Bluemotion
