Golf 7.5 DCC project. Coding. Basic Settings. Test.
After connecting the DCC system, the first diagnosis shows a large number of faults in the control units due to the battery disconnection and the installation of the new DCC system. Coding is required to clear all DTCs.
Applied coding.
DCC Coding (VCDS/ODIS)
Address 03: ABS Brakes (J104)
Coding:
Byte27 Bit7 ... enable (DCC installed)
Address 09: Cent. Elect. (J519)
Adaptation:
[VO]_Leuchtweitenregulierung:
[LO]_sensor_headlight_range_control_installed: [VO]_front_and_rear
[LO]_1_Sensor_LWR: [VO]_2-Sensor LWR
[LO]_Quelle_Hoehenwerte: [VO]_CAN_Daempferregelung
Address 17: Instruments (J285)
Coding:
Byte4 Bit4 ... enable (DCC installed) [LN]_damper control electronic: [VN]_yes
Address 19: CAN Gateway (J533)
Coding:
Byte12 Bit7 ... enable [LO]_FPA_Funktion_DR: [VN]_not active [VN]_active
Adaptation:
14 -Wheel Damping Electronics ... enable
[VN]_Gateway_Component_List:
[LN]_Node_0x72: [VN]_not_coded [VN]_coded
Address 4B: Multifunc. Module (J745)
Coding:
Byte8 Bits1-2 ... enable
[LO]_lwr_sensors: [VO]_2_sensors
[LO]_Source_height_value: [VO]_DCC
Basic Setting.
Address 14: Wheel Damping Electronics.
ODIS-S: Guided functions.
BASIC SETTING ... Vehicle liftted (axles extended)
Basic setting 4B.
viewtopic.php?p=582892#p582892
I drive a short distance to have all the sensors recalibrated due to the battery disconnect. I do a new ignition cycle and clear all the DTCs.
'In my case', I have two permanent faults left in the DCC unit (14 Address) that I must solve.
1- Wheel Damping Electronics. Basic Setting.
ODIS S.
To perform the Basic Setting it is necessary to lift the vehicle so that the axles are extended and the wheels are not in contact with the ground.
I had planned to do it on the platform of my trusted wheel workshop, but I preferred to do it with two jack stands and two trolley jacks because I wasn't going to work under the car, it would take me a couple of minutes, plus the 5 to 10 seconds in which ODIS S performs the basic setting.
I went to a place far from humanity, trolls and other divinities
, to avoid possible incidents as much as possible.
Warning:
Do not do what you see in the two previous images if you are going to work under the car,
additional safety measures are necessary.
I click on yes and the basic setting is done successfully in the blink of an eye, I didn't have time to take a screenshot.
2- Wheel Damping Electronics. Invalid dataset.
ODIS E
I don't know why the data set on my DCC unit 5Q0907376C (coming from an Arteon according to the eBay seller
viewtopic.php?p=597558#p597558) is invalid.
I look in MIB Solution, and luckily there is a different dataset also coming from an Arteon. I downloaded them and did the data transfer with ODIS E, as usual.
Note:
I first did the data transfer with the Golf (clubsport) dataset that is on the VCP servers, but logically it doesn't work either for DCC unit 5Q0907376C (Slider).
OK!
VCDS Autoscan.
Sunday,07,April,2024,14:06:06:32438
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate: DCC. OK!
Mileage: 53083km-32984mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 14 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C
A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW Mileage: 53083km-32984miles
14-Susp. Elect. -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 L HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6198
Revision: D7H20000 CVN: 92B19492
Coding: 01190032234415082000
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ECM10TFS01104C906025L 002003
ROD: EV_ECM10TFS01104C906025L_002.rod
VCID: 290F00D8897EC92258D-807C
VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 51998000000173
Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F08A40AA430B00000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B51BA40840D6DA05F-8022
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 AJ HW: 5NA 907 044 AJ
Component: AC Automat H50 1301
Revision: 20K03000 Serial number: 00000A00202735
Coding: 000200032001100D1115004C0018542A
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ACTouchPrehVW37X 001010
ROD: EV_ACTouchPrehVW37X_VW37.rod
VCID: 074B66607FAADF526E9-8052
Air quality sensor:
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 D HW: 4H0 907 658 D
Component: G935 MuFu H05 0010
Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 EC HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 1513
Serial number: 72007150025702 Dataset Number: V03935315NT 0001
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
VCID: 7DA704882D768582445-8028
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0F4DFD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SBY22M01D06H23M07S44
Coding: 00A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY191251XZQ
Alarm horn:
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Component: Sirene, DWA 005 0313
Serial number: 00002854456462182207
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H07 0073
Serial number: 000308417318277 Dataset Number: V03935313MC 0001
Coding: 8271567841
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 58E9751CE29480AA373-800C
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 S HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0780
Dataset Number: V12345678AA V310
Coding: 2B0D67E35DFFC728979C81A4614006800000000000B9C00024
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW37.rod
VCID: 47CBA6603F2A1F52AE9-8012
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 31051841350252 Dataset Number: V03935317XE 0001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392FD09879DE79A228D-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4F1CUQ Dataset Number: V03935272MG 0001
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00064
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F605869BEA92278D-805C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30071820325
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E31071830145
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 307 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000F8745C23S
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 002 807 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000EC18233G
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A729FD154210-
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A929FD1515577
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A326704A3C63.
