til3tsio
Drives: Seat Toledo KG
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Post by til3tsio »
iichel wrote: Mon Jan 16, 2023 8:20 pm
benmet wrote: Thu Dec 22, 2022 10:29 am
iichel wrote: Thu Dec 22, 2022 8:14 am
Thanks. I will reply by private message with your new eeprom to try.
Thank you very much. :) I am already despairing.
Hi, I had a look at your EEPROM but I'm afraid I'm not able to find anything wrong with it. I compared all the reference values that VDO offer with a stock 6R0 eeprom, and it seems well adjusted.
Hi , maybe I can help. I did something similar recently.
Vdo editor does not have many options like brake fluid warning, abs type or boot indicator.
I need eeprom backup from the old and new clusters to fix it.
til3tsio wrote: Tue Jan 17, 2023 4:40 am
Great, I've sent you the EEPROM via PM
MrCollayder wrote: Sun Jan 15, 2023 7:35 pm So, I've finally done some tests with 2q0 BSD radars =)
Now I have only 2 errors in 3C: no warning lamps))
Parking exit assistant is now active, but BSD isn't yet because of these errors.
Long coding is 52 95 24 A0.
This coding is for PQ.
• BSD/SWA is ON
• WITHOUT ecu for draw bar
• left-hand drive
• BSD/SWA warning lamps via PWM
• WITHOUT pre-crash_rear
• RTCA is ON
• parksystem installed
• NO break intervetion
• WITHOUT lane assist
Next week I'll try to connect both lamps and activate RTA.
Cool, thanks for helping out. Really appreciated. What dataset are you using?
benmet
Drives: Polo 6R 105PS TDI
Post by benmet »
iichel wrote: Tue Jan 17, 2023 9:42 am
thank you iichel & til3tsio for your help :)
MrCollayder
Drives: Polo 614 sedan (cave+dq200)
Post by MrCollayder »
• BSD/SWA is ON
• left-hand drive
• RTCA is ON
Today I've connected the lamps. So, there aren't any errors in 3C =)
Dataset's from passat_usa: 003C_2Q0907686B_0150_1VWMA7A31MC000090_USA
MrCollayder wrote: Tue Jan 17, 2023 2:02 pm
• BSD/SWA is ON
• left-hand drive
• RTCA is ON
Very valuable information, thank you very much!
MrCollayder
This is mine assists:
1. Parking exit
2. Blind spots
3. fatigue detection
P.S. lots of work are maden... trend --> exclusive :D
Looks good. Did you connect to powertrain canbus or instrument?
MrCollayder
iichel wrote: Tue Jan 17, 2023 7:14 pm Looks good. Did you connect to powertrain canbus or instrument?
Powertrain. This is the only way for pq25.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Is this modified cluster?
I haven't seen such dials with specially for fuel.
But it looks very nice.
MrCollayder
ag69 wrote: Wed Jan 18, 2023 4:59 am Is this modified cluster?
No, this is usual mfa+ (sw 1009) with the custom dials.
MrCollayder
But I hope, I can install 3d premium instrument cluster 8)
Immo data's already been copied, so the nearest aim is to adapt it physically:
ag69
Post by ag69 »
Great !!!
Waiting for your desired cluster.
Now I would add such dials to my 6R cluster in 6C shell in my dreams :D
benmet
Post by benmet »
Hi till3tsio,
Thank you for your messages and your work. Unfortunately I can't answer the messages because I'm still too new to the forum. Unfortunately, I always have to send in the speedometer to upload the EEPROM file.
The part number of my Polo speedometer is 6R0920861H. Thank you for your help.
til3tsio
Post by til3tsio »
Ok , no problem !
It's a pleasure to help others.
I reuploaded the file with a small fix to your fuel curves and fuel warning indicator so make sure to download it again.
Also you have to transfer your adaptation map from the old one so the service intervals and other settings are true on the new one .
* Sorry iichel, we highjacked your thread :D
