ciclo wrote: ↑Sun Feb 20, 2022 6:05 pm
Got it, thanks for the clarification.
There is a way to get rid of the battery regulator from the GW Installation list in case you need it...
In my fantasies, I also tried/installed a battery regulator (with LIN connection) in my 6R (7L3) without the "voltage stabilizer" indicated in the diagrams, and experienced malfunctions (sporadic errors) in the
automatic light system, also in the
radio-navigation system, although there were no malfunctions related to the voltage regulator/alternator.
Finally the battery regulator was removed as the voltage stabilizer was not going to be installed, everything worked perfectly again.
Great to know that my BCM coding for the T6.1 LED taillights (Byte 27, 18) also worked correctly with no faults detected.
If you want, try this new BCM coding, maybe we'll get lucky and get rid of the "low beam" faults.
F9A839BA0A21209101280E602CEB8E50D0807389600220C03200003D0800
Ah yeah, the CH function is semi-automatic.
- Ignition switch OFF, pull from the HB lever once, open the door and the lights will turn on.
Hiya Ciclo,
I hope y our week is going smoothly!
Sorry for the delay in getting back to you, this week is hectic. As always!
Here are some autoscans for your viewing.
Before latest coding:
Saturday,19,February,2022,14:08:06:50827
VCDS Version: 21.9.0.2 (x64) HEX-NET CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH09**** License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 20 25 37 56 61 77 0B
VIN: WV1ZZZ7HZEH09**** Mileage: 182370km-113319miles
20-High Beam Assist. -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GH HW: 03L 907 309 M
Component: R4 2,0L EDC X45 5576
Revision: 26X45--- Serial number: 00000000000000 CVN: 8C42185C
Coding: 01194012232400080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 77BE1AA7CE0BCF3170-8022
VINID: 9E606AAAA1D8A956002430C50C00D7DA0A
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 708724AD89AD0E9824A59176A96110
Shop #: WSC 02736 790 49152
VCID: 3A38C393B59912594F-806E
Serial number: 28011404650720
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB00F83E131FE7933-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02736 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7CB4058BF72DEC691D-8028
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 035161868
Coding: F9A839BA0A21209101280E602CEB8E50C0807389600220C03200003D0800
Shop #: WSC 12345 210 12345
VCID: 689C49DB9BB550C9E9-803C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030216 05 54 0403
Coding: 2630AD
Subsystem 2 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 005 0653
Serial number: KU0KU022101992950515
Coding: 1000B3
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 004 0653
Serial number: KU0KU010041991001759
Coding: 0000B3
Subsystem 4 - Part No SW: 5G0 959 442 L HW: 5G0 959 442 L
Component: E221__MFL-DC1 H11 0103
Serial number: 29180000513380048213
Coding: A4FFFF
10 Faults Found:
03432 - Activation of Right Parking Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:45:24
03435 - Terminal 30 for Interior Light and Parking Light
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:38:60
03303 - Response Closing Status of Rear Left Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 02:16:18
03396 - Supply voltage terminal 30 for central locking
Fault Priority: 2
Fault Frequency: 1
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:38:60
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:39:01
03591 - Control Circuit for Horn
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:39:01
01516 - Terminal 30; Left
Fault Priority: 3
Fault Frequency: 2
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:38:60
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 23:28:25
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 2
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 23:28:25
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 23:28:25
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00MSSRH
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3522D0AF9487FD21A2-8060
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 760E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 312AE4BF60EFD101FE-8064
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
[Steuergerät für Telefon keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 21
Reset counter: 61
Mileage: 182371 km
Date: 2022.02.18
Time: 01:28:02
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 042300
5 Faults Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
01300 - Control Module for Navigation with CD-Rom (J401)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
01303 - Telephone Transceiver (R36)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
03406 - Control Module for Battery Monitoring
Fault Priority: 2
Fault Frequency: 6
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 03:06:05
03395 - Control Module for High Beam Assistant
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 1K8 857 511 E HW: 8J0 857 511 C
Component: FLA H03 0012
Revision: AA002001
Coding: 0102856B74745D545420363E01
Shop #: WSC 00020 790 12345
VCID: 3424EDAB97FDE42995-8060
Component: IMMO H04 0710
Serial number:
VCID: 6A9833D38DB962D9FF-803E
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 00001A00
Shop #: WSC 02739 790 12345
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2016.07.12
Time: 03:38:55
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:20, VBatt start/end: 14.4V/14.4V)-----------
After coding:
Monday,21,February,2022,10:19:40:50827
www.Ross-Tech.com
Scan: 01 03 04 08 09 15 17 19 20 25 37 56 61 0B
Revision: 00H43001
Coding: 01
Revision: 00001012
Coding: 0000000002
Coding: F9A839BA0A21209101280E602CEB8E50D0807389600220C03200003D0800
Coding: 2630AD
Coding: 1000B3
Coding: 0000B3
Coding: A4FFFF
2 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.14
Time: 00:22:28
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.14
Time: 00:22:28
Coding: 760E01
Revision: B9080001
Coding: 042300
2 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.14
Time: 00:22:33
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.14
Time: 00:22:33
Cannot be reached
Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
Coding: 00001A00
End----(Elapsed Time: 01:19, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Most of the codes were from having the BCM unplugged.
I also tested different CAN locations for the J844 and it is functional when I can't talk to it so will be leaving it there for now until I decide what to do with the windscreen/sensor. I am thinking of sourcing the 5K0 mirror to see if that solves the issue.
As a side note, the camera unit HW (8J0857511C) is an Audi TT part number, interesting.
I currently have no interior illumination when on Auto and only partial illumination (IC and Climate controls) when on dipped beam but I am awaiting the arrival of the dimmer switch. I will correct this once the part is in hand.
Ignoring the above, this has been an overwhelming success as I have full light functionality including full auto lights. Again, thank you.
I have noticed that I don't have the auto wipers function but I have yet to have the time to look at the coding for that yet.
What interesting things do you have planned next for your vehicles?
