Okay, well try the wiring adaptation I showed earlier. But you did not answer my question about the lens clicking.
BlackT51
Drives: No polos
Post by BlackT51 »
What do you mean "clicking" my english is broken sorry :lol:
And where is this J331 relay?
Thanks for the picture and Autoscan.
The T5 does not have Relay J331. (what the ...)
According to the Autoscan, the T41 connector is not perfectly connected. This is usually caused by not pushing the tab on the connector's locking mechanism all the way in.
From H4 to H7 (or similar), for T5. BCM 087 or lower.
Remove T41/40 wire from stalks/levers connector, also remove T17/4 wire from light switch, and extend the original wire T41/40 with a new wire to the T17/4 empty light switch slot.
Connect original wire T17/4 previously removed to T17/7 in light switch connector.
Notes:
Scrupulously respect the thickness of the new wires. They must be automotive wires.
Make perfect joints, splices or crimps.
I allow this information to be copied and published elsewhere without making any reference to its creator...
RJShep
https://www.vwt4forum.co.uk/threads/t5- ... st-6707142
https://www.vwt4forum.co.uk/threads/t5- ... st-6708032
8)
BlackT51
Drives: No polos
Post by BlackT51 »
ciclo wrote: Sun Sep 11, 2022 9:41 pm Thanks for the picture and Autoscan.
Its about slip ring on a wheel i think there is some magic with it when i change steering wheel there was a light after anti slip, and later it fixed itself.
Notes:
I hope 'my' English can be understood.😁
Okay, thank you i almost understand everything today after work i will try it. :mrgreen:
BlackT51 wrote: Mon Sep 12, 2022 8:13 am
Notes:
Exactly, the faults detected in the GW on the G85 sensor and the 'intermittent' communication failure with the Powertrain Data Bus are clues to think that something is wrong/was wrong in connector T41. (has happened on more occasions)
Some time ago I realized that the problem of understanding in this tower of babel was not the language... rather the technical issues.
Sometimes our languages use the same sematic origin for some words, but the particular circumstances of the different peoples that use them make the meaning of the word totally different. Which causes great confusion.
Good luck fitting the wires (don't forget to remove the negative battery cable before doing any wire work).
Please report your high/low beams results to be useful for current or future forum users. Thanks.
BlackT51
Drives: No polos
Post by BlackT51 »
First time when i get this fault was when i make cruise control retrofit, but then i put everything back together i get slip ring fault i use vcds and other diagnostic tool to delete this fault but nothing after some time it fixed itself... later i buyed MFSW i disconnect slip ring again, and now i have again this problem with this slip ring, but now this light still on not fixing itself and it long time now..
Thank you again, i will try do my best :wink:
Hamster
Drives: VW T5
Post by Hamster »
ciclo wrote: Thu Sep 08, 2022 6:16 pm Some ideas:
When installing Bixenon headlights, the 4 parking/side lights are powered individually, but you already did this according to your comments, link...?
The original wires in the front for these lights with Halogen headlights need to be isolated (T10) - check insulation - ...and install the two new ones from the BCM to the headlights (T14).
You may have forgotten to install the J431 headlight range control unit (55 Adres). :)
Try enabling and disabling the last 4 Bits of Byte11, maybe you'll have luck with this.
4 and 5 should be enabled based on the new light settings.
6 and 7 is the diagnosis.
Ciclo I checked the entire installation again and added the headlight range module, unfortunately to no avail.
So far I have selected BYTE19 BIT6 and the indicator on the meter went out.
Everything works great :!: Lights, headlight washers and headlight range control 8)
I'm very grateful to you for the help you have shown me, you're a great specialist in automotive electrics :shock:
Maybe I could repay you somehow? :lol:
The best and only payment is the one you just made.👌
Enjoy your great work!
dkudel
Drives: Vw caravelle 2015
Post by dkudel »
Hi Cyclo Can we contact you by phone I urgently need your help with the lights please
I will help you here efficiently.
If something catastrophic has not happened, everything has an easy solution.
(waiting for the forum notification of your reply to fix this problem/issue as soon as possible)
dkudel
Post by dkudel »
There is a lot to describe and I don't know where to start Ok I will try to sey what I mean. I want to do auto lights in my t5.1
I'll replace the light switch. I'm not sure if I need to pull any wires or do you need to code something?
Here you have everything you need. Please, read without urgency and carefully from the beginning of the thread.
I'll help you with the coding when you finish the installation.
Good luck!
dkudel
Post by dkudel »
Thank you for your response. I understand that coding alone is not enough. I read the thread and concluded that there is a description to be taken over for bxenon lamps
dkudel
Post by dkudel »
Hi Ciclo It is possible that you would make wire harnesses for me that I need to switch to the auto lights?
I am very sorry, but currently it is no longer possible.🙏
Thank you very much for trusting me, it is what I wanted some time ago.
