It's a 1.0 MPI 60hp / 44kW engine, from 2012.
240.000km, and in pristine condition.
It's the Black Up Exclamation Mark, meaning it has the 16 inch black alloys, chrome mirror caps, Black lettering on the door and black interior accents.
https://imgur.com/a/cgrY7E8
It's pretty standard and well equipped:
- IT'S GOT A SUNROOF!!!!
- Factory 75hp software in the ECU
- Dealer maintained (!)
- 3 doors
- GTI spoiler
- City brake / short distance LIDAR
- Satnav by Navigon
- Bluemotion technologies (BCM max)
- Facelift tail lights
- Metallic paint LC9X
Modifications:
Interior:
- OEM 1S0 BCM Max from facelift 1S0937090F
- OEM 1S0 Facelift instrument cluster 1S0920870
Exterior:
- OEM 1S0 Facelift rear bumper --> 1S6807421BE + 1S6807568 + 1S0945701 + 1S0945702 + info
- OEM 1K8 LED licence plate lights --> 2x 1K8943021C
- OEM 1S0 rear camera --> 1S0980121
- OEM 1S0 3K PDC --> 1S0919475B + 3x 5Q0919275B
Running gear:
- OEM 1S0 Polygon 17 inch rims with 195/40 R17 tires --> 1S0601025N +info
- OEM 1S0 ABS controller 1S0614517L for TPMS
Thursday,24,February,2022,09:21:39:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 21.9.0.2 (x64) HEX-V2 CB: 0.4604.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZAAZCD064697 License Plate:
Mileage: 243840km-151515mi Repair Order:
Chassis Type: AA-VW12 (6N0)
Scan: 01 03 09 13 15 17 19 25 44 56 61 AD
VIN: WVWZZZAAZCD064697 Mileage: 243840km-151515miles
56-Radio -- Status: OK 0000
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 D HW: 04C 907 309 A
Component: 1.0l R3 MPI H01 6464
Revision: U8H01--- Serial number: CVN: 073C1CE7
Coding: 00110012020401000000
Shop #: WSC 44376 001 1048576
ASAM Dataset: EV_ECM10MPI01104C906020D 001011
ROD: EV_ECM10MPI01104C906020D.rod
VCID: 1C612931E629222B5B9-8049
VINID: 9E69EAAAA451A935001841891C2C774285
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 C HW: 1S0 614 517 C
Component: EBC 460 ESP H08 0004
Serial number: 0109352
Coding: 12BF24718BB302F5480024FED1B0405058B000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_Brake1UDSESP 015024
ROD: EV_Brake1UDSESP.rod
VCID: 2F3BEEFD879FA9B30EB-807B
Address 09: Cent. Elect. (J519) Labels:. 1S0-937-09x-V1.clb
Part No SW: 1S0 937 090 HW: 1S0 937 090
Component: PQ25 BCM H57 0555
Revision: -8------ Serial number: --------------
Coding: 62B8290000010000080001F42E28ACC07740426F7E820440200000420100
Shop #: WSC 46766 001 1048576
VCID: 70B92D815AA1F64B571-8025
Subsystem 1 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO1616061
Coding: 183100
Part No SW: 1S0 959 655 HW: 1S0 959 655
Component: VW10Airbag009 H03 0005
Revision: -------- Serial number: 003G3002G3FF
Coding: 000000000000000000000000000000003039
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 7BA30AAD03678513F23-802F
Serial number: 3575HRB405H18NQSF1I6
Serial number: 3585HRB405H18NQSDPIT
Serial number: 3555NRB40124UE20RPDT
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 860 B HW: 1S0 920 860 B
Component: KOMBI H08 0021
Revision: X0008006 Serial number: 00000000000000
Coding: 114300
ASAM Dataset: EV_KombiUDSMM9RM10 A04708
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 1S0 937 090
Component: GW-K-CAN TP20 H57 0555
Revision: -8------
Coding: 001000
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1S0 920 860 B
Component: IMMO H08 0021
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8D3FE97CFD0C9B195-803F
Address 44: Steering Assist (J792) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S1 909 144 G HW: 1S1 909 144 G
Component: EPS_ECU H30 1503
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 009004
ROD: EV_SteerAssisNSK_009.rod
VCID: 372BD69D7FCF617356B-8063
Part No SW: 1S0 035 156 A HW: 1S0 035 156 A
Component: Radio 567 5536
Revision: AA001001 Serial number: VWZ8Z1M3006432
Coding: 0000040802
VCID: 290F00E5B9FBC783D0F-807D
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 1S0 907 534 HW: 1S0 937 090
Component: Batt-regelung H57 0555
Coding: 032B7864
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 HW: 1S0 907 201
Component: CV-SENSOR H06 0450
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 678B46DD6FEF31F306B-8033
End----------(Elapsed Time: 00:36, VBatt start/end: 12.3V/12.3V)-----------
