BCM Max Transporter 2013
Re: BCM Max Transporter 2013
Install a NEW battery!!! It is clear that the poor condition of the battery directly influences the problems that arise in your T5.
I recommend an AGM technology battery.
In the Debug folder of the VCDS program you have all the codings you have done on your T5, they are in the CodingLog file, maybe there you will find the original BCM coding.
Please follow my advices above, don't invent new encodings. :)
This matter ends here, we are hijacking another user's thread.
samul
Drives: T5
Post by samul »
Summary:
A8A000380E212023002000103C2B0C500000430F60060000300000000000
This was your coding and like you wrote i tested all possibilities with "(Bit3 and Bit5) and Byte7 (Bit4 and Bit5)"
i ended with 2 errors which reaturn after i lock & unlock car:
03303 - Response Closing Status of Rear Left Door
03304 - Response Closing Status of Rear Right Door
But doors are locking and unlocking, status in vcds is correct, no errors on speedo.
After diging in internet i found similar problem with Interior lights and find resolution :D this wasn't connected with bcm upgrade. In transport part i have 2 lights, one is with led board, this with led board was set to react on door open. When switch it off interior lights works fine. The lamp has internal problem.
01044 - Control Module Incorrectly Coded <- this is lie :D Has nothing to do with BCM, another idea from internet ;) I unplugged china radio and error don't return after deletion. I connected it back, active on Can Gateway installation list Radio & Navigation and i don't have this error but i have:
01304 - Radio
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
So here there is no solution :/ I will have error in the can gateway regarding bad coding or errors with the radio and navi... another solution is radio replacement.
Next week i will replace battery :!:
Thanks for help ;)
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
New mod :-
Bixenon headlight + Auto range + headlight washers
Shadow109
Post by Shadow109 »
SO.. I have fitted the headlights, added new wires for drl and 58r/l
I still didn't connect the level sensors
everything works as expected exclude the lift HB light
I have tried to swap the bubs, checked all the fuses
then I checked the wiring diagram for HB light, and I fund that the current is going for HB right and lift to the BCM But the lift HB Current is not going out from BCM
I tried several coding possibilities, then I tried A different BCM, But no success
this is my current autoscan:-
3C-Lane Change -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   X44 3312
   Revision: 26X44---    Serial number: 00000000000000 CVN: 40C67883
   Coding: 01114012234400080000
   Shop #: WSC 92521 052 12345
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75B7E8FE5543B673EC4-8020
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
1 Fault Found:
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:04
                    Engine RPM: 856.00 /min
                    Normed load value: 35.7 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 38 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 14.040 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 64
                    Cruise Control System (CCS): status-Bits 0-7: 208
                    Cruise control switch-off: irreversible-Bits 0-7: 0
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bits 0-7: 0
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175796210
   Shop #: WSC 02736 790 49152
   VCID: 3A2D3BC23C5D190BC16-806E
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F7D26075F52BBDE-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BA3FEC67367E0039A0-802E
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.lbl
   Revision: B9084001    Serial number: 2502 306190145
   Coding: A8A0393E4E33201201280E717EEB9FD5CA88660F608538403204003F0840
   Shop #: WSC 12345 123 12345
   VCID: 2D07009EFD13BEB3544-8078
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160002125520036437
   Coding: B0FFFF
1 Fault Found:
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Time Indication: 0
                    Date: 2022.04.01
                    Time: 09:47:01
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0021255101
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372B22F60FCF04633E8-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:03
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353728FE15C3F6732C4-8060
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140A230300
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 3B233EC633E72003DA0-806E
1 Fault Found:
15361536 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General Checksum Failure
          [ECU component protection eeprom defect]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:02
   Revision: B9084001
   Coding: 042204
   VCID: 6889B18A12715B9B672-803C
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 010100E200000100000000
   VCID: 2D07009EFD93BEB3544-8078
   Component: IMMO          H04 1109
   Serial number:
   VCID: 6A8DCB820CFD698B716-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:| User\5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0466413079
   Coding: 03031102
   Shop #: WSC 09003 957 00200
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2730DE2DF32E33E44-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0465512829
   Coding: 030311
1 Fault Found:
730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
          C122C 15 [009] - Open or Short to Plus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:02
   Revision: --------    Serial number: --------------
   Coding: 0206000001000000
   VCID: 77ABE2F64F4FC463FE8-8022
3 Faults Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:03
5256213 - Front Vehicle Height/Level Sensor
          C114D 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:02
5256725 - Rear Vehicle Height/Level Sensor
          C114E 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:02
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001010D08001F0303D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2517F8BEA56386F39C4-8070
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
2 Faults Found:
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:02
                    Voltage terminal 30: 13.8 V
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 111
                    Mileage: 251191 km
                    Date: 2022.04.01
                    Time: 09:47:02
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: F0001800
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:36, VBatt start/end: 14.1V/14.2V)-----------
Any ideas ??
