BCM Max Transporter 2013
Re: BCM Max Transporter 2013
post a vcds autoscan please to see what's happening
LaurentiuL
Drives: Amarok
Post by LaurentiuL »
Hello, cilco how can i get in touch with you, i want to ask you something and i cannot send you a pm. Thx.
Hi welcome.
Start here...
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
So I have finally completed my EPB retrofit
I had this kit from e-bay that have nearly everything I want
Attached the new button:-
Replaced the calipers:-
Everything works as expected
Part Two was dealing with parking signal to cluster
First I have modified my secondary cluster
After that I have edited epprom with VDO editor
But after testing the signal is reversed
So I have P light on when parking break is not engaged
When I have a free time I will try to sort it out
Shadow109
Post by Shadow109 »
No progress on retrofitting the 2Q0 radars,
But I had succeeded to add cool feature to my 5Q0 radars
Rear traffic alert warning on Cluster :-
[youtube]https://youtu.be/2JTT2LMBan4[/youtube]
prtvrk
Drives: 6C
Post by prtvrk »
Shadow109 wrote: Tue Jan 31, 2023 7:10 am No progress on retrofitting the 2Q0 radars,
How? I'm missing that
Shadow109
Post by Shadow109 »
I don’t really know yet, send me your coding to check it
prtvrk
Drives: 6C
Post by prtvrk »
Shadow109 wrote: Tue Jan 31, 2023 7:31 pm I don’t really know yet, send me your coding to check it
Cluster, parking assist and blind spot?
Shadow109
Post by Shadow109 »
prtvrk
Drives: 6C
Post by prtvrk »
Shadow109 wrote: Wed Feb 01, 2023 6:42 am parking assist and blind spot
Parking assist:
1K8919475D
LC: 00 31 16 72 51
Blind Spot
2Q0907686B
LC: 52 94 A4 20
prtvrk
Drives: 6C
Post by prtvrk »
@shadow109, i can't reply to your PM as a new user. Can I send you an email?
Shadow109
Post by Shadow109 »
this is a small present for everyone in this forum, the data in this file was collected VCDS (German), and from this furom
https://www.dropbox.com/s/2jfabdoz2u1ir ... 1.clb?dl=0
Byte29 Bit5 is active when LED headlight "modules" (PQ25) are installed. (in case someone wants to correct that label👍)
Shadow109
Post by Shadow109 »
Sure, I will correct it, big thanks 🙏
Shadow109
Post by Shadow109 »
New project on the way :-
The cluster, key, and elv is form the same, this will make it possible to adapt elv through vvdi2
I am not starting this project until finishing DCC
after trying to bought used shock absorbers, I have discovered that my country rules had forbidden buying used shock absorbers, so I had to change the plane and buy new ones
After checking etka I found out I can use t6.1 rear shock absorbers which is cool