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 404 4191
Coding: 07A532807E8C000801887A0F5401000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2B03FAD08382DB32AA1-807E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 C
Component: GW MQB High 521 5502
Serial number: 09012020001767 Dataset Number: SET_FPA_MOD 0001
Coding: 030900047F085700FB0002FE880F00010001070000000000000000000000
GVL: 014E3C100000000040CC800000024C0000000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW37.rod
VCID: 7F5BFE80277A9792569-802A
Generator:
Component: 4-01-02-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218123222100544
Coding: AE2B00
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9353818504
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H07 0150
Serial number: 00000587514012
Coding: 52A54640
ROD: EV_HREntryHellaGen3Kl15.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H07 0150
Serial number: 00000587481913
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 P HW: 5Q4 959 593 P
Component: TSG FS 011 0912
Serial number: 0000417322781 Dataset Number: V03935341UB 0001
Coding: 00150220D000048000001000
Shop #: WSC 00030 935 00052
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 52FD8734C468AAFAC97-8006
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Dataset Number: V03935287HR 0001
Coding: 931F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B121AC1E3CC4CA3BB-8020
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0371
Serial number: 01081930001280 Dataset Number: V03935292JZ 0001
Coding: 00000005090016C206207F07620000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 372BD6A04FCA6FD2DE9-8062
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 P HW: 5Q4 959 592 P
Component: TSG BFS 011 0912
Serial number: 0000423015792 Dataset Number: V03935341UE 0001
Coding: 00150220DE00048000001000
Shop #: WSC 00030 935 00034
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 51FF8838C16ED1E2F0D-8004
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000009846262
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0879
Serial number: Dataset Number: 5G0CV1v____ 0001
Coding: 02731001FF0000004111010140880A231F0507E401200400CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323DE7B4A4A88AFAE97-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2691212
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 CA HW: -----------
Component: ECE AS 22/23 --- 1810
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000250801 Dataset Number: RDKS_TinyQ_ 1017
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3829D59C42D460AAD73-806C
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Dataset Number: V03935246NT 0001
Coding: 01040201C600201F000060
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 C HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E80320004213340 Dataset Number: V03935349WG 0001
Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW27.rod
VCID: 3537DCA855C69DC2CC5-8060
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5F0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 Z001
Serial number: 181027201414
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6A8D3FD44CF8023A917-803E
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:45, VBatt start/end: 14.5V/14.5V)-----------
Part No SW:
V03935317XE 0001
Slider. Video
https://www.youtube.com/embed/fx62RFSay ... autoplay=1
Previous update of the GW dataset for Slider.
viewtopic.php?p=602020#p602020
Related (MODE):
viewtopic.php?p=577888#p577888
Test.
- In Comfort mode, filters road irregularities with notable gentleness. For my personal taste, perhaps the maximum Comfort setting makes the suspension a bit bouncy for good roads at high speed, so I think the maximum Comfort setting is only recommended for really bad roads, like rural roads in a very bad state of conservation (like the image above).
- I love all the possibilities with the Slider, allows you to adjust the suspension for any type of road with relative precision (depends on the driving capabilities/skills/experience/knowledge of each individual). Those who have high driving skills will greatly appreciate this type of electronic damping.
- Considering that our Golf had a 'standard' suspension from the factory (which is already very good), I really appreciate the Sport mode setting for highways or sporty driving, the driving becomes very precise. I like the maximum Sport setting, it brings back memories of an S3 that I had in the past (not the same, but that jumps out in my mind).
- The good handling of the car is not lost in any setting of the driving profiles, even in the maximum Sport setting the/your back will not suffer due to the irregularities of the road.
On the other hand, the MODE button on the center console now makes more/real sense, you can switch from one driving profile to another quickly, which is very convenient for roads that have small sections with many irregularities or in poor condition and the most of the route/road is in good condition.
Works Wonderfully!
https://www.youtube.com/watch?v=hzryq-i_ukg
Currently I prefer this suspension height, I have already had other cars with very good and low suspensions that I will not have again. The laws of physics and other more mundane laws are inexorable.
Note:
I will check the geometry/alignment of the wheels
according to erWin, in about 1000-2000 kms.
viewtopic.php?p=604516#p604516
At the moment and surprisingly the car feels very good in this sense, it goes in a straight line perfectly, I will see in future checks what happens with the wear of the wheels/tires.