Shadow109
Post by Shadow109 »
My first time to see the MKE on the new T6 3D cluster 🥰
Shadow109 wrote: Fri Apr 01, 2022 5:32 pm
Any ideas ??
The BCM coding is correct for Bixenon with 'T6 electrical installation' (but you already know that :wink: ).
Assuming that the electrical installation for HB is correct (two different wires from pins T73a/1, T73b/1 --> 2 fuses -- each routed for each headlight -HB-), we cannot draw any conclusions until the level sensors are installed, ... because you already have the J431 unit connected.
The coding for the J431 unit (55) is not correct, I guess you still can't code it due to the detected faults.
You also know that:
Module 61 can be removed from the installation list with the following procedure:
1- Go to Gateway 19, install list, enable 61 (again).
2- Go to Battery monitoring 61 (now enabled), code to 000000.
3- Come back to Gateway 19, install list, disable 61.
4- Go to autoscan, click on GW installation list (not on Start), wait the result, clear all DTCs, wait the result ...
Module 61 must have disappeared from the installation list.
5- Check with a new Autoscan (Start button).
This bug also cause unexpected faults.
As you mentioned, these are just ideas...
Shadow109
Post by Shadow109 »
So after a lot off digging, I decided to change the wire T73/1a, and the surprise was when I disconnect it from the bcm
after fixing the current wire everything worked like a charm
   Coding: A8A0393E4E33201201280EC17EEB9FD5CA846601608538C03204003F0840
   VCID: 2D07009EFD13BEB3549-8078
   Coding: 0228EE
   VCID: 77ABE2F64F4FC463FE5-8022
Shadow109
Post by Shadow109 »
New mood
6000k bi-xenon low beam
6000k H7 highbeam
6000k front fog lights
and full led rear lights
After coding similar to t6 led coding, I still have 2 faults:-
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 35
                    Reset counter: 43
                    Mileage: 256107 km
                    Time Indication: 0
                    Date: 2022.05.15
                    Time: 20:32:24
03432 - Activation of Right Parking Light
                    Fault Priority: 2
                    Fault Frequency: 12
                    Reset counter: 43
                    Mileage: 256107 km
                    Time Indication: 0
                    Date: 2022.05.15
                    Time: 20:32:24
 01502 - Bulb for Rear Fog; Left (L46)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 9
                    Mileage: 256679 km
                    Time Indication: 0
                    Date: 2022.05.19
                    Time: 01:19:09
The reason I have the rear fog light faul is that the T6 had a separate led bulb for rear fog, unlike t5
Shadow109 wrote: Sat Jun 25, 2022 7:18 pm ...
Very common causes (too common) in these retrofits, the wiring is the first thing to thoroughly check when these faults are detected in the scans.
Maybe you should check the coding for unit 55.
I recommend that you do some comparison with other vehicles like yours.
