Front Pads and Disc 2016 GTI Torque settings
- Drives: 2021-22 GTI+
Hi I have done a quick search but not found what I'm after.
So I about to change the front disc and pads and after torque settings for the Gide pads for the front calliper also the Calliper hub Bracket bolts.
Thanks in advance for the help.
- Drives: 2017 6C GTi Manual
Re: Front Pads and Disc 2016 GTI Torque settings
Went to look at my Erwin manuals I "printed" and realised I had the manuals for FS3 calipers rather than FN3 calipers.
Anyway with that sorted.
Guide pins: 30nm
Carrier bolts (clean if reused): 124nm
Brake hose with banjo bolt: 35nm
Disc retaining screw: 4.5nm (guten tight)
Bleeder screw: 8nm (again guten tight)
Hope that helps
Guide pins: 30nm
Hope that helps
- Platinum Member
Prepare some umf for carrier bolts, they can be tight because of thread locker. -18 mm socket
guide pins 7mm allen
t30 torx
t30 torx
Also, the spring is a right bastard to get back on.
There is a knack to it however. I think putting the pointed ends into their holes on the face of the caliper and the bottom flat in place first then levering the top flat over. A light smear of ceratec made it easier.
Go for whichever way feels easiest for you as they aren't fun to deal with.
Thanks for the info, do you know if the carrier bolts should be replaced?
The service manual says to clean if resued so I'd say you can but I can't imagine them costing more than a couple of quid from your dealership.
Thanks for all the info, will these discs be ok?
https://www.eurocarparts.com/p/brembo-h ... -92844079M
Going to use oem pads
Says the diameter is 288mm whereas the 6C GTi's front brakes are 310mm (312mm) so just double check they're for your car.
Personally don't like the look of the slot design that Brembo use (ATE's is also quite similar).
I myself am looking at fitting the DBA 4000 T3's with their street performance pad to mine when they eventually need changing. However, the DBAs are roughly twice the price of the Brembos.
If you were to buy just the DBA discs I believe Demon Tweaks sell them.
- Platinum Member
yes, just get correct diameter ( size)TrebleTA wrote: ↑Sat May 07, 2022 12:04 pm Thanks for all the info, will these discs be ok?
Well for my reg I get 3 types listed.
https://www.eurocarparts.com/performance-brake-discs
3rd Brembo option, £82.99
https://www.eurocarparts.com/p/brembo-h ... -92844085M
Diameter [mm]312
Brake Disc Thickness (mm)25
Diameter [mm]312
How are the brakes?
Havent fitted the fronts yet, getting that last bit out off the fronts. But have it all ready, euro car parts tock a age, due to me ordering a 18mm socket too, yet they could not get so went tool station and was half the price for the socket
P.s also noticed the front left disc is whining in slow traffic, have to stamp on the peddle to stop the whine. I did think it was the back, will try to do next week, I twisted my arm 5 weeks ago. Catching my dog fulling off the bed
