Polo AW Led bulbs
blackscell
Drives: 2018 AW
Polo AW Led bulbs
Post by blackscell »
Anyone know some error free Led bulbs? I've tried some canbus, most of them give dashboard errors. Only one working atm is the H7 in my headlights. H7 highbeam give errors. Rear lights canbus everything gave an error. Seems like the Polo is too sensitive. Or is there an option to change Halogen to Led in VCDS?
Dazeredo
Drives: Polo aw1 1.0t 95hp
Re: Polo AW Led bulbs
Post by Dazeredo »
I've led in the rear turn signals without errors, but I bought the same bulb that other user already tested.
blackscell
Drives: 2018 AW
Could u link me up?
Teee
Drives: Polo gti +
Post by Teee »
I got my led reverse lights from AliExpress
(P21w bulb) no errors on the display
https://a.aliexpress.com/_dYJCQwZ
Edit :-
The indicator lights are PY21W But I never changed those.
MattHGR
Drives: GTI+
Post by MattHGR »
You can code the car for led bulbs instead of standard.
Simple Google search will bring up the code needed
blackscell
Drives: 2018 AW
Is that possible with a clone cable?
MattHGR
Drives: GTI+
Post by MattHGR »
Not sure. Did my adaptations through OBDEleven, but used a VCDS forum to find the options to change.
Dazeredo
Post by Dazeredo »
blackscell wrote: Wed Jul 29, 2020 1:29 pm Could u link me up?
https://www.ebay.com.au/itm/264669415032
It was cheaper when I bought :oops:
blackscell
Drives: 2018 AW
The led is working, no errors and hella bright. Anyone got a link for the H7 high beam lights? Got the normal ones. Tried 2 different Canbus for the highbeam, both barely light up and gives an error
danx0r
Drives: 2020 GTI
Post by danx0r »
Can anyone suggest which LEDs work without error? Links posted above no longer work.