Shadow109
Post by Shadow109 »
ciclo wrote: Sat Jun 25, 2022 7:57 pm
no need, I have changed the coding to test a DCC unit and forgot to change it back :lol:
New retrofit :-
upgrading ABS from MK25 to MK100
this upgrade is necessary if your intending to retrofit ACC, the ABS Unit that I am using is: SW: 7E0 907 379 Q HW: 7E0 907 379 N
1.parts needed :-
ABS pump with its connector
1 M10 to M12 Connector and 1 M12 to M10 Connector
2 oil pipes form ABS pump to master (used from T6)
step 1 :-
When changing the ABS the order of the oil. pipes will be different from T5 order, some bending is needed
step 2 :-
repining the wires
step 3:-
coding, I will attach a .clb file that I have made that will make coding the mk100 a pice of cake
all the info in this .clb. file was shared by dnoermann
(I will. post the link later)
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA48661AA28F550
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40D9492A5A0143DB8FF-8014
1 Fault Found:
8229 - Databus
          [ACAN: Airbag_03 frame timeout]
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 252
                    Mileage: 255859 km
                    Date: 2022.05.14
                    Time: 04:52:06
Shadow109
Post by Shadow109 »
To solve the Airbag fault in the ABS unit I have took two t6 Airbag units from a friend
One is HW08 and the other is HW10
The HW10 seems not compatible with my airbag connector
So I had to stick with the HW08
Shadow109
Post by Shadow109 »
attaching ACC unit in my front bumper :-
until now :-
Radar fitted
ABS changed
Airbag Controller changed
Cluster CP done
ECU patched
CCE removed
the last mission was to deal with my Steering Wheel buttons, sine I don't like T6 Steering Wheel and I wanted to keep my GTI Steering Wheel, I had to face more issues
First I have moved buttons LIN from T73b/17 to T73b/36
and then tell the BCM by clicking byte 29 bit 6
then modifying CC wiring to match T6
WhatsApp Image 2022-03-08 at 1.46.20 PM.jpeg (111.15 KiB) Viewed 11128 times
WhatsApp Image 2022-03-08 at 1.42.07 PM.jpeg (89.35 KiB) Viewed 11128 times
Mainly RGA in in T6 is going directly from ACC unit to the buttons
after these changes we need to tell the BCM by clicking byte 17 bite 2
Changing my buttons to scirocco, hopefully it will work
WhatsApp Image 2022-07-12 at 10.22.46 PM.jpeg (32.9 KiB) Viewed 11128 times
   Coding: B0FFFF
the buttons seems to respond in 01 measurements, but still have faults in engine and ACC
I tried to change the buttons coding to match T6 buttons but still with the same faults
my last chance was swapping the Buttons IC
finally Everything works like a charm 8)
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 20 25 37 3C 55 5F 65 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 261420km-162438miles
   Revision: 26X44---    Serial number: 00000000000000 CVN: 376C1028
   Shop #: WSC 92521 052 00000
   VCID: 75B7E8FE5543B673EC9-8020
   Coding: 307E4098256586840C7A027AA486614F78F550
   Coding: 01
   VCID: 7EA5F7D26075F52BBD3-802A
   Revision: 00001010
   Coding: 0000000002
   VCID: 7BA3FEC67367E0039AD-802E
   Coding: A8A0393E4E33201201280EC17EEB9FD5F8846600608539C03204003F0860
   Coding: 0228EE
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
   Coding: 0041155001
   VCID: 372B22F60FCF04633E5-8062
1 Fault Found:
12718592 - Databus
          [Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 261426 km
                    Date: 2022.06.22
                    Time: 20:01:15
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 36352FF208C5FD6B253-8062
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$
   Coding: 000000000000000000000000000000003047
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   Coding: 140E230300
   VCID: 3B233EC633E72003DAD-806E
   Revision: B9084001
   Coding: 042207
   VCID: 6889B18A12715B9B67F-803C
   Revision: AA001001
   VCID: 2D07009EFD93BEB3549-8078
   Serial number:
   VCID: 6A8DCB820CFD698B71B-803E
Cannot be reached
   Coding: 03031102
   VCID: 3D2730DE2DF32E33E49-8068
   Coding: 030311
   VCID: 2517F8BEA56386F39C9-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 825 254 AN    HW: -----------
   Component: MRM DL2 22/23  --- 1810
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 261426 km
                    Date: 2022.06.22
                    Time: 20:01:15
                    Voltage terminal 30: 13.9 V
Cannot be reached
End----------(Elapsed Time: 01:32, VBatt start/end: 14.2V/14.2V)-----------
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Quite a lot of hard work gone in there -- Shadow109
Good to read all errors gone.
It is certainly a great job, thanks for sharing the info.
ACC was a nice evolutionary leap in cruise control systems ("one small step for man, one giant leap for mankind!" :lol:).
Enjoy it in your T5. 8)
Shadow109
Post by Shadow109 »
Thanks Fernando, I am not done yet :D
I think I have addicted
