- Drives: 6R Polo GT 1.6 TDI
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Thank you for the clarification ciclo sir. Its huge turn off that this feature isn't supported by this BCM max I'm using currently. Which BCM max shall I use?
7E0937090 B or C or D or E.
Any of them support memory seats, as you can see in the autoscan of the iichel 6R on the first page.
Are all of these BCM max? I don't want any of the current functions get hampered by switching to the new BCM.
Yes, all 089 and 090 BCM's for PQ are max ones.
Thanks iichel sir. Form where can I source BCM max? Could you pls help?
The most recent versions always came from Russia, i.e. via appreciated member firegrafik. I'm not sure he is still selling them. They were usually new and priced very competitively.
Here I can buy a used B/C/D at around 150-200 euros. Then I'd need to ship it to India. Might get very expensive and slow.
The eBay doesn't seem to have any better offers right now:
https://www.ebay.de/sch/i.html?_from=R4 ... =2&_sop=15
There are few BCMs available on ebay.uk
They are showing up with vw transporter
That's perfectly fine if they are from transporter, that doesn't matter
Can u pls tell which is the latest version of BCM max?
I believe it's the 7e0937090E
- Drives: Polo 614 sedan (cave+dq200)
